    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • luisestradaL
      luisestrada @sdetweil
      @sdetweil said in MMM-CalendarExt3:
      @luisestrada the info inside(event broadcast) is still the same
      and u didn’t need to do the rename. it supports multiple instances
      All calendar were working under the same name, however i thought it was the cause of the blank CX3 so that’s why i tried to create one version for each module as a last resort
      • luisestradaL
        luisestrada
        My code with the changes based on your feedback (and it seems to be working for now) Thank you!
        //Calendar hidden Module
                    //position: "top_left",
                    header: "Eventos",
                        broadcastPastEvents: true, // <= IMPORTANT to see past events
                        instanceId: "WeeklyCalendar",
                                url: "URL1",
                                name: "Cal1", // <= RECOMMENDED to assign name
                                color: "#0760d1", // <= RECOMMENDED to assign color
                                symbol: false
                                url: "URL2",
                                name: "Cal2", // <= RECOMMENDED to assign name
                                color: "#2a4d56", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
                                symbol: "birthday-cake"
                                url: "URL3",
                                name: "Cal3", // <= RECOMMENDED to assign name
                                color: "#333", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
                                symbol: "bank"
                                url: "URL4",
                                name: "Cal4", // <= RECOMMENDED to assign name
                                color: "#3f0101", // <= RECOMMENDED to assign color
                                symbol: "flag"
                                url: "URL5",
                                name: "Cal5, // <= RECOMMENDED to assign name
                                color: "#765f02", //rgb(58%, 24%, 45%) // <= RECOMMENDED to assign color
                                symbol: "flag"
        // CX3 Module
                    module: "MMM-CalendarExt3",
                    position: "bottom_bar",
                    title: "Calendario",
                        mode: "week",
                        locale: 'es-CO',
                        maxEventLines: 3,
                        firstDayOfWeek: 0,
                        weekIndex: 0,
                        weeksInView: 4,
                        waitFetch: 1000 * 10, //	(ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                        refreshInterval: 1000 * 60 * 10, //	(ms) refresh view by force if you need it.
                        glanceTime: 1000 * 60 * 10,	// (ms) Return to original view when you move to other moment by notification.
                        eventTimeOptions: {
                            timeStyle: "short"
                        //useSymbol: false,
                        calendarSet: ['Cal1', 'Cal2', 'Cal3', 'Cal4', 'Cal5'],
        Now these 3 calendars seem not to be conflicting with CX3
        			module: "calendar2",
        			header: "CAL2",
                                url: "CAL2"
        				maximumEntries: "2",
                        wrapEvents: true
        			header: "CAL3",
                                url: "CAL3"
        				maximumEntries: "3",
                        wrapEvents: true
        			header: "CAL",
                                url: "CAL"
        				maximumEntries: "5",
                        wrapEvents: true
        Sorry for the long message
        luisestradaL 1 Reply Last reply Reply Quote 0
        • luisestradaL
          luisestrada @luisestrada
          @luisestrada said in MMM-CalendarExt3:
          I talked too fast, I pressed submit and the issue came back :anxious_face_with_sweat:
            MMRIZE @luisestrada
            @luisestrada
            By your configuration;
            • It will be refreshed every refreshInterval by force. You’ve set up 10 minutes.
            • It will be refreshed after 10 seconds(waitFetch) of the last calendar parsed. a more frequent parsing of your calendar would be a more frequent updating view. If your 5 calendars finish their parsing in 10 seconds together, the view will be updated once. Meanwhile parsing your 5 calendars would take dozen seconds sequentially, the view will be flickering. In that case, set waitFetch longer.
            Anyway, I’ll release more improved version for frequent CALENDAR_EVENTS in a few days. Plz wait a little.
            • luisestradaL
              luisestrada @MMRIZE
              @MMRIZE said in MMM-CalendarExt3:
              @luisestrada
              Thank you @MMRIZE , I took your recommendations.
              • luisestradaL
                luisestrada
                Hi again,
                I read I did not have to do anything to get the weather displayed, however I still don’t see it. Any idea why?
                  MMRIZE @luisestrada
                  @luisestrada
                  Displaying the weather icon is an experimental feature. It would be applied from the next version of MagicMirror (ver 2.20) which will be released the next July.
                  At this moment(with the current MagicMirror 2.19), you can try like this;
                  cd MagicMirror // Your MM installed directory
                  git pull // to update latest version. If your MM was quite old, you might need additional command `npm install`
                  git checkout develop // Change the branch to develop version.
                  You don’t need this method after July.
                    @MMRIZE if they used my script to install they need a different command
                    see
                    https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                    • luisestradaL
                      luisestrada @MMRIZE
                      @MMRIZE I may prefer to wait until July then. :smiling_face_with_smiling_eyes:
                      And thank you so much for the recent update. Now the calendar works perfectly, no blinking and no black calendar as before. Works perfectly
                      • O
                        OliWer
                        Hi, I’m using CalendarExt2 with the MMM-CalendarExtPlan Plugin. This totaly fits my needs with having several calendars next to each other with different type of information for the upcoming days. Currently it looks like this is not possible with CalendarExt3, right?
                        Is CalendarExt2 not going to be maintained anymore in the near future?
                        Thanks for the great work btw,!
                          MMRIZE @OliWer
                          @OliWer
                          Thanks for using CX2. I think it is an almost-perfect module which I made. However, some people feel so difficult to use it. So I made a new one, CX3
                          While CX2 is enough for your purpose, just use it until you find a better alternative.
                          Anyway, I will not maintain it in near future. The most main reason is, that it is too heavy and severely dependent on other node-dependencies.
                          For the ExtPlan (and agenda view), I will provide an equivalent module for CX2 someday.
                          • O
                            OliWer @MMRIZE
                            Hope you mean CX3 ;)
                            Will wait until its done and closely monitor the evolution of CX3. Thanks again for your contribution, really good work!
                              MMRIZE @OliWer
                              @OliWer
                              :) CX3 indeed.
                              • BKeyportB
                                BKeyport Module Developer @MMRIZE
                                @MMRIZE When are you adding “upcoming” view in CX3? :rolling_on_the_floor_laughing:
                                  Dav8574 @MMRIZE
                                  @MMRIZE
                                  How to add a event where do you place.
                                    "title": "Leeds United - Chelsea",
                                    "startDate": 1650193200000,
                                    "endDate": 1650199500000,
                                    "fullDayEvent": false,
                                    "class": "PUBLIC",
                                    "location": false,
                                    "geo": false,
                                    "description": "...",
                                    "today": false,
                                    "symbol": ["calendar-alt"],
                                    "calendarName": "tottenham",
                                    "color": "gold",
                                    "calendarSeq": 1, // This would be the order from `calendarSet` of configuration
                                    "isPassed": true,
                                    "isCurrent": false,
                                    "isFuture": false,
                                    "isFullday": false,
                                    "isMultiday": false
                                  M S 2 Replies Last reply Reply Quote 0
                                    MMRIZE @Dav8574
                                    @Dav8574
                                    ??? I cannot understand what you meant. Explain in more detail what you want.
                                      sdetweil @Dav8574
                                      @Dav8574 you add calendar entries to a Google or similar calendar system
                                      you use the ical url for that cake dar to the default calendar modules in mm, which download and parse the events, and then broadcast them to other modules
                                      where Ext3, picks them up and produces different views of the entries
                                      • luisestradaL
                                        luisestrada
                                        Hi again,
                                        For some reason my calendars stopped working again, it seems it only shows two items in the past from two different calendars, but only once.
                                        And it seems to be the missing ones are private ics from google calendar. This occurred just right after the new update. I tried ever changing the private url in google and even reinstalling MagicMirror with no luck.
                                          sdetweil @luisestrada
                                          @luisestrada Ext3 gets entries broadcast from the default calendar.
                                          there was a change(me), that may have caused entry truncation, if you have maximumEntries set in any calendar entry
                                          • luisestradaL
                                            @sdetweil it may sound funny but now, I see all the future events but the ones that already passed, disappeared.
                                            and just in case:
                                            S luisestradaL 2 Replies Last reply Reply Quote 0
                                            • 34
                                            • 35
                                            • 3 / 35
