    Change page with MMM-Pages
    25 Posts 3 Posters 9.6k Views 3 Watching
    • E Offline
      Egnos
      Hello everybody,
      I would need your advice to change pages of the MM (I use MMM-Pages).
      I have always used automatic rotation or recipes with the GA module … but I would like to do without the GA.
      What methods do you know to change pages using notifications? Excluding GA …
      Thank you all.
        MMRIZE @Egnos
        @Egnos Which condition do you regard as a trigger? timer? button? face recognition?
          sdetweil @MMRIZE
          @MMRIZE swipe? hand gesture
            MMRIZE @sdetweil
            For the gesture, you can use MMM-Touch(touchscreen) or MMM-GroveGesture(gesture sensor).
            Yup, it was my PR time… :D
            @Egnos
            If you want to use MMM-Pages as simply time-based rotation, just assign rotationTime to your module configuration.
              sdetweil @MMRIZE
              @MMRIZE he has timed change… wants something explicit … has voice via GA now… but wants interaction without GA
                MMRIZE @sdetweil
                @Egnos
                We might have many user-input methods for the mirror, but you need to have them already. What do you have? physical button? touchscreen? command from a smartphone? IR sensor? face detection from a webcam? Geo-fence detection? IFTTT event? noise detection? voice command without GA? Alexa skill? by email(yes, even it possible)…
                What do you want? then we can discuss about it. :)
                S E 2 Replies Last reply Reply Quote 0
                  sdetweil @MMRIZE
                  @MMRIZE cannot be Alexa Skill
                  sadly Amazon has implemented new certification processes that MM system cannot pass
                  until certified all skill access is blocked
                  https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
                    MMRIZE @sdetweil
                    @sdetweil Sad to hear it.
                    But I think through IFTTT it might be possible (though not tested, but…)
                    I mean, not Alexa implemented mirror, but use Alexa Echo to command a mirror (via IFTTT and webhook endpoint)
                      sdetweil @MMRIZE
                      @MMRIZE ah, and MMM-AlexaControl can do that locally (and already supports pages)
                      • E Offline
                        Egnos @MMRIZE
                        @MMRIZE said in Change page with MMM-Pages:
                        @Egnos
                        Hi @MMRIZE and thanks for your reply.
                        I wanted to understand which methods were possible to change the page using the notification method (excluding GA that I already use …).
                        I was interested in “MMM-GroveGesture” (Maybe combined with a PIR…) but I have seen that some have reliability problems. Have you ever tried it?
                        https://forum.magicmirror.builders/topic/6428/question-to-mmm-swipe-simon089-and-mmm-pages-and-mmm-page-indicator
                        I mean, not Alexa implemented mirror, but use Alexa Echo to command a mirror (via >IFTTT and webhook endpoint)
                        This solution of using Alexa Echo might interest me: have you already done some tests?
                        Thanks very much for the valuable advice!
