    NPM run start cannot be used
    44 Posts 4 Posters 21.6k Views 4 Watching
    • 史
      史新瑞 @sdetweil
      Good evening. I just woke up
      /* MagicMirror² Config Sample
      * By Michael Teeuw https://michaelteeuw.nl
      * MIT Licensed.
      * see https://docs.magicmirror.builders/configuration/introduction.html
      * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
         address: "localhost", 	// Address to listen on, can be:
         port: 8080,
         basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
         ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
         language: "zh-cn",
         locale: "zh",
         timeFormat: 24,
         units: "metric",
         		module: "alert",
         		module: "updatenotification",
         		position: "top_bar"
         		module: "clock",
         		position: "top_left"
         		header: "US Holidays",
         					symbol: "calendar-check",
         					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
         //		module: "compliments",
         //		position: "lower_third"
         	module: "weather",
         		weatherProvider:"weatherbit",
         		weatherEndpoint:"/current/forecast/daily",
         		apiKey:"aa03f670e4944ac3a086f92482a5e25e",
         		lat:"40.5",
         		lon:"116.5",
         		showSun:"true",
         		colored:"true",
         		maxNumberOfDays:"5"
         	/*  显示图片
         			module: "MMM-ImagesPhotos",
         			position: "middle_center",
         				opacity: 0.5,
         				animationSpeed: 1000,
         				updateInterval: 5000,
         				maxWidth:"500px",
         				maxHeight:"200px",
         				backgroundColor: 'grey',  // not used if fill is true
         				fill: false,   // fill around image with blurred copy of image
         				blur: 10,   // only used if fill is true
         	module: "helloworld",
         	position: "bottom_bar",	// This can be any of the regions.
         		text: "Hi! May I help you?"
      	module: 'MMM-SimpleText',
      	position: 'bottom_right',
         		fontURL: {
         		  'value': 'Tahoma, Geneva, sans-serif'
         		fontSize: {
         		  'value': 'small'
         		fontStyle: {
         		  'value': 'italic'
         		color: {
         		  'value': '#FFFFFF'
         		refreshMs: {
         		  'value': '10000'
         		filePath: {
         		  'value': '123.txt'
        sdetweil @史新瑞
        @史新瑞 remove the weatherEndpoint
        add
        type:'current'
        史 1 Reply Last reply
        • 史
          史新瑞 @sdetweil
          Is that so?
            sdetweil @史新瑞
            @史新瑞 no. in the weather config… that is the issue we are working on
            make it look like mine, use your apikey
            and your provider
            https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used/14?_=1660526689873
            • 史
              史新瑞 @sdetweil
              The first or the second?
                sdetweil @史新瑞
                @史新瑞 either, both, whatever
                just trying to get it to work
                • 史
                  史新瑞 @sdetweil
                  @sdetweil Different weather configurations should be configured in different ways。https://docs.magicmirror.builders/modules/weather.html#configuration-options
                  The way I learned from here
                    sdetweil @史新瑞
                    @史新瑞 there are two options current weather and forecast
                    the new module eliminates having to use a lot of parms…
                    just try it my way, for a test
                    • 史
                      史新瑞 @sdetweil
                      @sdetweil I tried it just now, but it didn’t work. It will always show that it is loading
                        sdetweil @史新瑞
                        @史新瑞 ‘loading’ is the default message, until some data arrives.
                        can u show me what you did
                        • 史
                          史新瑞 @sdetweil
                          			module: "weather",
                          				type: "current",
                          				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          				apiKey: "???"
                          			module: "weather",
                          			header: "Weather Forecast",
                          				type: "forecast",
                          				apiKey: "???"
                            sdetweil @史新瑞
                            @史新瑞
                            just the weather config
                            ok, this module is stupid… requires parms, but then doesn’t use them…
                            			module: "weather",
                            				updateInterval: 15*1000,
                            				initialLoadDelay: 2,
                            				weatherProvider: "weatherbit",
                            				weatherEndpoint:"/forecast/daily",
                            				type: "forecast",
                            				lat: 30.4548443,
                            				lon: -97.6222674,
                            				apiKey: "67f41759a9c74d8a917ac984155286f0",
                            also, forecast has a long old bug , make sure to set
                            and a short interval for testing
                            you can use this apikey… I will kill it in an hour or so…
                            I opened this issue
                            https://github.com/MichMich/MagicMirror/issues/2899
                            type: current (default) worked on with my apikey
                            • 史
                              史新瑞 @sdetweil
                              1.png Using NPM run start will:
                                sdetweil @史新瑞
                                @史新瑞 open the developers window.
                                ctrl-shift-i on the keyboard
                                select the console tab and enter weath
                                in the filter field
                                • 史
                                  史新瑞 @sdetweil
                                  @sdetweil I don’t know how to open the developer window.
                                    sdetweil @史新瑞
                                    @史新瑞 I just told you how
                                    • 史
                                      史新瑞 @sdetweil
                                      @sdetweil I pressed ctrl-shift-i, but the raspberry pie didn’t respond
                                        sdetweil @史新瑞
                                        @史新瑞 on the pi keyboard, right?
                                        all keys at once
                                        with MagicMirror on the screen
                                          I am going to sleep now,sorry, long day.
                                            MMRIZE
                                            It seems like electron and node.js version issue.
                                            As far as I know, recent MM is depending on newer node and electron, but during update, your electron and node’s version is not matched properly.
                                            I recommend you to reinstall your nodejs and electron cleanly.
                                            • 2 / 3
