    Update fail
    28 Posts 4 Posters 12.8k Views 4 Watching
      sdetweil @JerryP
      @JerryP the two modules failing are because of the black screen issue.
      JerryPJ 1 Reply Last reply
      • JerryPJ
        JerryP @sdetweil
        @sdetweil said in Update fail:
        pi@raspberrypi:~/MagicMirror/modules $ grep -r -E '('request') | ('valid-url')' ~/MagicMirror/modules/*/*.js
        /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:const request = require('request');
        /home/pi/MagicMirror/modules/MMM-MercedesMe/node_helper.js:   * Handles the auth request endpoint, should be call by clicking on authenticate link
        /home/pi/MagicMirror/modules/MMM-MercedesMe/OAuth.js:const request = require('request');
        /home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:          console.log("Got request to stop", appName," with pid: ", pid);
        /home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:          console.error(this.logMessage, "Failed to request API:", api)
        /home/pi/MagicMirror/modules/MMM-SystemStats/node_helper.js:var request = require('request');
        SO MMM-screencast is working and MMM-Spotify is working.
        • AssassinsA
          Assassins
          this great scripts from @sdetweil work :
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
          Thanks alot @sdetweil
          • JerryPJ
            JerryP @Assassins
            @Assassins said in Update fail:
            is not working
            • JerryPJ
              JerryP @JerryP
              @JerryP
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              So this one is working. But the problem is still the same…
                sdetweil @JerryP
                @JerryP the ‘fix’ is to install the request library in EACH module that uses it
                  sdetweil @JerryP
                  @JerryP also for upgrade you have to add
                  apply
                  to actually DO the upgrade
                  and if u already did the upgrade, but want to redo, then you have to add
                  force
                  • JerryPJ
                    JerryP @sdetweil
                    checking for modules with removed libraries
                     require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                    	  bypass installing request for module MMM-SystemStats , doing test run
                     require for request in module MMM-MercedesMe not found in package.json package.json for module MMM-MercedesMe
                    	  bypass installing request for module MMM-MercedesMe , doing test run
                    • JerryPJ
                      JerryP @JerryP
                      @JerryP
                      so where must I force it
                        sdetweil @JerryP
                        @JerryP add the word
                        force
                        to the end of the
                        curl…
                        statement
                        just like the example using apply
                        • JerryPJ
                          JerryP @sdetweil
                          force
                          to the end of the
                          curl…
                          statement
                          Yes Yes Yes that is the trick…
                          Now al modules are working.
                          Butttttt now the mirror is stil look like it’s zoomed. All module ar looking resized 110% bigger. And drop over each other.
                            sdetweil @JerryP
                            @JerryP Ctrl- on keyboard to zoom out
                            • JerryPJ
                              JerryP @sdetweil
                              @sdetweil said in
                              That’s oke now. Ctrl- on keyboard to zoom out
                              But look the camera postion.
                              Normal it was lower
                              		module: "MMM-RTSPStream",
                              		disabled: false, //false, true
                              		position: "upper_third",  // "middle_center" "upper_third"
                              			autoStart: true,
                              			rotateStreams: false,
                              			rotateStreamTimeout: 20,
                              			moduleWidth: 720,
                              			moduleHeight: 420,
                              			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
                              			remotePlayer: 'none',
                              			showSnapWhenPaused: false,
                              			remoteSnaps: false,
                              			  stream1: {***************
                              I put in the upper_third… But when I put in the middel_center i’ts at the bottom.
                              So how can I lower the 4 camera feeds???
                              Than the mirror is 100% back again.
                              Thanks for the help so fare
                                sdetweil @JerryP
                                @JerryP I don’t know for sure, did u have a custom.css that moved the position?
                                JerryPJ 3 Replies Last reply
                                • JerryPJ
                                  JerryP @sdetweil
                                  MMM-RTSPStream .innerWrapper {
                                      border-style: none;
                                  .MMM-SystemStats table {
                                          width: 350px;
                                          color: #666;
                                          font-size: 20px;
                                  .MMM-SystemStats td {
                                      line-height: 20px;
                                  .MMM-clock table {
                                          width: 450px;
                                          color: #666;
                                          font-size: 20px;
                                  .MMM-MercedesMe #mercedesMain {
                                          zoom: 0.4;
                                  .MMM-Formula1 .module-header {
                                  display:none !important;
                                  .MMM-MercedesMe .module-header {
                                  .MMM-NetworkScanner .module-header {
                                  .MMM-VolvoOnCall .module-header {
                                  .MMM-Spotify .SPOTIFY_BACKGROUND {
                                  border-style: none;
                                   zoom: 80%;
                                  .MMM-MyVolvo .VOC .graphic {
                                          width: 50%;
                                          margin-right: 1px;
                                          margin-left: 10px;
                                          margin-top:  -4px;
                                          float: right;
                                  Yes but not for the RTSP-stream
                                  • JerryPJ
                                    JerryP @sdetweil
                                    in your script (new mirror setup)
                                    makes the scrip a new config.js.
                                    In that files stands
                                    locale: "en-US",
                                    Where can I find the info for Netherland???
                                      sdetweil @JerryP
                                      @JerryP I just copy the config.js.sample
                                      but language/locale codes are public
                                      https://www.science.co.il/language/Locale-codes.php
                                      • JerryPJ
                                        JerryP @sdetweil
                                        yes “nl-nl” that’s a check
                                        • JerryPJ
                                          JerryP @sdetweil
                                          Yes see the custom.css above
                                          • T
                                            torte22
                                            after updating my MM installation I had also an electron problem and MM didn’t start. This topic works for my fine and fixed my installation:
                                            https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
