    pm2 errors
    8 Posts 3 Posters 1.1k Views 3 Watching
      sdetweil @N6NG
      @N6NG I have no idea what u are looking at
      is MagicMirror installed in ~/MagicMirror
      like normal?
      if so, then
      pm2 stop all
      pm2 status
      take the number of the entry
      pm2 delete xx
      pm2 save force
      xx is the number
      then run the fixuppm2 script from my scripts
      last entry on the page
      bheplerB N6NGN 2 Replies Last reply Reply Quote 0
      • bheplerB Offline
        bhepler Module Developer @sdetweil
        @sdetweil - At a guess, something went wrong during his installation that is preventing electron from loading. But the failed calls to Google for the calendar worry me. I suspect that he has two issues: failed installation and a Google calendar configuration error that is preventing Google from serving up his calendar.
        You gave good advice, getting the electron issue sorted. But I think @N6NG is still going to have calendar problems.
        • N6NGN Offline
          N6NG @sdetweil
          I did the list as you said twice… With the same results. I think it will just be easier to start from scratch. What is the recommended O.S to load MM on now?
          Here is the result after I did the pm2 reset and you listed.
          1|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19)
          1|MagicMir | at require (node:internal/modules/cjs/helpers:102:18)
          1|MagicMir | at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
          1|MagicMir | at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
          1|MagicMir | [1143:0814/120009.873359:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          1|MagicMir | [1219:0814/120011.296500:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          1|MagicMir | [1246:0814/120011.766627:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          1|MagicMir | [14.08.2022 12:00.20.655] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/n28eorb78g9osq8n9k5h689jmg%40group.calendar.google.com/private-046ced3569f15a4ed126f5bb09847134/basic.ics Error: Not Found
          1|MagicMir | at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
          1|MagicMir | at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
          1|MagicMir | [14.08.2022 12:01.53.089] [WARN] You’re using a full whitelist configuration to allow for all IPs
          1|MagicMir | [14.08.2022 12:01.55.581] [ERROR] ERROR! Could not validate main module js file.
          1|MagicMir | [14.08.2022 12:01.55.596] [ERROR] ReferenceError: Log is not defined
          1|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:151216)
          1|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1118:14)
          1|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
          1|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32)
          1|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12)
          1|MagicMir | at c._load (node:electron/js2c/asar_bundle:5:13343)
          1|MagicMir | [2074:0814/120156.172072:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          1|MagicMir | [2166:0814/120200.161965:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          1|MagicMir | [2204:0814/120200.457971:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          1|MagicMir | [14.08.2022 12:02.13.913] [WARN] You’re using a full whitelist configuration to allow for all IPs
          /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
          1|MagicMir | [14.08.2022 12:02.00.537] [LOG] Shutting down server…
          1|MagicMir | [14.08.2022 12:02.00.552] [LOG] Stopping module helper: MMM-Wallpaper
          1|MagicMir | [14.08.2022 12:02.00.559] [LOG] Stopping module helper: MMM-3Day-Forecast
            sdetweil @N6NG
            @N6NG said in pm2 errors:
            Module.require
            this indicates a down level version of npm
            please use use my script, it does everything.
            start from fresh SD card flash, cause I don’t know what you’ve got now, but it’s a mess
              sdetweil @N6NG
              either the latest 32 bit full desktop
              or if using video streams with MM, then the legacy 32 bit image
              N6NGN 1 Reply Last reply Reply Quote 0
              • N6NGN Offline
                N6NG @sdetweil
                @sdetweil No 64?
                  sdetweil @N6NG
                  @N6NG no. not yet… too many issues
