    Update fail
    28 Posts 4 Posters 12.8k Views 4 Watching
    • JerryPJ
      JerryP @JerryP
      @JerryP
      so where must I force it
        sdetweil @JerryP
        @JerryP add the word
        force
        to the end of the
        curl…
        statement
        just like the example using apply
        JerryPJ 1 Reply Last reply
        • JerryPJ
          JerryP @sdetweil
          @sdetweil said in Update fail:
          force
          to the end of the
          curl…
          statement
          Yes Yes Yes that is the trick…
          Now al modules are working.
          Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.
            sdetweil @JerryP
            @JerryP Ctrl- on keyboard to zoom out
            • JerryPJ
              JerryP @sdetweil
              @sdetweil said in
              That’s oke now. Ctrl- on keyboard to zoom out
              But look the camera postion.
              Normal it was lower
              		module: "MMM-RTSPStream",
              		disabled: false, //false, true
              		position: "upper_third",  // "middle_center" "upper_third"
              			autoStart: true,
              			rotateStreams: false,
              			rotateStreamTimeout: 20,
              			moduleWidth: 720,
              			moduleHeight: 420,
              			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
              			remotePlayer: 'none',
              			showSnapWhenPaused: false,
              			remoteSnaps: false,
              			  stream1: {***************
              I put in the upper_third… But when I put in the middel_center i’ts at the bottom.
              So how can I lower the 4 camera feeds???
              Than the mirror is 100% back again.
              Thanks for the help so fare
                sdetweil @JerryP
                @JerryP I don’t know for sure, did u have a custom.css that moved the position?
                JerryPJ 3 Replies Last reply
                • JerryPJ
                  JerryP @sdetweil
                  MMM-RTSPStream .innerWrapper {
                      border-style: none;
                  .MMM-SystemStats table {
                          width: 350px;
                          color: #666;
                          font-size: 20px;
                  .MMM-SystemStats td {
                      line-height: 20px;
                  .MMM-clock table {
                          width: 450px;
                          color: #666;
                          font-size: 20px;
                  .MMM-MercedesMe #mercedesMain {
                          zoom: 0.4;
                  .MMM-Formula1 .module-header {
                  display:none !important;
                  .MMM-MercedesMe .module-header {
                  .MMM-NetworkScanner .module-header {
                  .MMM-VolvoOnCall .module-header {
                  .MMM-Spotify .SPOTIFY_BACKGROUND {
                  border-style: none;
                   zoom: 80%;
                  .MMM-MyVolvo .VOC .graphic {
                          width: 50%;
                          margin-right: 1px;
                          margin-left: 10px;
                          margin-top:  -4px;
                          float: right;
                  Yes but not for the RTSP-stream
                  • JerryPJ
                    JerryP @sdetweil
                    in your script (new mirror setup)
                    makes the scrip a new config.js.
                    In that files stands
                    locale: "en-US",
                    Where can I find the info for Netherland???
                      sdetweil @JerryP
                      @JerryP I just copy the config.js.sample
                      but language/locale codes are public
                      https://www.science.co.il/language/Locale-codes.php
                      • JerryPJ
                        JerryP @sdetweil
                        yes “nl-nl” that’s a check
                        • JerryPJ
                          JerryP @sdetweil
                          Yes see the custom.css above
                          • T
                            torte22
                            after updating my MM installation I had also an electron problem and MM didn’t start. This topic works for my fine and fixed my installation:
                            https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
