    Use of Samsung „The Frame“ with MM
    samsung the frame
    11 Posts 4 Posters 8.7k Views 4 Watching
      MajorC Project Sponsor
      did anyone use Samsungs The Frame together with MM?
      From what I had read the TV sounds like a good solution for my dashboard screen idea. My MM will be 80% of the time show all my pictures and 20% of the time weather, news and calendar.
      It will not have a mirror and sit in the living room.
      Happy to get any feedback from you.
      Christian
      M JalibuJ 2 Replies Last reply Reply Quote 0
        MMRIZE @MajorC
        @MajorC
        Samsung’s tizen os has sonehow outdated chromium, so some of modern 3rd party modules might not work, but I think default modules ok.
        • JalibuJ Offline
          Jalibu Module Developer @MajorC
          @MajorC
          I have a Samsung the Frame, but you can only display photos in the power-saving Art Mode and not a browser. This is also not possible in Ambient Mode.
            sdetweil @Jalibu
            @Jalibu not running ON/IN the TV, but thru a separate HDMI port. you should be able to do anything u want
            HDMI signal is an HDMI signal. TV doesn’t know what is being displayed
            JalibuJ 1 Reply Last reply Reply Quote 0
            • JalibuJ Offline
              Jalibu Module Developer @sdetweil
              haha, of course it works with HDMI ;-)
              But I think this question is about Samsung The Frame specific features and not TVs in general 🙃
                sdetweil @Jalibu
                @Jalibu i don’t think that was what he was asking… but maybe he will chime in…
                I have a precursor to the frame, 82in samsung with the external hdmi ports… MM works fine over hdmi
                (google ChromeCast does the same thing)
                  MajorC Project Sponsor @sdetweil
                  My idea was to run MM via HDMI and a Raspberry when I am in the room.
                  If no one is in front of the frame, it should switch to “frame mode” and display a picture.
                  But do not know if it works that way. Or if I just take a normal monitor and have a frame built.
                    sdetweil @MajorC
                    @MajorC said in Use of Samsung „The Frame“ with MM:
                    that is a good question…
                    looks like not
                    https://us.community.samsung.com/t5/QLED-and-The-Frame/Feature-Request-CEC-Anynet-options-to-prevent-Frame-switching/td-p/1287539
                    looks like if u turn it off with CEC then its ‘off’, not frame mode
                      Following the comments in your link, Samsung has made it possible by a firmware update.
                      Maybe @Jalibu can double-check the behavior.
                      • JalibuJ Offline
                        @MajorC
                        I did not find this option as a setting on my Frame (latest Firmware). Unfortunately, I also can‘t test this because I don’t have a Anynet device
                          MajorC Project Sponsor @Jalibu
                          It looks like there are different firmware features. Depending on the hardware.
                          Great thx Samsung. Now I have to find out when this option is available. I’m not really willing to spend 500€ for a picture frame. Then I can rather buy a monitor and have a nice wooden frame built by a carpenter.
