    Change page with MMM-Pages
    25 Posts 3 Posters 9.9k Views 3 Watching
      sdetweil @MMRIZE
      @MMRIZE he has timed change… wants something explicit … has voice via GA now… but wants interaction without GA
        MMRIZE @sdetweil
        @Egnos
        We might have many user-input methods for the mirror, but you need to have them already. What do you have? physical button? touchscreen? command from a smartphone? IR sensor? face detection from a webcam? Geo-fence detection? IFTTT event? noise detection? voice command without GA? Alexa skill? by email(yes, even it possible)…
        What do you want? then we can discuss about it. :)
        S E 2 Replies Last reply Reply Quote 0
          sdetweil @MMRIZE
          @MMRIZE cannot be Alexa Skill
          sadly Amazon has implemented new certification processes that MM system cannot pass
          until certified all skill access is blocked
          https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
            MMRIZE @sdetweil
            @sdetweil Sad to hear it.
            But I think through IFTTT it might be possible (though not tested, but…)
            I mean, not Alexa implemented mirror, but use Alexa Echo to command a mirror (via IFTTT and webhook endpoint)
              sdetweil @MMRIZE
              @MMRIZE ah, and MMM-AlexaControl can do that locally (and already supports pages)
              • E Offline
                Egnos @MMRIZE
                @MMRIZE said in Change page with MMM-Pages:
                @Egnos
                Hi @MMRIZE and thanks for your reply.
                I wanted to understand which methods were possible to change the page using the notification method (excluding GA that I already use …).
                I was interested in “MMM-GroveGesture” (Maybe combined with a PIR…) but I have seen that some have reliability problems. Have you ever tried it?
                https://forum.magicmirror.builders/topic/6428/question-to-mmm-swipe-simon089-and-mmm-pages-and-mmm-page-indicator
                I mean, not Alexa implemented mirror, but use Alexa Echo to command a mirror (via >IFTTT and webhook endpoint)
                This solution of using Alexa Echo might interest me: have you already done some tests?
                Thanks very much for the valuable advice!
                  sdetweil @Egnos
                  @Egnos said in Change page with MMM-Pages:
                  MMM-AlexaControl already provides support for MMM-Pages, using the notifications configuration options
                  next and back, and you can add actions to go to a specific pages (hard coded number)
                  AlexaControl creates fake/virtual wemo plugs, which can be turned on or off…
                  they cannot receive any data … so you can say ‘Turn on page 2’ which sends notification to pages to go to page two
                  but you cannot define a single switch that can go to any page based on voice…
                  (but it sounds like that to the user)…
                    MMRIZE @Egnos
                    Yup, I made that. :)
                    That is a different H/W and different module with MMM-GroveGesture. MMM-Swipe is using HC-SR04, Ultrasonic Sensor, it is different with PAJ7620 gesture sensor.
                    Not with Echo, But with Google Home I had success,(+ IFTTT + Nginx + dataplicity.io + MMM-NotificationTrigger) It is definitely possible.
                    • E Offline
                      Egnos @sdetweil
                      @sdetweil said in Change page with MMM-Pages:
                      I did not understand this last sentence …
                      Which one do you recommend between the two? Did you find “MMM-GroveGesture” reliable?
                      It would be perfect (I am oriented to the purchase of a Nest Audio …) but I see the thing too “complicated” … :grinning_face_with_sweat:
                        sdetweil @Egnos
                        the way AlexaControl works , it creates a switch, on or off…
                        a switch doesn’t get any data from the voice command
                        on 12? makes no sense
                        so you cannot create a single generic go to page x, notification
                        and use voice to give x
                        you CAN create a notification for EACH page
                        page 1
                        page 2
                        page 3
                        page 4
                        page 5
                        and the voice is ‘alexa, turn on page 1’
                        and the page 1 alexacontrol event fires the pages notification for goto page 1
                        this.sendNotification("PAGE_CHANGED", 0);
