    Update fail
    28 Posts 4 Posters 11.6k Views 4 Watching
    • JerryPJ Offline
      JerryP
      please Help.
      I just run the update tot V.2.20
      but now the mirror is brokken
      pi@raspberrypi:~ $ pm2 logs mm
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      4|mm       | [03.07.2022 22:23.06.022] [LOG]   Starting MagicMirror: v2.20.0
      4|mm       | [03.07.2022 22:23.06.033] [LOG]   Loading config ...
      4|mm       | [03.07.2022 22:23.06.043] [LOG]   Loading module helpers ...
      4|mm       | [03.07.2022 22:23.06.048] [LOG]   No helper found for module: alert.
      4|mm       | [03.07.2022 22:23.06.067] [LOG]   Initializing new module helper ...
      4|mm       | [03.07.2022 22:23.06.070] [LOG]   Module helper loaded: updatenotification
      4|mm       | [03.07.2022 22:23.06.160] [LOG]   Initializing new module helper ...
      4|mm       | [03.07.2022 22:23.06.161] [LOG]   Module helper loaded: MMM-Spotify
      4|mm       | [03.07.2022 22:23.06.168] [LOG]   Loading module helpers ...
      4|mm       | [03.07.2022 22:23.06.169] [LOG]   No helper found for module: alert.
      4|mm       | [03.07.2022 22:23.06.170] [LOG]   Initializing new module helper ...
      4|mm       | [03.07.2022 22:23.06.171] [LOG]   Module helper loaded: updatenotification
      4|mm       | [03.07.2022 22:23.06.172] [LOG]   Initializing new module helper ...
      4|mm       | [03.07.2022 22:23.06.173] [LOG]   Module helper loaded: MMM-Spotify
      4|mm       | [03.07.2022 22:23.06.483] [LOG]   Launching application.
      4|mm       |     '/home/pi/MagicMirror/js/electron.js',
      4|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      4|mm       |     undefined
      4|mm       |   ]
      4|mm       | }
      4|mm       | [03.07.2022 22:23.06.186] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      4|mm       | [03.07.2022 22:23.06.187] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      4|mm       | MESA-LOADER: failed to retrieve device information
      4|mm       | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      4|mm       | failed to load driver: kms_swrast
      4|mm       | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      4|mm       | failed to load swrast driver
      4|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      What’s going wrong???
      • T Offline
        torte22
        after updating my MM installation I had also an electron problem and MM didn’t start. This topic works for my fine and fixed my installation:
        https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
          sdetweil @JerryP
          @JerryP how did u do the update?
          JerryPJ 1 Reply Last reply Reply Quote 0
          • JerryPJ Offline
            JerryP @sdetweil
            Goodmorning
            I run the
            git pull && npm install --only=prod --omit=dev
            And i remana the MAP and than
            git clone https://github.com/MichMich/MagicMirror
            cd MagicMirror/
            Same result alt the end…
              sdetweil @JerryP
              @JerryP and try my script?
              JerryPJ 2 Replies Last reply Reply Quote 0
              • JerryPJ Offline
                JerryP @sdetweil
                No Not yet.
                • JerryPJ Offline
                  JerryP @sdetweil
                  @sdetweil said in Update fail:
                  Yesterday I have made a new install whit your script.
                  After that i’ts was running fine (Standard module)
                  https://github.com/sdetweil/MagicMirror_scripts (That was good)
                  When I’m trying to put my own module back whit al git clone and install I run in to trouble.
                  • https://github.com/skuethe/MMM-Spotify (check)
                  • https://github.com/mazim-co/MMM-MyVolvo (Check)
                  • https://github.com/ianperrin/MMM-NetworkScanner (Check)
                  • https://github.com/darickc/MMM-BackgroundSlideshow (Check)
                  • https://github.com/shbatm/MMM-RTSPStream (Check)
                  • https://github.com/ianperrin/MMM-Formula1 (Check)
                  • https://github.com/BenRoe/MMM-SystemStats (Trouble black screen)
                  • https://github.com/ashishtank/MMM-MercedesMe (Trouble black screen)
                  			module: "MMM-MercedesMe",
                  			position: "bottom_right",
                  				client_id: '************',
                  				client_secret: '************',
                  				vehicleType: 'Electric',
                  				vehicleId: 'WDD**************',
                  				displayStyle: 'singledial',  //# twodial & singledial
                  				//updateInterval: 300000, // 10 Minutes,
                  				maxRange: 175,
                  				debug: false,
                  				logsInFile: false,
                  		module: 'MMM-SystemStats',
                  		position: 'top_center',
                  			updateInterval: 10000, // every 10 seconds
                  			align: 'right', // align labels
                  			units: 'metric', // default, metric, imperial
                  			view: 'textAndIcon',
                  And the total mirror is look like i’ts zoom-in for 20% or something.
                  So that’s the status for now. Its running on 75% hahahah (Smile)
                    sdetweil @JerryP
                    @JerryP black screen see
                    if you had run the upgrade script from the old version, then I would have fixed these for you
                    • JerryPJ Offline
                      JerryP @sdetweil
                      So that was not the fix.
                      I’ts not the black screen that makes the problemen. It.s hangingang on the electron… I think
                        sdetweil @JerryP
                        @JerryP the two modules failing are because of the black screen issue.
                        • JerryPJ Offline
                          JerryP @sdetweil
                          pi@raspberrypi:~/MagicMirror/modules $ grep -r -E '('request') | ('valid-url')' ~/MagicMirror/modules/*/*.js
                          /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:const request = require('request');
                          /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:   * Handles the auth request endpoint, should be call by clicking on authenticate link
                          /home/pi/MagicMirror/modules/MMM-MercedesMe/OAuth.js:const request = require('request');
                          /home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:          console.log("Got request to stop", appName," with pid: ", pid);
                          /home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:          console.error(this.logMessage, "Failed to request API:", api)
                          /home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js:var request = require('request');
                          SO MMM-screencast is working and MMM-Spotify is working.
                          • AssassinsA Offline
                            Assassins
                            this great scripts from @sdetweil work :
                            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                            Thanks alot @sdetweil
                            • JerryPJ Offline
                              JerryP @Assassins
                              @Assassins said in Update fail:
                              is not working
                              • JerryPJ Offline
                                JerryP @JerryP
                                @JerryP
                                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                So this one is working. But the problem is still the same…
                                  sdetweil @JerryP
                                  @JerryP the ‘fix’ is to install the request library in EACH module that uses it
                                    sdetweil @JerryP
                                    @JerryP also for upgrade you have to add
                                    apply
                                    to actually DO the upgrade
                                    and if u already did the upgrade, but want to redo, then you have to add
                                    force
                                    • JerryPJ Offline
                                      JerryP @sdetweil
                                      checking for modules with removed libraries
                                       require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                                      	  bypass installing request for module MMM-SystemStats , doing test run
                                       require for request in module MMM-MercedesMe not found in package.json package.json for module MMM-MercedesMe
                                      	  bypass installing request for module MMM-MercedesMe , doing test run
                                      • JerryPJ Offline
                                        JerryP @JerryP
                                        @JerryP
                                        so where must I force it
                                          sdetweil @JerryP
                                          @JerryP add the word
                                          force
                                          to the end of the
                                          curl…
                                          statement
                                          just like the example using apply
                                          • JerryPJ Offline
                                            JerryP @sdetweil
                                            force
                                            to the end of the
                                            curl…
                                            statement
                                            Yes Yes Yes that is the trick…
                                            Now al modules are working.
                                            Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.
                                              sdetweil @JerryP
                                              @JerryP Ctrl- on keyboard to zoom out
