    MMM-OpenWeatherMapForecast stuck on Loading....
    63 Posts 16 Posters 55.8k Views 18 Watching
      sdetweil @bassin12
      @bassin12 said in MMM-OpenWeatherMapForecast stuck on Loading....:
      401
      well, that is
      http error 401 unauthorized
      so, that looks like there is some error in your apiKey
        sdetweil @bassin12
        module: “MMM-OpenWeatherForecast”,
        also, this is a different module than we are discussing
          @bassin12 your config works perfectly with my apikey
            sdetweil @bassin12
            @bassin12 also, please enclose all config and code sections in a code block
            copy paste the text into the new message
            select the text
            and the hit the button </> above the editor
              bassin12
              This is really funny, I downloaded the right module now, tested with my key, and now it is saying the key is invalid, this is the code I’m using
                                     module: "weather",
                                     header: "Weather Forecast",
                                             type: "forecast",
                                             locationID: "4225309",
                                             apiKey: "Mykey"
                               module: "MMM-OpenWeatherMapForecast",
                               header: "Weather",
                               classes: "default everyone",
                               disabled: false,
                                 apiKey: "Mykey",
                                 latitude: 51.506130,
                                 longitude: -0.090270,
                                 iconset: "4c",
                                 concise: false,
                                 forecastLayout: "table"
              This is the error I get
              [29.08.2022 09:07.47.834] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 09:07 ** ERROR ** No API key configured. Get an API key at https://openweathermap.org/api/one-call-api
              I tried the Latitude and Longitude with and without quotes.
                sdetweil @bassin12
                @bassin12 this module uses all lowercase for the key name field
                apikey:
                this system is case sensitive
                  bassin12
                  I did the code change in node_helpe.js, and the system now reports this error
                  [29.08.2022 10:34.06.199] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:34 ** bad status ** 401
                  my full config.js is this:
                  /* MagicMirror² Config Sample
                   * By Michael Teeuw https://michaelteeuw.nl
                   * MIT Licensed.
                   * see https://docs.magicmirror.builders/configuration/introduction.html
                   * and https://docs.magicmirror.builders/modules/configuration.html
                  let config = {
                  	address: "localhost", 	// Address to listen on, can be:
                  	port: 8080,
                  	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                  	language: "en",
                  	locale: "en-US",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "weather",
                  				type: "forecast",
                  				apiKey: "45fe452eea1fcfe3589cd5e8aa3f3f93"
                                          header: "Weather",
                                          disabled: false,
                                                  apikey: "45fe452eea1fcfe3589cd5e8aa3f3f93",
                                                  latitude: "51.506130",
                                                  longitude: "-0.090270",
                                                  iconset: "4c",
                                                  concise: false,
                  S 4 Replies Last reply
                    sdetweil @bassin12
                    @bassin12 yep… something…
                    both work for me…
                      sdetweil @bassin12
                      @bassin12
                      hm… I created a new key…
                      seems OpenWeatherForecast has a bug
                      in its node_helper.js
                      change
                                "&units=" + payload.units +
                      to (same as openWeatherMapForecast
                                          (payload.units !== "" ? "&units=" + payload.units : "") +
                      can’t pass in junk
                        sdetweil @bassin12
                        @bassin12 if the apikey is valid, I get 401 as well…
                        using my (new) apikey… all ok…
                          sdetweil @bassin12
                          @bassin12 with that api key data is coming back, but its in the wrong format
                          i switch to my apikey and all is good
                          • A
                            ally @sdetweil
                            @sdetweil I deleted the MMM-OpenWeatherMapForecast and reinstalled it as per the instructions. Results below, no change.
                            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                            0|MagicMir | [30.08.2022 18:29.44.705] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            0|MagicMir | [30.08.2022 18:32.45.422] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                            0|MagicMir | [30.08.2022 18:34.45.902] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            0|MagicMir | [30.08.2022 18:37.19.673] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:37 ** ERROR ** null
                            0|MagicMir | [30.08.2022 18:37.45.605] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                            0|MagicMir | [30.08.2022 18:39.47.120] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            0|MagicMir | [30.08.2022 18:42.45.793] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                            0|MagicMir | [30.08.2022 18:44.48.354] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            0|MagicMir | [30.08.2022 18:47.19.775] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:47 ** ERROR ** null
                            0|MagicMir | [30.08.2022 18:47.45.968] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                            0|MagicMir | [30.08.2022 18:49.49.561] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            0|MagicMir | [30.08.2022 18:52.46.128] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                            0|MagicMir | [30.08.2022 18:54.50.794] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            0|MagicMir | [30.08.2022 18:57.19.667] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:57 ** ERROR ** null
                            0|MagicMir | [30.08.2022 18:57.46.299] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                            0|MagicMir | [30.08.2022 18:59.52.001] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            0|MagicMir | [30.08.2022 19:02.46.483] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                            0|MagicMir | [30.08.2022 19:04.53.188] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                            Am I doing anything wrong?
                            Ally
                              bassin12
                              I think I was able to get to the bottom of this, you need to subscribe to the API giving your credit card information, also API 2.5 is deprecated for new users, I entered in contact with Open Weather and they have sent me this information.
                              Hope this helps people in the future.
                              A 1 Reply Last reply
                                sdetweil @ally
                                @ally what instructions?
                                unless the author changed the code, nothing will change
                                • A
                                  ally @bassin12
                                  What service did you subscribe to, as that looks like the only way to enter your credit card info.
                                  Ally
                                  E 1 Reply Last reply
                                  • E
                                    elorand @ally
                                    Hey @ally, I recently ran into the same problem like you.
                                    I followed all instructions given to you from @sdetweil and finally figured out, what the problem was: openweathermap updated its api to version 3.0!
                                    Even if you have a free subscription (limiting to 1000 api-calls a day, which is fine unless you stay above a refreshrate of every 3 minutes), you need to edit the link in node_helper.js from
                                    var url = "https://api.openweathermap.org/data/2.5/onecall" +
                                    to
                                    var url = "https://api.openweathermap.org/data/3.0/onecall" +
                                    For the free subscription on API-Version 3.0, you need to provide your credit card information, but you can set the maximum of possible API-calls to 1000, so that you will never ever ran into any costs.
                                    S A L 3 Replies Last reply
                                      sdetweil @elorand
                                      @elorand the default weather module still uses 2.5 and it works
                                      karsten13K 1 Reply Last reply
                                        chief
                                        Just following up on this thread - I also am on the “free tier” 2.5 API version and when I try to use MMM-OpenWeatherForecast, it is stuck on “Loading”.
                                        Any advice?
                                        • E
                                          elorand @chief
                                          @sdetweil I couldn’t choose the old 2.5 API when I registered as new user to OpenWeatherMap. Therefore I had no other chance than to go with the 3.0 API.
                                          @chief depending on the API you are subscribed to, you need to edit the node_helper.js (as mentioned in my previous post). After editing you should restart your magicmirror.
                                          • karsten13K
                                            karsten13 @sdetweil
                                            at the moment, yes.
                                            I looked into their api stuff and onecall v2.5 is not mentioned anymore. The normal endpoints weather and forecast are still on v2.5.
                                            Problem: For onecall 3.0 you need a special api key (as already mentioned here) with a subsciption where you have to give your payment data (1000 request free per day, limit is 2000 per day but you can set your limit to 1000 if you want it for free … ).
                                            I think we will get problems/questions to this for the default weather module too.
                                            So (for default weather module) if you use endpoints weather and forecast and old onecall v2.5 everthing works out of the box with old api keys, if someone use new onecall v3.0 he needs an api key for 3.0 and has to set apiVersion: "3.0", in the config …
                                            • 2 / 4
