    Change page with MMM-Pages
    25 Posts 3 Posters 12.8k Views 3 Watching
      sdetweil @MMRIZE
      @MMRIZE he has timed change… wants something explicit … has voice via GA now… but wants interaction without GA
        MMRIZE @sdetweil
        @Egnos
        We might have many user-input methods for the mirror, but you need to have them already. What do you have? physical button? touchscreen? command from a smartphone? IR sensor? face detection from a webcam? Geo-fence detection? IFTTT event? noise detection? voice command without GA? Alexa skill? by email(yes, even it possible)…
        What do you want? then we can discuss about it. :)
        S E 2 Replies Last reply Reply Quote 0
          sdetweil @MMRIZE
          @MMRIZE cannot be Alexa Skill
          sadly Amazon has implemented new certification processes that MM system cannot pass
          until certified all skill access is blocked
          https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working
            MMRIZE @sdetweil
            @sdetweil Sad to hear it.
            But I think through IFTTT it might be possible (though not tested, but…)
            I mean, not Alexa implemented mirror, but use Alexa Echo to command a mirror (via IFTTT and webhook endpoint)
              sdetweil @MMRIZE
              @MMRIZE ah, and MMM-AlexaControl can do that locally (and already supports pages)
              • E Offline
                Egnos @MMRIZE
                @MMRIZE said in Change page with MMM-Pages:
                @Egnos
                Hi @MMRIZE and thanks for your reply.
                I wanted to understand which methods were possible to change the page using the notification method (excluding GA that I already use …).
                I was interested in “MMM-GroveGesture” (Maybe combined with a PIR…) but I have seen that some have reliability problems. Have you ever tried it?
                https://forum.magicmirror.builders/topic/6428/question-to-mmm-swipe-simon089-and-mmm-pages-and-mmm-page-indicator
                I mean, not Alexa implemented mirror, but use Alexa Echo to command a mirror (via >IFTTT and webhook endpoint)
                This solution of using Alexa Echo might interest me: have you already done some tests?
                Thanks very much for the valuable advice!
                  sdetweil @Egnos
                  @Egnos said in Change page with MMM-Pages:
                  MMM-AlexaControl already provides support for MMM-Pages, using the notifications configuration options
                  next and back, and you can add actions to go to a specific pages (hard coded number)
                  AlexaControl creates fake/virtual wemo plugs, which can be turned on or off…
                  they cannot receive any data … so you can say ‘Turn on page 2’ which sends notification to pages to go to page two
                  but you cannot define a single switch that can go to any page based on voice…
                  (but it sounds like that to the user)…
                    MMRIZE @Egnos
                    Yup, I made that. :)
                    That is a different H/W and different module with MMM-GroveGesture. MMM-Swipe is using HC-SR04, Ultrasonic Sensor, it is different with PAJ7620 gesture sensor.
                    Not with Echo, But with Google Home I had success,(+ IFTTT + Nginx + dataplicity.io + MMM-NotificationTrigger) It is definitely possible.
                    • E Offline
                      Egnos @sdetweil
                      @sdetweil said in Change page with MMM-Pages:
                      I did not understand this last sentence …
                      Which one do you recommend between the two? Did you find “MMM-GroveGesture” reliable?
                      It would be perfect (I am oriented to the purchase of a Nest Audio …) but I see the thing too “complicated” … :grinning_face_with_sweat:
                        sdetweil @Egnos
                        the way AlexaControl works , it creates a switch, on or off…
                        a switch doesn’t get any data from the voice command
                        on 12? makes no sense
                        so you cannot create a single generic go to page x, notification
                        and use voice to give x
                        you CAN create a notification for EACH page
                        page 1
                        page 2
                        page 3
                        page 4
                        page 5
                        and the voice is ‘alexa, turn on page 1’
                        and the page 1 alexacontrol event fires the pages notification for goto page 1
                        this.sendNotification("PAGE_CHANGED", 0);
                        • E Offline
                          Egnos @MMRIZE
                          Yup, I made that.
                          Sorry @MMRIZE but I didn’t understand that the module “MMM-GroveGesture” was created by you and I apologize if I doubted its reliability.
                          I found the sensor you mentioned, in a nicer form to see, I am attaching the link:
                          https://shop.m5stack.com/products/unit-gesture-recognition-sensor-paj7620u2
                          Can you confirm that it is the same HW that you used?
                          Furthermore, would it be possible to link the functions of the gesture sensor to a motion sensor (PIR)?
                          For instance:
                          IF the motion sensor does not detect movement THEN do not activate the gesture sensor (also because the monitor would be off …)
                          IF the motion sensor detects movement THEN also activate the gesture sensor (also because the monitor would be on …)
                          page 1
                          page 2
                          page 3
                          page 4
                          page 5
                          thanks @sdetweil now i understand. Thank you so much!
                            MMRIZE @Egnos
                            Looks like so. (If the description is right). I think it is only housed with pretty cover. But I think its better without housing (Because you may want to dig this sensor to wooden mirror frame. In that case, without housing would be better to assembly)
                            Another possible issue might be HY2.0-4P Cable included. That connector would not fit with bare GPIO pins of RPI. You may need something like below cable (only one piece);
                            For instance:
                            MMM-GroveGestures module already has onIdle and onDetected features, So these features could be used for your idle/wakeup behaviours. (But the sensor itself has not long distances like PIR, so to use PIR together would be better idea.)
                            • E Offline
                              Egnos @MMRIZE
                              If instead you took the sensor without a cover how did you think of attaching it to the frame? Do you leave the sensor naked or cover it with a self made cover?
                              Ok, I hope you will help me when I have to make it work!:winking_face:
                              From your tests what is the minimum distance that the hand must have from the sensor?
                              Thank you very much!
                                sdetweil @Egnos
                                the doc for the sensor he linked says
                                Effective recognition distance 5cm-15cm
                                (without obstruction of case or cover)
                                • E Offline
                                  Egnos @sdetweil
                                  If so, it is very little!
                                    MMRIZE @Egnos
                                    @Egnos
                                    See how usage looks like.
                                    https://youtu.be/BcpZvkcrfHU
                                    E 1 Reply Last reply Reply Quote 1
                                    • E Offline
                                      Egnos @MMRIZE
                                      I just have to try!
                                      @MMRIZE If instead you took the sensor without a cover how did you think of attaching it to the frame? Do you leave the sensor naked or cover it with a self made cover?
                                        MMRIZE @Egnos
                                        @Egnos
                                        At this moment, I don’t have the real implementation to show,
                                        But what I tried was;
                                        Dig a hole then Implant the sensor in the frame. This gesture sensor has a short distance, but fortunately, through thin plastic/acryl/wood/paper/glass, it works. It detects changes in magnetic fields so except for metal/mirror(metal coated) it will work.
                                        My first intention was to cover the hole with small cardboard paper, then paint it black (I prefer a black framed mirror), But I lost interest at the finish stage, so I left it naked. :D
                                        • E Offline
                                          Egnos @MMRIZE
                                          Hi @MMRIZE unfortunately behind wood, plastic or plexiglass the sensor does not work … it’s a big problem!
                                          Do you know by chance if this sensor has a SW adjustment (I don’t see any trimmer on the PCB …)?
                                          thanks
                                            MMRIZE @Egnos
                                            @Egnos
                                            By my test, under 5mm thick plastic or wood panel it works. But there is no s/w fixture about it.
