    MMM-OpenWeatherMapForecast stuck on Loading....
    63 Posts 16 Posters 55.7k Views 18 Watching
    • A
      ally @sdetweil
      @sdetweil This is new.
      oad stylesheet: modules/MMM-OpenWeatherMapForecast/MMM-OpenWeatherMapForecast.css
      loader.js:162 Styles loaded for: MMM-OpenWeatherMapForecast
      loader.js:164 Translations loaded for: MMM-OpenWeatherMapForecast
      loader.js:184 Load script: modules/default/newsfeed/newsfeed.js
      module.js:509 Module registered: newsfeed
      loader.js:155 Bootstrapping module: newsfeed
      loader.js:244 File already loaded: moment.js
      loader.js:160 Scripts loaded for: newsfeed
      loader.js:203 Load stylesheet: modules/default/newsfeed/newsfeed.css
      loader.js:162 Styles loaded for: newsfeed
      loader.js:164 Translations loaded for: newsfeed
      loader.js:203 Load stylesheet: css/custom.css
      alert.js:47 Starting module: alert
      updatenotification.js:18 Starting module: updatenotification
      clock.js:48 Starting module: clock
      calendar.js:87 Starting module: calendar
      compliments.js:38 Starting module: compliments
      weatherprovider.js:35 Weather provider: OpenWeatherMap initialized.
      weatherprovider.js:46 Weather provider: OpenWeatherMap started.
      MMM-OpenWeatherMapForecast.js:145 Starting module: MMM-OpenWeatherMapForecast
      newsfeed.js:65 Starting module: newsfeed
      main.js:501 All modules started!
      openweathermap.js:63 Could not load data ...  XMLHttpRequest
      (anonymous) @ openweathermap.js:63
      weather.js:150 New weather information available.
      openweathermap.js:43 Could not load data ...  XMLHttpRequest
      (anonymous) @ openweathermap.js:43
      59weather.js:150 New weather information available.
        sdetweil @ally
        @ally those errors are from the default weather module…
        i think you should disable them while we work this
        add
        disabled: true,
        after the module:“weather”,
        lines
        • A
          ally @sdetweil
          @sdetweil No errors being reported, but no change in the modules behavior.
          			module: "weather",
          			disabled: true,
          				type: "current",
          				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				apiKey: "XXXXXXXXXXX"
          			module: "weather",
          			disabled: true,
          			header: "Weather Forecast",
          				type: "forecast",
          			module: "MMM-OpenWeatherMapForecast",
          			header: "Weather",
          			classes: "default everyone",
          			disabled: false,
          				apikey: "XXXXXXXXXXX",
          				latitude: "51.506130",
          				longitude: "-0.090270",
            sdetweil @ally
            @ally I need the messages from the terminal window or pm2 logs
            do
            pm2 flush
            pm2 restart 0
            wait
            pm2 logs --lines=80 >somefile.txt 2>&1
            ctrl-c
            then examine somefile.txt
            • A
              ally @sdetweil
              @sdetweil unfortunately the same useful answer
              /home/pi/.pm2/logs/MagicMirror-out.log last 80 lines:
              0|MagicMir |
              0|MagicMir | > magicmirror@2.20.0 start
              0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
              0|MagicMir |
              0|MagicMir | [28.08.2022 20:52.28.785] [LOG]   Starting MagicMirror: v2.20.0
              0|MagicMir | [28.08.2022 20:52.28.793] [LOG]   Loading config ...
              0|MagicMir | [28.08.2022 20:52.28.800] [LOG]   Loading module helpers ...
              0|MagicMir | [28.08.2022 20:52.28.803] [LOG]   No helper found for module: alert.
              0|MagicMir | [28.08.2022 20:52.28.823] [LOG]   Initializing new module helper ...
              0|MagicMir | [28.08.2022 20:52.28.825] [LOG]   Module helper loaded: updatenotification
              0|MagicMir | [28.08.2022 20:52.28.826] [LOG]   No helper found for module: clock.
              0|MagicMir | [28.08.2022 20:52.29.043] [LOG]   Initializing new module helper ...
              0|MagicMir | [28.08.2022 20:52.29.044] [LOG]   Module helper loaded: calendar
              0|MagicMir | [28.08.2022 20:52.29.046] [LOG]   No helper found for module: compliments.
              0|MagicMir | [28.08.2022 20:52.29.097] [LOG]   Initializing new module helper ...
              0|MagicMir | [28.08.2022 20:52.29.098] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
              0|MagicMir | [28.08.2022 20:52.29.129] [LOG]   Initializing new module helper ...
              0|MagicMir | [28.08.2022 20:52.29.131] [LOG]   Module helper loaded: newsfeed
              0|MagicMir | [28.08.2022 20:52.29.132] [LOG]   All module helpers loaded.
              0|MagicMir | [28.08.2022 20:52.29.246] [LOG]   Starting server on port 8080 ...
              0|MagicMir | [28.08.2022 20:52.29.264] [LOG]   Server started ...
              0|MagicMir | [28.08.2022 20:52.29.265] [LOG]   Connecting socket for: updatenotification
              0|MagicMir | [28.08.2022 20:52.29.267] [LOG]   Starting module helper: updatenotification
              0|MagicMir | [28.08.2022 20:52.29.268] [LOG]   Connecting socket for: calendar
              0|MagicMir | [28.08.2022 20:52.29.268] [LOG]   Starting node helper for: calendar
              0|MagicMir | [28.08.2022 20:52.29.269] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
              0|MagicMir | [28.08.2022 20:52.29.270] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
              0|MagicMir | [28.08.2022 20:52.29.271] [LOG]   Connecting socket for: newsfeed
              0|MagicMir | [28.08.2022 20:52.29.271] [LOG]   Starting node helper for: newsfeed
              0|MagicMir | [28.08.2022 20:52.29.272] [LOG]   Sockets connected & modules started ...
              0|MagicMir | [28.08.2022 20:52.29.554] [LOG]   Launching application.
              0|MagicMir | [28.08.2022 20:52.32.673] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
              0|MagicMir | [28.08.2022 20:52.33.281] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              0|MagicMir | [28.08.2022 20:52.33.308] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
              0|MagicMir | [28.08.2022 20:52.33.374] [INFO]  Checking git for module: default
              0|MagicMir | [28.08.2022 20:52.33.661] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
              0|MagicMir | [28.08.2022 20:52.33.981] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
              0|MagicMir | [28.08.2022 20:52.34.387] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 20:52 ** ERROR ** null
                sdetweil @ally
                @ally there is another section of the output…where the error was reported last time
                home/pi/.pm2/logs/MagicMirror-error.log
                • A
                  ally @sdetweil
                  @sdetweil same error
                  28.08.2022 21:10.34.377] [LOG]   Starting MagicMirror: v2.20.0
                  [28.08.2022 21:10.34.385] [LOG]   Loading config ...
                  [28.08.2022 21:10.34.394] [LOG]   Loading module helpers ...
                  [28.08.2022 21:10.34.399] [LOG]   No helper found for module: alert.
                  [28.08.2022 21:10.34.419] [LOG]   Initializing new module helper ...
                  [28.08.2022 21:10.34.420] [LOG]   Module helper loaded: updatenotification
                  [28.08.2022 21:10.34.422] [LOG]   No helper found for module: clock.
                  [28.08.2022 21:10.34.635] [LOG]   Initializing new module helper ...
                  [28.08.2022 21:10.34.638] [LOG]   Module helper loaded: calendar
                  [28.08.2022 21:10.34.640] [LOG]   No helper found for module: compliments.
                  [28.08.2022 21:10.34.689] [LOG]   Initializing new module helper ...
                  [28.08.2022 21:10.34.692] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                  [28.08.2022 21:10.34.720] [LOG]   Initializing new module helper ...
                  [28.08.2022 21:10.34.723] [LOG]   Module helper loaded: newsfeed
                  [28.08.2022 21:10.34.724] [LOG]   All module helpers loaded.
                  [28.08.2022 21:10.34.833] [LOG]   Starting server on port 8080 ...
                  [28.08.2022 21:10.34.850] [LOG]   Server started ...
                  [28.08.2022 21:10.34.853] [LOG]   Connecting socket for: updatenotification
                  [28.08.2022 21:10.34.855] [LOG]   Starting module helper: updatenotification
                  [28.08.2022 21:10.34.857] [LOG]   Connecting socket for: calendar
                  [28.08.2022 21:10.34.859] [LOG]   Starting node helper for: calendar
                  [28.08.2022 21:10.34.861] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                  [28.08.2022 21:10.34.863] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                  [28.08.2022 21:10.34.865] [LOG]   Connecting socket for: newsfeed
                  [28.08.2022 21:10.34.867] [LOG]   Starting node helper for: newsfeed
                  [28.08.2022 21:10.34.868] [LOG]   Sockets connected & modules started ...
                  [28.08.2022 21:10.35.212] [LOG]   Launching application.
                  [28.08.2022 21:10.38.502] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                  [28.08.2022 21:10.38.552] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                  [28.08.2022 21:10.38.603] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                  [28.08.2022 21:10.38.642] [INFO]  Checking git for module: default
                  [28.08.2022 21:10.38.927] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:10.39.643] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:10 ** ERROR ** null
                  [28.08.2022 21:10.39.896] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:15.39.424] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:15.41.132] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:20.39.237] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:20 ** ERROR ** null
                  [28.08.2022 21:20.40.820] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:20.42.343] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:25.41.189] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:25.43.553] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:30.39.346] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:30 ** ERROR ** null
                  [28.08.2022 21:30.41.369] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:30.44.877] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:35.41.533] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:35.46.150] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:40.39.257] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:40 ** ERROR ** null
                  [28.08.2022 21:40.41.736] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:40.47.660] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:45.41.947] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:45.48.861] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:50.39.355] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:50 ** ERROR ** null
                  [28.08.2022 21:50.42.128] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:50.50.284] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 21:55.42.480] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 21:55.51.610] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 22:00.39.318] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 22:00 ** ERROR ** null
                  [28.08.2022 22:00.42.644] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 22:00.52.840] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 22:05.42.822] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                  [28.08.2022 22:05.54.216] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                  [28.08.2022 22:10.39.243] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 22:10 ** ERROR ** null
                    sdetweil @ally
                    @ally did u add my new code?
                      bassin12
                      I’m having some hard time too, I cannot get it to work and get this error, I’m using the same key for the default weather module
                      [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 07:50 ** ERROR ** Error: Request failed with status code 401
                      Not sure what I’m doing wrong.
                      module: “weather”,
                      position: “top_right”,
                      header: “Weather Forecast”,
                      weatherProvider: “openweathermap”,
                      type: “forecast”,
                      locationID: “4225309”,
                      apiKey: “working key”
                      module: “MMM-OpenWeatherForecast”,
                      header: “Wettervorschau Schama”,
                      apikey: “same key as above”, //SUPER SECRET
                      latitude: 49.039349,
                      longitude: 11.847070,
                      units: “metric”,
                      iconset: “4c”,
                      colored: true,
                      concise: true
                      S 3 Replies Last reply Reply Quote 0
                        sdetweil @bassin12
                        @bassin12 said in MMM-OpenWeatherMapForecast stuck on Loading....:
                        401
                        well, that is
                        http error 401 unauthorized
                        so, that looks like there is some error in your apiKey
                          sdetweil @bassin12
                          also, this is a different module than we are discussing
                            @bassin12 your config works perfectly with my apikey
                              sdetweil @bassin12
                              @bassin12 also, please enclose all config and code sections in a code block
                              copy paste the text into the new message
                              select the text
                              and the hit the button </> above the editor
                                bassin12
                                This is really funny, I downloaded the right module now, tested with my key, and now it is saying the key is invalid, this is the code I’m using
                                                       module: "weather",
                                                               type: "forecast",
                                                               locationID: "4225309",
                                                               apiKey: "Mykey"
                                                 header: "Weather",
                                                 disabled: false,
                                                   apiKey: "Mykey",
                                                   latitude: 51.506130,
                                                   longitude: -0.090270,
                                                   iconset: "4c",
                                                   concise: false,
                                                   forecastLayout: "table"
                                This is the error I get
                                [29.08.2022 09:07.47.834] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 09:07 ** ERROR ** No API key configured. Get an API key at https://openweathermap.org/api/one-call-api
                                I tried the Latitude and Longitude with and without quotes.
                                  sdetweil @bassin12
                                  @bassin12 this module uses all lowercase for the key name field
                                  apikey:
                                  this system is case sensitive
                                    bassin12
                                    I did the code change in node_helpe.js, and the system now reports this error
                                    [29.08.2022 10:34.06.199] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:34 ** bad status ** 401
                                    my full config.js is this:
                                    /* MagicMirror² Config Sample
                                     * By Michael Teeuw https://michaelteeuw.nl
                                     * MIT Licensed.
                                     * see https://docs.magicmirror.builders/configuration/introduction.html
                                     * and https://docs.magicmirror.builders/modules/configuration.html
                                    let config = {
                                    	address: "localhost", 	// Address to listen on, can be:
                                    	port: 8080,
                                    	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                                    	language: "en",
                                    	locale: "en-US",
                                    	timeFormat: 24,
                                    	units: "metric",
                                    			module: "weather",
                                    				type: "forecast",
                                    				apiKey: "45fe452eea1fcfe3589cd5e8aa3f3f93"
                                                            header: "Weather",
                                                            disabled: false,
        apikey: "45fe452eea1fcfe3589cd5e8aa3f3f93",
        iconset: "4c",
        concise: false,
                                    S 4 Replies Last reply Reply Quote 0
                                      sdetweil @bassin12
                                      @bassin12 yep… something…
                                      both work for me…
                                        sdetweil @bassin12
                                        @bassin12
                                        hm… I created a new key…
                                        seems OpenWeatherForecast has a bug
                                        in its node_helper.js
                                        change
                                                  "&units=" + payload.units +
                                        to (same as openWeatherMapForecast
                                                            (payload.units !== "" ? "&units=" + payload.units : "") +
                                        can’t pass in junk
                                          sdetweil @bassin12
                                          @bassin12 if the apikey is valid, I get 401 as well…
                                          using my (new) apikey… all ok…
                                            sdetweil @bassin12
                                            @bassin12 with that api key data is coming back, but its in the wrong format
                                            i switch to my apikey and all is good
                                            • 2 / 4
