    Update fail
    28 Posts 4 Posters 12.8k Views 4 Watching
    • JerryPJ
      JerryP @sdetweil
      No Not yet.
      • JerryPJ
        JerryP @sdetweil
        @sdetweil said in Update fail:
        @JerryP and try my script?
        Yesterday I have made a new install whit your script.
        After that i’ts was running fine (Standard module)
        https://github.com/sdetweil/MagicMirror_scripts (That was good)
        When I’m trying to put my own module back whit al git clone and install I run in to trouble.
        • https://github.com/skuethe/MMM-Spotify (check)
        • https://github.com/mazim-co/MMM-MyVolvo (Check)
        • https://github.com/ianperrin/MMM-NetworkScanner (Check)
        • https://github.com/darickc/MMM-BackgroundSlideshow (Check)
        • https://github.com/shbatm/MMM-RTSPStream (Check)
        • https://github.com/ianperrin/MMM-Formula1 (Check)
        • https://github.com/BenRoe/MMM-SystemStats (Trouble black screen)
        • https://github.com/ashishtank/MMM-MercedesMe (Trouble black screen)
        			module: "MMM-MercedesMe",
        			position: "bottom_right",
        				client_id: '************',
        				client_secret: '************',
        				vehicleType: 'Electric',
        				vehicleId: 'WDD**************',
        				displayStyle: 'singledial',  //# twodial & singledial
        				//updateInterval: 300000, // 10 Minutes,
        				maxRange: 175,
        				debug: false,
        				logsInFile: false,
        		module: 'MMM-SystemStats',
        		position: 'top_center',
        			updateInterval: 10000, // every 10 seconds
        			align: 'right', // align labels
        			units: 'metric', // default, metric, imperial
        			view: 'textAndIcon',
        And the total mirror is look like i’ts zoom-in for 20% or something.
        So that’s the status for now. Its running on 75% hahahah (Smile)
          sdetweil @JerryP
          @JerryP black screen see
          if you had run the upgrade script from the old version, then I would have fixed these for you
          JerryPJ 1 Reply Last reply
          • JerryPJ
            JerryP @sdetweil
            So that was not the fix.
            I’ts not the black screen that makes the problemen. It.s hangingang on the electron… I think
              sdetweil @JerryP
              @JerryP the two modules failing are because of the black screen issue.
              • JerryPJ
                JerryP @sdetweil
                pi@raspberrypi:~/MagicMirror/modules $ grep -r -E '('request') | ('valid-url')' ~/MagicMirror/modules/*/*.js
                /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:const request = require('request');
                /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:   * Handles the auth request endpoint, should be call by clicking on authenticate link
                /home/pi/MagicMirror/modules/MMM-MercedesMe/OAuth.js:const request = require('request');
                /home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:          console.log("Got request to stop", appName," with pid: ", pid);
                /home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:          console.error(this.logMessage, "Failed to request API:", api)
                /home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js:var request = require('request');
                SO MMM-screencast is working and MMM-Spotify is working.
                • AssassinsA
                  Assassins
                  this great scripts from @sdetweil work :
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                  Thanks alot @sdetweil
                  • JerryPJ
                    JerryP @Assassins
                    @Assassins said in Update fail:
                    is not working
                    • JerryPJ
                      JerryP @JerryP
                      @JerryP
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                      So this one is working. But the problem is still the same…
                        sdetweil @JerryP
                        @JerryP the ‘fix’ is to install the request library in EACH module that uses it
                          sdetweil @JerryP
                          @JerryP also for upgrade you have to add
                          apply
                          to actually DO the upgrade
                          and if u already did the upgrade, but want to redo, then you have to add
                          force
                          • JerryPJ
                            JerryP @sdetweil
                            checking for modules with removed libraries
                             require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                            	  bypass installing request for module MMM-SystemStats , doing test run
                             require for request in module MMM-MercedesMe not found in package.json package.json for module MMM-MercedesMe
                            	  bypass installing request for module MMM-MercedesMe , doing test run
                            • JerryPJ
                              JerryP @JerryP
                              @JerryP
                              so where must I force it
                                sdetweil @JerryP
                                @JerryP add the word
                                force
                                to the end of the
                                curl…
                                statement
                                just like the example using apply
                                • JerryPJ
                                  JerryP @sdetweil
                                  force
                                  to the end of the
                                  curl…
                                  statement
                                  Yes Yes Yes that is the trick…
                                  Now al modules are working.
                                  Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.
                                    sdetweil @JerryP
                                    @JerryP Ctrl- on keyboard to zoom out
                                    • JerryPJ
                                      JerryP @sdetweil
                                      @sdetweil said in
                                      That’s oke now. Ctrl- on keyboard to zoom out
                                      But look the camera postion.
                                      Normal it was lower
                                      		module: "MMM-RTSPStream",
                                      		disabled: false, //false, true
                                      		position: "upper_third",  // "middle_center" "upper_third"
                                      			autoStart: true,
                                      			rotateStreams: false,
                                      			rotateStreamTimeout: 20,
                                      			moduleWidth: 720,
                                      			moduleHeight: 420,
                                      			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                                      			remotePlayer: 'none',
                                      			showSnapWhenPaused: false,
                                      			remoteSnaps: false,
                                      			  stream1: {***************
                                      I put in the upper_third… But when I put in the middel_center i’ts at the bottom.
                                      So how can I lower the 4 camera feeds???
                                      Than the mirror is 100% back again.
                                      Thanks for the help so fare
                                        sdetweil @JerryP
                                        @JerryP I don’t know for sure, did u have a custom.css that moved the position?
                                        JerryPJ 3 Replies Last reply
                                        • JerryPJ
                                          JerryP @sdetweil
                                          MMM-RTSPStream .innerWrapper {
                                              border-style: none;
                                          .MMM-SystemStats table {
                                                  width: 350px;
                                                  color: #666;
                                                  font-size: 20px;
                                          .MMM-SystemStats td {
                                              line-height: 20px;
                                          .MMM-clock table {
                                                  width: 450px;
                                                  color: #666;
                                                  font-size: 20px;
                                          .MMM-MercedesMe #mercedesMain {
                                                  zoom: 0.4;
                                          .MMM-Formula1 .module-header {
                                          display:none !important;
                                          .MMM-MercedesMe .module-header {
                                          .MMM-NetworkScanner .module-header {
                                          .MMM-VolvoOnCall .module-header {
                                          .MMM-Spotify .SPOTIFY_BACKGROUND {
                                          border-style: none;
                                           zoom: 80%;
                                          .MMM-MyVolvo .VOC .graphic {
                                                  width: 50%;
                                                  margin-right: 1px;
                                                  margin-left: 10px;
                                                  margin-top:  -4px;
                                                  float: right;
                                          Yes but not for the RTSP-stream
                                          • JerryPJ
                                            JerryP @sdetweil
                                            in your script (new mirror setup)
                                            makes the scrip a new config.js.
                                            In that files stands
                                            locale: "en-US",
                                            Where can I find the info for Netherland???
