    MMM-OpenWeatherMapForecast stuck on Loading....
    63 Posts 16 Posters 52.6k Views 18 Watching
      sdetweil @bassin12
      @bassin12
      hm… I created a new key…
      seems OpenWeatherForecast has a bug
      in its node_helper.js
      change
                "&units=" + payload.units +
      to (same as openWeatherMapForecast
                          (payload.units !== "" ? "&units=" + payload.units : "") +
      can’t pass in junk
        sdetweil @bassin12
        @bassin12 if the apikey is valid, I get 401 as well…
        using my (new) apikey… all ok…
          sdetweil @bassin12
          @bassin12 with that api key data is coming back, but its in the wrong format
          i switch to my apikey and all is good
            ally @sdetweil
            @sdetweil I deleted the MMM-OpenWeatherMapForecast and reinstalled it as per the instructions. Results below, no change.
            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
            0|MagicMir | [30.08.2022 18:29.44.705] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [30.08.2022 18:32.45.422] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
            0|MagicMir | [30.08.2022 18:34.45.902] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [30.08.2022 18:37.19.673] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:37 ** ERROR ** null
            0|MagicMir | [30.08.2022 18:37.45.605] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
            0|MagicMir | [30.08.2022 18:39.47.120] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [30.08.2022 18:42.45.793] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
            0|MagicMir | [30.08.2022 18:44.48.354] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [30.08.2022 18:47.19.775] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:47 ** ERROR ** null
            0|MagicMir | [30.08.2022 18:47.45.968] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
            0|MagicMir | [30.08.2022 18:49.49.561] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [30.08.2022 18:52.46.128] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
            0|MagicMir | [30.08.2022 18:54.50.794] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [30.08.2022 18:57.19.667] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:57 ** ERROR ** null
            0|MagicMir | [30.08.2022 18:57.46.299] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
            0|MagicMir | [30.08.2022 18:59.52.001] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [30.08.2022 19:02.46.483] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
            0|MagicMir | [30.08.2022 19:04.53.188] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            Am I doing anything wrong?
            Ally
              bassin12
              I think I was able to get to the bottom of this, you need to subscribe to the API giving your credit card information, also API 2.5 is deprecated for new users, I entered in contact with Open Weather and they have sent me this information.
              Hope this helps people in the future.
              A 1 Reply Last reply Reply Quote 1
                sdetweil @ally
                @ally what instructions?
                unless the author changed the code, nothing will change
                  ally @bassin12
                  @bassin12 said in MMM-OpenWeatherMapForecast stuck on Loading....:
                  What service did you subscribe to, as that looks like the only way to enter your credit card info.
                  Ally
                  • E Offline
                    elorand @ally
                    Hey @ally, I recently ran into the same problem like you.
                    I followed all instructions given to you from @sdetweil and finally figured out, what the problem was: openweathermap updated its api to version 3.0!
                    Even if you have a free subscription (limiting to 1000 api-calls a day, which is fine unless you stay above a refreshrate of every 3 minutes), you need to edit the link in node_helper.js from
                    var url = "https://api.openweathermap.org/data/2.5/onecall" +
                    to
                    var url = "https://api.openweathermap.org/data/3.0/onecall" +
                    For the free subscription on API-Version 3.0, you need to provide your credit card information, but you can set the maximum of possible API-calls to 1000, so that you will never ever ran into any costs.
                    S A L 3 Replies Last reply Reply Quote 1
                      sdetweil @elorand
                      @elorand the default weather module still uses 2.5 and it works
                        chief
                        Just following up on this thread - I also am on the “free tier” 2.5 API version and when I try to use MMM-OpenWeatherForecast, it is stuck on “Loading”.
                        Any advice?
                        • E Offline
                          elorand @chief
                          @sdetweil I couldn’t choose the old 2.5 API when I registered as new user to OpenWeatherMap. Therefore I had no other chance than to go with the 3.0 API.
                          @chief depending on the API you are subscribed to, you need to edit the node_helper.js (as mentioned in my previous post). After editing you should restart your magicmirror.
                          • karsten13K Online
                            karsten13 @sdetweil
                            at the moment, yes.
                            I looked into their api stuff and onecall v2.5 is not mentioned anymore. The normal endpoints weather and forecast are still on v2.5.
                            Problem: For onecall 3.0 you need a special api key (as already mentioned here) with a subsciption where you have to give your payment data (1000 request free per day, limit is 2000 per day but you can set your limit to 1000 if you want it for free … ).
                            I think we will get problems/questions to this for the default weather module too.
                            So (for default weather module) if you use endpoints weather and forecast and old onecall v2.5 everthing works out of the box with old api keys, if someone use new onecall v3.0 he needs an api key for 3.0 and has to set apiVersion: "3.0", in the config …
                            • L Offline
                              LemonBrain @ally
                              @ally
                              Hi!
                              There was an error “** ERROR ** Error: socket hang up”
                              This solution helped:
                              in the module node_helper.js
                              replace with
                              var url = "http://api.openweathermap.org/data/2.5/onecall" +
                              (https -> http)
                              and restart the MM2
                              • Y Offline
                                yk
                                Was there an agreed solution to this one? Do we need to subscribe separately to the 3.0 API or does the free subscription doable (works with default weather module)?
                                • L Offline
                                  LemonBrain @yk
                                  @yk
                                  Hello!
                                  I use a free subscription. This subscription apparently has a problem with https protocol. Found out by randomly studying the weather server’s response in the browser.
                                    anhanyoung @elorand
                                    @elorand Hey man, I know this was a little while ago but I’m struggling with this atm. I subscribed to 3.0 but when I look at my services tab, it’s still showing the free version. When I create an API, it doesn’t seem to work even with editing the node helper to the url you posted. Is there a specific way to generate an API from them with 3.0?
                                      sdetweil @anhanyoung
                                      @anhanyoung try my version. I fixed a loading bug a while back
                                      https://github.com/sdetweil/MMM-OpenWeatherMapForecast
                                        @anhanyoung I see your key is 3.0, but the code uses 2.5.
                                        module needs a new parameter to allow selecting which api group it’s in and use that when constructing the url
                                        • L Offline
                                          Latch @elorand
                                          @elorand
                                          This worked for me. Great work!
                                          • T Offline
                                            Tomcat1977 @LemonBrain
                                            @LemonBrain This is the solution! Thanks! No API 3.0, no apiversions. THIS IS IT! Thank you very much! It took me a week to find this!
                                            • 3 / 4
