    pm2 errors
    8 Posts 3 Posters 1.2k Views 3 Watching
    • N6NGN Offline
      N6NG @sdetweil
      I did the list as you said twice… With the same results. I think it will just be easier to start from scratch. What is the recommended O.S to load MM on now?
      Here is the result after I did the pm2 reset and you listed.
      1|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19)
      1|MagicMir | at require (node:internal/modules/cjs/helpers:102:18)
      1|MagicMir | at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
      1|MagicMir | at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
      1|MagicMir | [1143:0814/120009.873359:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      1|MagicMir | [1219:0814/120011.296500:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      1|MagicMir | [1246:0814/120011.766627:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      1|MagicMir | [14.08.2022 12:00.20.655] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics Error: Not Found
      1|MagicMir | at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
      1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
      1|MagicMir | [14.08.2022 12:01.53.089] [WARN] You’re using a full whitelist configuration to allow for all IPs
      1|MagicMir | [14.08.2022 12:01.55.581] [ERROR] ERROR! Could not validate main module js file.
      1|MagicMir | [14.08.2022 12:01.55.596] [ERROR] ReferenceError: Log is not defined
      1|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:151216)
      1|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1118:14)
      1|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
      1|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32)
      1|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12)
      1|MagicMir | at c._load (node:electron/js2c/asar_bundle:5:13343)
      1|MagicMir | [2074:0814/120156.172072:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      1|MagicMir | [2166:0814/120200.161965:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      1|MagicMir | [2204:0814/120200.457971:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      1|MagicMir | [14.08.2022 12:02.13.913] [WARN] You’re using a full whitelist configuration to allow for all IPs
      /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
      1|MagicMir | [14.08.2022 12:02.00.537] [LOG] Shutting down server…
      1|MagicMir | [14.08.2022 12:02.00.552] [LOG] Stopping module helper: MMM-Wallpaper
      1|MagicMir | [14.08.2022 12:02.00.559] [LOG] Stopping module helper: MMM-3Day-Forecast
        sdetweil @N6NG
        @N6NG said in pm2 errors:
        Module.require
        this indicates a down level version of npm
        please use use my script, it does everything.
        start from fresh SD card flash, cause I don’t know what you’ve got now, but it’s a mess
          sdetweil @N6NG
          either the latest 32 bit full desktop
          or if using video streams with MM, then the legacy 32 bit image
          N6NGN 1 Reply Last reply Reply Quote 0
          • N6NGN Offline
            N6NG @sdetweil
            @sdetweil No 64?
              sdetweil @N6NG
              @N6NG no. not yet… too many issues
