    Use of Samsung „The Frame“ with MM
    samsung the frame
    11 Posts 4 Posters 9.3k Views 4 Watching
      MMRIZE @MajorC
      @MajorC
      Samsung’s tizen os has sonehow outdated chromium, so some of modern 3rd party modules might not work, but I think default modules ok.
      • JalibuJ Offline
        Jalibu Module Developer @MajorC
        @MajorC
        I have a Samsung the Frame, but you can only display photos in the power-saving Art Mode and not a browser. This is also not possible in Ambient Mode.
          sdetweil @Jalibu
          @Jalibu not running ON/IN the TV, but thru a separate HDMI port. you should be able to do anything u want
          HDMI signal is an HDMI signal. TV doesn’t know what is being displayed
          JalibuJ 1 Reply Last reply Reply Quote 0
          • JalibuJ Offline
            Jalibu Module Developer @sdetweil
            haha, of course it works with HDMI ;-)
            But I think this question is about Samsung The Frame specific features and not TVs in general 🙃
              sdetweil @Jalibu
              @Jalibu i don’t think that was what he was asking… but maybe he will chime in…
              I have a precursor to the frame, 82in samsung with the external hdmi ports… MM works fine over hdmi
              (google ChromeCast does the same thing)
                MajorC Project Sponsor @sdetweil
                My idea was to run MM via HDMI and a Raspberry when I am in the room.
                If no one is in front of the frame, it should switch to “frame mode” and display a picture.
                But do not know if it works that way. Or if I just take a normal monitor and have a frame built.
                  sdetweil @MajorC
                  @MajorC said in Use of Samsung „The Frame“ with MM:
                  that is a good question…
                  looks like not
                  https://us.community.samsung.com/t5/QLED-and-The-Frame/Feature-Request-CEC-Anynet-options-to-prevent-Frame-switching/td-p/1287539
                  looks like if u turn it off with CEC then its ‘off’, not frame mode
                    Following the comments in your link, Samsung has made it possible by a firmware update.
                    Maybe @Jalibu can double-check the behavior.
                    • JalibuJ Offline
                      @MajorC
                      I did not find this option as a setting on my Frame (latest Firmware). Unfortunately, I also can‘t test this because I don’t have a Anynet device
                        MajorC Project Sponsor @Jalibu
                        It looks like there are different firmware features. Depending on the hardware.
                        Great thx Samsung. Now I have to find out when this option is available. I’m not really willing to spend 500€ for a picture frame. Then I can rather buy a monitor and have a nice wooden frame built by a carpenter.
