    NPM run start cannot be used
    44 Posts 4 Posters 20.7k Views 4 Watching
      sdetweil @史新瑞
      @史新瑞 remove the weatherEndpoint
      add
      type:'current'
      史 1 Reply Last reply Reply Quote 0
      • 史
        史新瑞 @sdetweil
        Is that so?
          sdetweil @史新瑞
          @史新瑞 no. in the weather config… that is the issue we are working on
          make it look like mine, use your apikey
          and your provider
          https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used/14?_=1660526689873
          • 史
            史新瑞 @sdetweil
            The first or the second?
              sdetweil @史新瑞
              @史新瑞 either, both, whatever
              just trying to get it to work
              • 史
                史新瑞 @sdetweil
                @sdetweil Different weather configurations should be configured in different ways。https://docs.magicmirror.builders/modules/weather.html#configuration-options
                The way I learned from here
                  sdetweil @史新瑞
                  @史新瑞 there are two options current weather and forecast
                  the new module eliminates having to use a lot of parms…
                  just try it my way, for a test
                  • 史
                    史新瑞 @sdetweil
                    @sdetweil I tried it just now, but it didn’t work. It will always show that it is loading
                      sdetweil @史新瑞
                      @史新瑞 ‘loading’ is the default message, until some data arrives.
                      can u show me what you did
                      • 史
                        史新瑞 @sdetweil
                        			module: "weather",
                        				weatherProvider:"weatherbit",
                        				type: "current",
                        				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                        				apiKey: "???"
                        			module: "weather",
                        			header: "Weather Forecast",
                        				type: "forecast",
                        				apiKey: "???"
                          sdetweil @史新瑞
                          @史新瑞
                          just the weather config
                          ok, this module is stupid… requires parms, but then doesn’t use them…
                          			module: "weather",
                          				updateInterval: 15*1000,
                          				initialLoadDelay: 2,
                          				weatherProvider: "weatherbit",
                          				weatherEndpoint:"/forecast/daily",
                          				type: "forecast",
                          				lat: 30.4548443,
                          				lon: -97.6222674,
                          				apiKey: "67f41759a9c74d8a917ac984155286f0",
                          also, forecast has a long old bug , make sure to set
                          and a short interval for testing
                          you can use this apikey… I will kill it in an hour or so…
                          I opened this issue
                          https://github.com/MichMich/MagicMirror/issues/2899
                          type: current (default) worked on with my apikey
                          • 史
                            史新瑞 @sdetweil
                            1.png Using NPM run start will:
                              sdetweil @史新瑞
                              @史新瑞 open the developers window.
                              ctrl-shift-i on the keyboard
                              select the console tab and enter weath
                              in the filter field
                              • 史
                                史新瑞 @sdetweil
                                @sdetweil I don’t know how to open the developer window.
                                  sdetweil @史新瑞
                                  @史新瑞 I just told you how
                                  • 史
                                    史新瑞 @sdetweil
                                    @sdetweil I pressed ctrl-shift-i, but the raspberry pie didn’t respond
                                      sdetweil @史新瑞
                                      @史新瑞 on the pi keyboard, right?
                                      all keys at once
                                      with MagicMirror on the screen
                                        I am going to sleep now,sorry, long day.
                                          MMRIZE
                                          It seems like electron and node.js version issue.
                                          As far as I know, recent MM is depending on newer node and electron, but during update, your electron and node’s version is not matched properly.
                                          I recommend you to reinstall your nodejs and electron cleanly.
                                          • 史
                                            史新瑞 @sdetweil
                                            @sdetweil Sorry, I am not convenient for debugging today. Please allow me to come back to you for consultation in a few days
                                            • 2 / 3
