    Update fail
    28 Posts 4 Posters 13.0k Views 4 Watching
      sdetweil @JerryP
      @JerryP and try my script?
      JerryPJ 2 Replies Last reply
      • JerryPJ
        JerryP @sdetweil
        No Not yet.
        • JerryPJ
          JerryP @sdetweil
          @sdetweil said in Update fail:
          Yesterday I have made a new install whit your script.
          After that i’ts was running fine (Standard module)
          https://github.com/sdetweil/MagicMirror_scripts (That was good)
          When I’m trying to put my own module back whit al git clone and install I run in to trouble.
          • https://github.com/skuethe/MMM-Spotify (check)
          • https://github.com/mazim-co/MMM-MyVolvo (Check)
          • https://github.com/ianperrin/MMM-NetworkScanner (Check)
          • https://github.com/darickc/MMM-BackgroundSlideshow (Check)
          • https://github.com/shbatm/MMM-RTSPStream (Check)
          • https://github.com/ianperrin/MMM-Formula1 (Check)
          • https://github.com/BenRoe/MMM-SystemStats (Trouble black screen)
          • https://github.com/ashishtank/MMM-MercedesMe (Trouble black screen)
          			module: "MMM-MercedesMe",
          			position: "bottom_right",
          				client_id: '************',
          				client_secret: '************',
          				vehicleType: 'Electric',
          				vehicleId: 'WDD**************',
          				displayStyle: 'singledial',  //# twodial & singledial
          				//updateInterval: 300000, // 10 Minutes,
          				maxRange: 175,
          				debug: false,
          				logsInFile: false,
          		module: 'MMM-SystemStats',
          		position: 'top_center',
          			updateInterval: 10000, // every 10 seconds
          			align: 'right', // align labels
          			units: 'metric', // default, metric, imperial
          			view: 'textAndIcon',
          And the total mirror is look like i’ts zoom-in for 20% or something.
          So that’s the status for now. Its running on 75% hahahah (Smile)
            sdetweil @JerryP
            @JerryP black screen see
            if you had run the upgrade script from the old version, then I would have fixed these for you
            JerryPJ 1 Reply Last reply
            • JerryPJ
              JerryP @sdetweil
              So that was not the fix.
              I’ts not the black screen that makes the problemen. It.s hangingang on the electron… I think
                sdetweil @JerryP
                @JerryP the two modules failing are because of the black screen issue.
                • JerryPJ
                  JerryP @sdetweil
                  pi@raspberrypi:~/MagicMirror/modules $ grep -r -E '('request') | ('valid-url')' ~/MagicMirror/modules/*/*.js
                  /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:const request = require('request');
                  /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:   * Handles the auth request endpoint, should be call by clicking on authenticate link
                  /home/pi/MagicMirror/modules/MMM-MercedesMe/OAuth.js:const request = require('request');
                  /home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:          console.log("Got request to stop", appName," with pid: ", pid);
                  /home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:          console.error(this.logMessage, "Failed to request API:", api)
                  /home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js:var request = require('request');
                  SO MMM-screencast is working and MMM-Spotify is working.
                  • AssassinsA
                    Assassins
                    this great scripts from @sdetweil work :
                    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                    Thanks alot @sdetweil
                    • JerryPJ
                      JerryP @Assassins
                      @Assassins said in Update fail:
                      is not working
                      • JerryPJ
                        JerryP @JerryP
                        @JerryP
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                        So this one is working. But the problem is still the same…
                          sdetweil @JerryP
                          @JerryP the ‘fix’ is to install the request library in EACH module that uses it
                            sdetweil @JerryP
                            @JerryP also for upgrade you have to add
                            apply
                            to actually DO the upgrade
                            and if u already did the upgrade, but want to redo, then you have to add
                            force
                            • JerryPJ
                              JerryP @sdetweil
                              checking for modules with removed libraries
                               require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                              	  bypass installing request for module MMM-SystemStats , doing test run
                               require for request in module MMM-MercedesMe not found in package.json package.json for module MMM-MercedesMe
                              	  bypass installing request for module MMM-MercedesMe , doing test run
                              • JerryPJ
                                JerryP @JerryP
                                @JerryP
                                so where must I force it
                                  sdetweil @JerryP
                                  @JerryP add the word
                                  force
                                  to the end of the
                                  curl…
                                  statement
                                  just like the example using apply
                                  • JerryPJ
                                    JerryP @sdetweil
                                    force
                                    to the end of the
                                    curl…
                                    statement
                                    Yes Yes Yes that is the trick…
                                    Now al modules are working.
                                    Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.
                                      sdetweil @JerryP
                                      @JerryP Ctrl- on keyboard to zoom out
                                      • JerryPJ
                                        JerryP @sdetweil
                                        @sdetweil said in
                                        That’s oke now. Ctrl- on keyboard to zoom out
                                        But look the camera postion.
                                        Normal it was lower
                                        		module: "MMM-RTSPStream",
                                        		disabled: false, //false, true
                                        		position: "upper_third",  // "middle_center" "upper_third"
                                        			autoStart: true,
                                        			rotateStreams: false,
                                        			rotateStreamTimeout: 20,
                                        			moduleWidth: 720,
                                        			moduleHeight: 420,
                                        			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                                        			remotePlayer: 'none',
                                        			showSnapWhenPaused: false,
                                        			remoteSnaps: false,
                                        			  stream1: {***************
                                        I put in the upper_third… But when I put in the middel_center i’ts at the bottom.
                                        So how can I lower the 4 camera feeds???
                                        Than the mirror is 100% back again.
                                        Thanks for the help so fare
                                          sdetweil @JerryP
                                          @JerryP I don’t know for sure, did u have a custom.css that moved the position?
                                          JerryPJ 3 Replies Last reply
                                          • JerryPJ
                                            JerryP @sdetweil
                                            MMM-RTSPStream .innerWrapper {
                                                border-style: none;
                                            .MMM-SystemStats table {
                                                    width: 350px;
                                                    color: #666;
                                                    font-size: 20px;
                                            .MMM-SystemStats td {
                                                line-height: 20px;
                                            .MMM-clock table {
                                                    width: 450px;
                                                    color: #666;
                                                    font-size: 20px;
                                            .MMM-MercedesMe #mercedesMain {
                                                    zoom: 0.4;
                                            .MMM-Formula1 .module-header {
                                            display:none !important;
                                            .MMM-MercedesMe .module-header {
                                            .MMM-NetworkScanner .module-header {
                                            .MMM-VolvoOnCall .module-header {
                                            .MMM-Spotify .SPOTIFY_BACKGROUND {
                                            border-style: none;
                                             zoom: 80%;
                                            .MMM-MyVolvo .VOC .graphic {
                                                    width: 50%;
                                                    margin-right: 1px;
                                                    margin-left: 10px;
                                                    margin-top:  -4px;
                                                    float: right;
                                            Yes but not for the RTSP-stream
