    [HOW_TO] MagicMirror as Desktop Wallpaper (all platform : updated)
    23 Posts 8 Posters 21.9k Views 9 Watching
    • mumblebajM
      mumblebaj Module Developer @MMRIZE
      @mmrize Very nice
      • S sdetweil pinned this topic on
      • doctorwhenD
        doctorwhen @MMRIZE
        @mmrize I just use pcmanfm https://gitlab.com/doctorfree/Scripts/-/blob/master/MagicMirror/backgrounds.sh
        M 1 Reply Last reply
          MMRIZE @doctorwhen
          @doctorwhen
          Interesting. I know pcmanfm can set desktop wallpaper with image, but is it possible also application to locate in background layer?
          Anyway, now we can do it natively since 2.17
          doctorwhenD 1 Reply Last reply
          • doctorwhenD
            doctorwhen @MMRIZE
            @mmrize no, pcmanfm cannot run an application in the desktop background layer, just a wallpaper image. so, i take my comment back, i did not fully understand what you are talking about. but, now i want to try running magicmirror as my desktop background!
            • L
              lexcyr @MMRIZE
              @mmrize Hello
              i just tried it on Xubuntu, the background stay black for me and not transparent. so i can’t see my desktop icons anymore :(.
                MMRIZE @lexcyr
                @lexcyr
                In the Linux environment, some additional options might be needed or modified (I mentioned it in README)
                Anyway, you’ve said;
                It means, your MM is not placed on the desktop layer, but normal application layer. (And your transparent setting also doesn’t work)
                I doubt you probably miss these;
                • Your MM might not be 2.17.
                • Or your configuration was wrong.
                • O
                  OscarVsp
                  Hello, thank for this !
                  I’ve followed configuration for linux, and i also had to add the custom css content to have transparency. It works well expect one issue: the mouse click don’t go through magicmirror, so i can’t click on folder/app on the desktop.
                  Is it normal, and am i supposed to only use the menu to launch app or am i missing something ? I looked on the electron documentation but i didn’t found answer to this…
                  Thanks for your help
                  M 3 Replies Last reply
                    MMRIZE @OscarVsp
                    @OscarVsp
                    I’ve tested MacOS and Windows, but not Linux, sorry. But Electron Manual says type: 'desktop' options would work on Linux Environment too.
                    What kind of Linux are you using?
                      MMRIZE @OscarVsp
                      @OscarVsp
                      You can check whether MM is really ‘most-bottomed’. Adjust some CSS to check whether MM is “COVERING but just transparent” against other icons or applications.
                        MMRIZE @OscarVsp
                        @OscarVsp
                        • Non-X-11 based Linux Desktop might not work.
                        • This behaviour may severely be dependent on the platform, so in some environment, it might not work.
                        • When some OTHER application occupies the “most-bottomed position” later, MM might be expelled to the foreground. I’m not sure.
                          MMRIZE
                          Just for confirmation about still-working. (2024-05-16)
                          Both electronOptions and electronSwitches to be added must reside within the config variable in config.js. I didn’t mention it because it seemed obvious. Surprisingly, it seems to be misunderstood as adding this to the end of the file.
                          plainbrokeP 1 Reply Last reply
                          • plainbrokeP
                            plainbroke @MMRIZE
                            @MMRIZE
                            I tried to figure out what and how to make this work. Wow, way above my abilities.
                            Can you make a script for all of it so, us dummies can use it?
                              MMRIZE @plainbroke
                              @plainbroke which environment are you using?
                              • plainbrokeP
                                plainbroke @MMRIZE
                                @MMRIZE
                                MM latest and windows 10
                                  MMRIZE @plainbroke
                                  @plainbroke can you install MM on your windows and be able to run it? Or should we start from there?
                                  J plainbrokeP 2 Replies Last reply
                                    JohnGalt @MMRIZE
                                    @MMRIZE
                                    Do you know whether the install script developed and maintained by @sdetweil would install on various specified versions of Windows [E.G. Win7, Win 8, Win 8.1, Win 10 or Win 11]? if that script will install on the various implementations of Windows, that would likely solve this question of how to do it.
                                    M S 2 Replies Last reply
                                      MMRIZE @JohnGalt
                                      @JohnGalt
                                      To be honest, I always install MM on various env, manually by myself. Never with his script. So my experience will not be helpful.
                                      Anyway,
                                      Even in windows (I installed MM many times on Windows) it is always same.
                                      1. Install git-bash
                                      2. Install nvm-for-windows, then install node js through it.
                                      3. Make a working directory for MM on git-bash terminal.
                                      4. Clone repository of MM on that directory with git command.
                                      5. Edit some path in package.json for Windows.
                                      6. execute npm install.
                                      7. Make config.js, custom.css
                                      8. For fonts and bundle, install them.
                                      Well, For me it’s not difficult at all but I recommend @sdetweil ‘s script for beginners. As far as I know, it will work on all Windows version.
                                      S J 2 Replies Last reply
                                        sdetweil @JohnGalt
                                        @JohnGalt the script does NOT work on windows… it is bash only
                                        but install on windows is easy too…
                                        (well, node and npm excluded)
                                        the doc has the steps
                                        open a command prompt (cmd.exe)
                                        use nvm to install node version needed
                                        https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems
                                          sdetweil @MMRIZE
                                          @MMRIZE no NOT need git bash
                                          MM runs under cmd.exe just fine
                                            MMRIZE @sdetweil
                                            I prefer bash. For similar experience with real -NIX/MacOS.
