    Update fail
    28 Posts 4 Posters 12.8k Views 4 Watching
    • AssassinsA
      Assassins
      this great scripts from @sdetweil work :
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
      Thanks alot @sdetweil
      JerryPJ 1 Reply Last reply
      • JerryPJ
        JerryP @Assassins
        @Assassins said in Update fail:
        is not working
        • JerryPJ
          JerryP @JerryP
          @JerryP
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
          So this one is working. But the problem is still the same…
            sdetweil @JerryP
            @JerryP the ‘fix’ is to install the request library in EACH module that uses it
              sdetweil @JerryP
              @JerryP also for upgrade you have to add
              apply
              to actually DO the upgrade
              and if u already did the upgrade, but want to redo, then you have to add
              force
              • JerryPJ
                JerryP @sdetweil
                checking for modules with removed libraries
                 require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                	  bypass installing request for module MMM-SystemStats , doing test run
                 require for request in module MMM-MercedesMe not found in package.json package.json for module MMM-MercedesMe
                	  bypass installing request for module MMM-MercedesMe , doing test run
                • JerryPJ
                  JerryP @JerryP
                  @JerryP
                  so where must I force it
                    sdetweil @JerryP
                    @JerryP add the word
                    force
                    to the end of the
                    curl…
                    statement
                    just like the example using apply
                    • JerryPJ
                      JerryP @sdetweil
                      @sdetweil said in Update fail:
                      force
                      to the end of the
                      curl…
                      statement
                      Yes Yes Yes that is the trick…
                      Now al modules are working.
                      Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.
                        sdetweil @JerryP
                        @JerryP Ctrl- on keyboard to zoom out
                        • JerryPJ
                          JerryP @sdetweil
                          @sdetweil said in
                          That’s oke now. Ctrl- on keyboard to zoom out
                          But look the camera postion.
                          Normal it was lower
                          		module: "MMM-RTSPStream",
                          		disabled: false, //false, true
                          		position: "upper_third",  // "middle_center" "upper_third"
                          			autoStart: true,
                          			rotateStreams: false,
                          			rotateStreamTimeout: 20,
                          			moduleWidth: 720,
                          			moduleHeight: 420,
                          			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                          			remotePlayer: 'none',
                          			showSnapWhenPaused: false,
                          			remoteSnaps: false,
                          			  stream1: {***************
                          I put in the upper_third… But when I put in the middel_center i’ts at the bottom.
                          So how can I lower the 4 camera feeds???
                          Than the mirror is 100% back again.
                          Thanks for the help so fare
                            sdetweil @JerryP
                            @JerryP I don’t know for sure, did u have a custom.css that moved the position?
                            JerryPJ 3 Replies Last reply
                            • JerryPJ
                              JerryP @sdetweil
                              MMM-RTSPStream .innerWrapper {
                                  border-style: none;
                              .MMM-SystemStats table {
                                      width: 350px;
                                      color: #666;
                                      font-size: 20px;
                              .MMM-SystemStats td {
                                  line-height: 20px;
                              .MMM-clock table {
                                      width: 450px;
                                      color: #666;
                                      font-size: 20px;
                              .MMM-MercedesMe #mercedesMain {
                                      zoom: 0.4;
                              .MMM-Formula1 .module-header {
                              display:none !important;
                              .MMM-MercedesMe .module-header {
                              .MMM-NetworkScanner .module-header {
                              .MMM-VolvoOnCall .module-header {
                              .MMM-Spotify .SPOTIFY_BACKGROUND {
                              border-style: none;
                               zoom: 80%;
                              .MMM-MyVolvo .VOC .graphic {
                                      width: 50%;
                                      margin-right: 1px;
                                      margin-left: 10px;
                                      margin-top:  -4px;
                                      float: right;
                              Yes but not for the RTSP-stream
                              • JerryPJ
                                JerryP @sdetweil
                                in your script (new mirror setup)
                                makes the scrip a new config.js.
                                In that files stands
                                locale: "en-US",
                                Where can I find the info for Netherland???
                                  sdetweil @JerryP
                                  @JerryP I just copy the config.js.sample
                                  but language/locale codes are public
                                  https://www.science.co.il/language/Locale-codes.php
                                  • JerryPJ
                                    JerryP @sdetweil
                                    yes “nl-nl” that’s a check
                                    • JerryPJ
                                      JerryP @sdetweil
                                      Yes see the custom.css above
                                      • T
                                        torte22
                                        after updating my MM installation I had also an electron problem and MM didn’t start. This topic works for my fine and fixed my installation:
                                        https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
