    pm2 errors
    8 Posts 3 Posters 1.6k Views 3 Watching
    • N6NGN
      N6NG
      Lets try try this again… I now see the calendar errors and can probably figure tose out but the pm2 is another story.
      1|mm | /tmp/start-dcfcac42.sh: 1: /tmp/start-dcfcac42.sh: ./node_modules/.bin/electron: not found
      1|mm | /tmp/start-1274b738.sh: 1: /tmp/start-1274b738.sh: ./node_modules/.bin/electron: not found
      1|mm | /tmp/start-c2007b47.sh: 1: /tmp/start-c2007b47.sh: ./node_modules/.bin/electron: not found
      1|mm | /tmp/start-32dcf27c.sh: 1: /tmp/start-32dcf27c.sh: ./node_modules/.bin/electron: not found
      1|mm | /tmp/start-132c9b31.sh: 1: /tmp/start-132c9b31.sh: ./node_modules/.bin/electron: not found
      1|mm | /tmp/start-11e3e2b7.sh: 1: /tmp/start-11e3e2b7.sh: ./node_modules/.bin/electron: not found
      1|mm | /tmp/start-54d113c7.sh: 1: /tmp/start-54d113c7.sh: ./node_modules/.bin/electron: not found
      1|mm | /tmp/start-8e8129ea.sh: 1: /tmp/start-8e8129ea.sh: ./node_modules/.bin/electron: not found
      /home/pi/.pm2/logs/MagicMirror-error.log last 30 lines:
      3|MagicMir | [13.08.2022 13:38.28.480] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics Error: Not Found
      3|MagicMir | at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
      3|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
      3|MagicMir | [13.08.2022 13:43.28.887] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics Error: Not Found
      3|MagicMir | [13.08.2022 13:48.29.118] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics Error: Not Found
      3|MagicMir | [13.08.2022 13:53.29.385] [ERR
        sdetweil @N6NG
        @N6NG I have no idea what u are looking at
        is MagicMirror installed in ~/MagicMirror
        like normal?
        if so, then
        pm2 stop all
        pm2 status
        take the number of the entry
        pm2 delete xx
        pm2 save force
        xx is the number
        then run the fixuppm2 script from my scripts
        last entry on the page
        B N6NGN 2 Replies Last reply
          bhepler Module Developer @sdetweil
          @sdetweil - At a guess, something went wrong during his installation that is preventing electron from loading. But the failed calls to Google for the calendar worry me. I suspect that he has two issues: failed installation and a Google calendar configuration error that is preventing Google from serving up his calendar.
          You gave good advice, getting the electron issue sorted. But I think @N6NG is still going to have calendar problems.
          • N6NGN
            N6NG @sdetweil
            I did the list as you said twice… With the same results. I think it will just be easier to start from scratch. What is the recommended O.S to load MM on now?
            Here is the result after I did the pm2 reset and you listed.
            1|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19)
            1|MagicMir | at require (node:internal/modules/cjs/helpers:102:18)
            1|MagicMir | at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
            1|MagicMir | at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
            1|MagicMir | [1143:0814/120009.873359:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            1|MagicMir | [1219:0814/120011.296500:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            1|MagicMir | [1246:0814/120011.766627:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
            1|MagicMir | [14.08.2022 12:00.20.655] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics Error: Not Found
            1|MagicMir | at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
            1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
            1|MagicMir | [14.08.2022 12:01.53.089] [WARN] You’re using a full whitelist configuration to allow for all IPs
            1|MagicMir | [14.08.2022 12:01.55.581] [ERROR] ERROR! Could not validate main module js file.
            1|MagicMir | [14.08.2022 12:01.55.596] [ERROR] ReferenceError: Log is not defined
            1|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:151216)
            1|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1118:14)
            1|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
            1|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32)
            1|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12)
            1|MagicMir | at c._load (node:electron/js2c/asar_bundle:5:13343)
            1|MagicMir | [2074:0814/120156.172072:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            1|MagicMir | [2166:0814/120200.161965:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            1|MagicMir | [2204:0814/120200.457971:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
            1|MagicMir | [14.08.2022 12:02.13.913] [WARN] You’re using a full whitelist configuration to allow for all IPs
            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
            1|MagicMir | [14.08.2022 12:02.00.537] [LOG] Shutting down server…
            1|MagicMir | [14.08.2022 12:02.00.552] [LOG] Stopping module helper: MMM-Wallpaper
            1|MagicMir | [14.08.2022 12:02.00.559] [LOG] Stopping module helper: MMM-3Day-Forecast
            S 2 Replies Last reply
              sdetweil @N6NG
              @N6NG said in pm2 errors:
              Module.require
              this indicates a down level version of npm
              please use use my script, it does everything.
              start from fresh SD card flash, cause I don’t know what you’ve got now, but it’s a mess
                sdetweil @N6NG
                either the latest 32 bit full desktop
                or if using video streams with MM, then the legacy 32 bit image
                N6NGN 1 Reply Last reply
                • N6NGN
                  N6NG @sdetweil
                  @sdetweil No 64?
                    sdetweil @N6NG
                    @N6NG no. not yet… too many issues
