    Update fail
    28 Posts 4 Posters 12.0k Views 4 Watching
    • JerryPJ Offline
      JerryP @sdetweil
      @sdetweil said in Update fail:
      @JerryP black screen see
      if you had run the upgrade script from the old version, then I would have fixed these for you
      So that was not the fix.
      I’ts not the black screen that makes the problemen. It.s hangingang on the electron… I think
        sdetweil @JerryP
        @JerryP the two modules failing are because of the black screen issue.
        JerryPJ 1 Reply Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @sdetweil
          pi@raspberrypi:~/MagicMirror/modules $ grep -r -E '('request') | ('valid-url')' ~/MagicMirror/modules/*/*.js
          /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:const request = require('request');
          /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:   * Handles the auth request endpoint, should be call by clicking on authenticate link
          /home/pi/MagicMirror/modules/MMM-MercedesMe/OAuth.js:const request = require('request');
          /home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:          console.log("Got request to stop", appName," with pid: ", pid);
          /home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:          console.error(this.logMessage, "Failed to request API:", api)
          /home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js:var request = require('request');
          SO MMM-screencast is working and MMM-Spotify is working.
          • AssassinsA Offline
            Assassins
            this great scripts from @sdetweil work :
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
            Thanks alot @sdetweil
            • JerryPJ Offline
              JerryP @Assassins
              @Assassins said in Update fail:
              is not working
              • JerryPJ Offline
                JerryP @JerryP
                @JerryP
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                So this one is working. But the problem is still the same…
                  sdetweil @JerryP
                  @JerryP the ‘fix’ is to install the request library in EACH module that uses it
                    sdetweil @JerryP
                    @JerryP also for upgrade you have to add
                    apply
                    to actually DO the upgrade
                    and if u already did the upgrade, but want to redo, then you have to add
                    force
                    • JerryPJ Offline
                      JerryP @sdetweil
                      checking for modules with removed libraries
                       require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                      	  bypass installing request for module MMM-SystemStats , doing test run
                       require for request in module MMM-MercedesMe not found in package.json package.json for module MMM-MercedesMe
                      	  bypass installing request for module MMM-MercedesMe , doing test run
                      • JerryPJ Offline
                        JerryP @JerryP
                        @JerryP
                        so where must I force it
                          sdetweil @JerryP
                          @JerryP add the word
                          force
                          to the end of the
                          curl…
                          statement
                          just like the example using apply
                          • JerryPJ Offline
                            JerryP @sdetweil
                            force
                            to the end of the
                            curl…
                            statement
                            Yes Yes Yes that is the trick…
                            Now al modules are working.
                            Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.
                              sdetweil @JerryP
                              @JerryP Ctrl- on keyboard to zoom out
                              • JerryPJ Offline
                                JerryP @sdetweil
                                @sdetweil said in
                                That’s oke now. Ctrl- on keyboard to zoom out
                                But look the camera postion.
                                Normal it was lower
                                		module: "MMM-RTSPStream",
                                		disabled: false, //false, true
                                		position: "upper_third",  // "middle_center" "upper_third"
                                			autoStart: true,
                                			rotateStreams: false,
                                			rotateStreamTimeout: 20,
                                			moduleWidth: 720,
                                			moduleHeight: 420,
                                			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                                			remotePlayer: 'none',
                                			showSnapWhenPaused: false,
                                			remoteSnaps: false,
                                			  stream1: {***************
                                I put in the upper_third… But when I put in the middel_center i’ts at the bottom.
                                So how can I lower the 4 camera feeds???
                                Than the mirror is 100% back again.
                                Thanks for the help so fare
                                  sdetweil @JerryP
                                  @JerryP I don’t know for sure, did u have a custom.css that moved the position?
                                  JerryPJ 3 Replies Last reply Reply Quote 0
                                  • JerryPJ Offline
                                    JerryP @sdetweil
                                    MMM-RTSPStream .innerWrapper {
                                        border-style: none;
                                    .MMM-SystemStats table {
                                            width: 350px;
                                            color: #666;
                                            font-size: 20px;
                                    .MMM-SystemStats td {
                                        line-height: 20px;
                                    .MMM-clock table {
                                            width: 450px;
                                            color: #666;
                                            font-size: 20px;
                                    .MMM-MercedesMe #mercedesMain {
                                            zoom: 0.4;
                                    .MMM-Formula1 .module-header {
                                    display:none !important;
                                    .MMM-MercedesMe .module-header {
                                    .MMM-NetworkScanner .module-header {
                                    .MMM-VolvoOnCall .module-header {
                                    .MMM-Spotify .SPOTIFY_BACKGROUND {
                                    border-style: none;
                                     zoom: 80%;
                                    .MMM-MyVolvo .VOC .graphic {
                                            width: 50%;
                                            margin-right: 1px;
                                            margin-left: 10px;
                                            margin-top:  -4px;
                                            float: right;
                                    Yes but not for the RTSP-stream
                                    • JerryPJ Offline
                                      JerryP @sdetweil
                                      in your script (new mirror setup)
                                      makes the scrip a new config.js.
                                      In that files stands
                                      locale: "en-US",
                                      Where can I find the info for Netherland???
                                        sdetweil @JerryP
                                        @JerryP I just copy the config.js.sample
                                        but language/locale codes are public
                                        https://www.science.co.il/language/Locale-codes.php
                                        • JerryPJ Offline
                                          JerryP @sdetweil
                                          yes “nl-nl” that’s a check
                                          • JerryPJ Offline
                                            JerryP @sdetweil
                                            Yes see the custom.css above
