    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • luisestradaL
      luisestrada @sdetweil
      @sdetweil said in MMM-CalendarExt3:
      @luisestrada each sends out its own list of entries. maybe calext3 is replacing a with b with c
      That’s exactly what i thought, so thats why I created 3 different modules by copying the entire module in a separate folder and renaming it, similar to this: https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial
      but still, if I have 3 modules called, calendar, calendar1 and calendar2, it does it
      M S 3 Replies Last reply Reply Quote 0
        MMRIZE @luisestrada
        @luisestrada
        Well, I was worried about just that case when I developed this module - multiple calendar instances. I thought Nobody would use the calendar module like that. So I haven’t considered supporting that case. But I was wrong.
        The current behaviour of this module is replacing whole events when the notification arrives, not combining each. So you cannot get proper whole events from multi-emitter of notifications.
        I’ll modify the module in a few days to stack each event not replace it. Wait for a little.
          MMRIZE @luisestrada
          @luisestrada
          By the way, your configuration is not quite effective. Some options are located in the wrong place, some are invalid.
          • All module-specific user configuration should be placed in config: { ... }. Your waitFecth or eventTimeOptions and something more would not be applied.
          • there is no fetchInterval or rotateInterval option in CX3.
          • broadcastPastEvents is not for CX3 module but for calendar module.
          • refreshInterval: 1000 * 60 * 1 means redraw calendar every 1 minute. Is it really needed?
          luisestradaL 1 Reply Last reply Reply Quote 0
            sdetweil @luisestrada
            @luisestrada the info inside(event broadcast) is still the same
            and u didn’t need to do the rename. it supports multiple instances
              sdetweil @MMRIZE
              @MMRIZE u can see in config if multiple instances and maybe the ‘from’ on notification
              • luisestradaL
                luisestrada @MMRIZE
                @MMRIZE said in MMM-CalendarExt3:
                @luisestrada
                Thank you, I will show you my code so you all can understand the mess I did :beaming_face_with_smiling_eyes:
                @luisestrada
                It was supposed to be ten minutes but because I was trying and adding and testing, I forgot to change it back
                • luisestradaL
                  All calendar were working under the same name, however i thought it was the cause of the blank CX3 so that’s why i tried to create one version for each module as a last resort
                  • luisestradaL
                    luisestrada
                    My code with the changes based on your feedback (and it seems to be working for now) Thank you!
                    //Calendar hidden Module
                                //position: "top_left",
                                header: "Eventos",
                                    broadcastPastEvents: true, // <= IMPORTANT to see past events
                                    instanceId: "WeeklyCalendar",
                                            url: "URL1",
                                            name: "Cal1", // <= RECOMMENDED to assign name
                                            color: "#0760d1", // <= RECOMMENDED to assign color
                                            symbol: false
                                            url: "URL2",
                                            name: "Cal2", // <= RECOMMENDED to assign name
                                            color: "#2a4d56", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
                                            symbol: "birthday-cake"
                                            url: "URL3",
                                            name: "Cal3", // <= RECOMMENDED to assign name
                                            color: "#333", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
                                            symbol: "bank"
                                            url: "URL4",
                                            name: "Cal4", // <= RECOMMENDED to assign name
                                            color: "#3f0101", // <= RECOMMENDED to assign color
                                            symbol: "flag"
                                            url: "URL5",
                                            name: "Cal5, // <= RECOMMENDED to assign name
                                            color: "#765f02", //rgb(58%, 24%, 45%) // <= RECOMMENDED to assign color
                                            symbol: "flag"
                    // CX3 Module
                                module: "MMM-CalendarExt3",
                                position: "bottom_bar",
                                title: "Calendario",
                                    mode: "week",
                                    locale: 'es-CO',
                                    maxEventLines: 3,
                                    firstDayOfWeek: 0,
                                    weekIndex: 0,
                                    weeksInView: 4,
                                    waitFetch: 1000 * 10, //	(ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                                    refreshInterval: 1000 * 60 * 10, //	(ms) refresh view by force if you need it.
                                    glanceTime: 1000 * 60 * 10,	// (ms) Return to original view when you move to other moment by notification.
                                    eventTimeOptions: {
                                        timeStyle: "short"
                                    //useSymbol: false,
                                    calendarSet: ['Cal1', 'Cal2', 'Cal3', 'Cal4', 'Cal5'],
                    Now these 3 calendars seem not to be conflicting with CX3
                    			module: "calendar2",
                    			header: "CAL2",
                                            url: "CAL2"
                    				maximumEntries: "2",
                                    wrapEvents: true
                    			header: "CAL3",
                                            url: "CAL3"
                    				maximumEntries: "3",
                                    wrapEvents: true
                    			header: "CAL",
                                            url: "CAL"
                    				maximumEntries: "5",
                                    wrapEvents: true
                    Sorry for the long message
                    • luisestradaL
                      luisestrada @luisestrada
                      @luisestrada said in MMM-CalendarExt3:
                      I talked too fast, I pressed submit and the issue came back :anxious_face_with_sweat:
                        MMRIZE @luisestrada
                        @luisestrada
                        By your configuration;
                        • It will be refreshed every refreshInterval by force. You’ve set up 10 minutes.
                        • It will be refreshed after 10 seconds(waitFetch) of the last calendar parsed. a more frequent parsing of your calendar would be a more frequent updating view. If your 5 calendars finish their parsing in 10 seconds together, the view will be updated once. Meanwhile parsing your 5 calendars would take dozen seconds sequentially, the view will be flickering. In that case, set waitFetch longer.
                        Anyway, I’ll release more improved version for frequent CALENDAR_EVENTS in a few days. Plz wait a little.
                        • luisestradaL
                          luisestrada @MMRIZE
                          @luisestrada
                          Thank you @MMRIZE , I took your recommendations.
                          • luisestradaL
                            luisestrada
                            Hi again,
                            I read I did not have to do anything to get the weather displayed, however I still don’t see it. Any idea why?
                              MMRIZE @luisestrada
                              @luisestrada
                              Displaying the weather icon is an experimental feature. It would be applied from the next version of MagicMirror (ver 2.20) which will be released the next July.
                              At this moment(with the current MagicMirror 2.19), you can try like this;
                              cd MagicMirror // Your MM installed directory
                              git pull // to update latest version. If your MM was quite old, you might need additional command `npm install`
                              git checkout develop // Change the branch to develop version.
                              You don’t need this method after July.
                                @MMRIZE if they used my script to install they need a different command
                                see
                                https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                • luisestradaL
                                  luisestrada @MMRIZE
                                  @MMRIZE I may prefer to wait until July then. :smiling_face_with_smiling_eyes:
                                  And thank you so much for the recent update. Now the calendar works perfectly, no blinking and no black calendar as before. Works perfectly
                                  • O
                                    OliWer
                                    Hi, I’m using CalendarExt2 with the MMM-CalendarExtPlan Plugin. This totaly fits my needs with having several calendars next to each other with different type of information for the upcoming days. Currently it looks like this is not possible with CalendarExt3, right?
                                    Is CalendarExt2 not going to be maintained anymore in the near future?
                                    Thanks for the great work btw,!
                                      MMRIZE @OliWer
                                      @OliWer
                                      Thanks for using CX2. I think it is an almost-perfect module which I made. However, some people feel so difficult to use it. So I made a new one, CX3
                                      While CX2 is enough for your purpose, just use it until you find a better alternative.
                                      Anyway, I will not maintain it in near future. The most main reason is, that it is too heavy and severely dependent on other node-dependencies.
                                      For the ExtPlan (and agenda view), I will provide an equivalent module for CX2 someday.
                                      • O
                                        OliWer @MMRIZE
                                        Hope you mean CX3 ;)
                                        Will wait until its done and closely monitor the evolution of CX3. Thanks again for your contribution, really good work!
                                          MMRIZE @OliWer
                                          @OliWer
                                          :) CX3 indeed.
                                          • BKeyportB
                                            BKeyport Module Developer @MMRIZE
                                            @MMRIZE When are you adding “upcoming” view in CX3? :rolling_on_the_floor_laughing:
                                            • 34
                                            • 35
                                            • 3 / 35
