Solved Magic mirror is not showing up
@CoopDog1712 says something is still running…
you didn’t do pm2 stop all
after doing test
ps -ef | grep -i magicmirror
should return nothing
@sdetweil whoops…
ok is did pm2 stop all and then entered that line of code you gave me and got this -
ok do
we will delete 1 entry so you don’t have 2 trying to run at the same time
and then rebootpm2 delete 1 pm2 save sudo reboot
@sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up
pm2 status again
also, how did you install mm? manual or my automated script?
did you setup MM autostart before adding pm2?
@sdetweil i installed it manually, and no it didnt
@CoopDog1712 what is the output of pm2 status?
@sdetweil k i did that and it was still a blank screen, so i stoped it and did pm2 logs --lines=50 and got this
also would it be worth a try to just completely delete everything and then start from scratch?
