    PIR sensor to turn on LED strip
    35 Posts 6 Posters 14.6k Views 6 Watching
    • E Offline
      Egnos @sdetweil
      @sdetweil said in PIR sensor to turn on LED strip:
      @Egnos from the 3rd party modules list, maybe
      This module https://github.com/idoodler/MMM-RPI-LED it seems it cannot be controlled with notifications.
        sdetweil @Egnos
        @Egnos that could be added pretty easily.
        • E Offline
          Egnos @sdetweil
          The problem is that I don’t have the skills to program. I understand something … but not enough … unfortunately
            sdetweil @Egnos
            @Egnos well, there ARE people who could do it…
              sdetweil @Egnos
              @Egnos what actions would u like the LEDs to do on notification? and what would u think the notification ID string should be?
              • E Offline
                Egnos @sdetweil
                Initially it would be enough to turn on the LEDs at the same time as the monitor is turned on and turn them off when the monitor is turned off.
                For the notification I believe that the module that manages the LEDs should respond to a notification such as “LightOn-White” and “LightOff-White” generated by the module that manages the PIR sensor variations.
                I hope I haven’t said too many wrong things … 🤞
                  sdetweil @Egnos
                  @Egnos that led module can only on/off/ or blink
                  • E Offline
                    Egnos @sdetweil
                    At the moment I could be satisfied … but it does not seem that the module proposed by you can receive notifications.
                      sdetweil @Egnos
                      @Egnos notifications are easy… but this module rpi-leds, only toggles the leds ON the pi board… not led strip…
                      if u can find one that works the ed strip with a python command, then we can make that work
                      • E Offline
                        Egnos
                        Maybe this module could fit https://github.com/jc21/MMM-PiLights, using SPI and a LPD8806 or WS2801 LED strip.
                        It appears to respond to notifications:
                        this.sendNotification('PILIGHTS_SEQUENCE', 'blue_pulse');
                          sdetweil @Egnos
                          @Egnos it has a way for all off. but not all on.
                            sdetweil @Egnos
                            @Egnos use my updated fork…
                            https://github.com/sdetweil/MMM-PiLights
                            it responds to the PIR modules USER_PRESENCE notification (true = turn on, false = turn off)
                            if lights are off and on is sent, it will restore the previous sequence set with the normal
                            SEQUENCE notification
                            • wishmaster270W Offline
                              wishmaster270 Module Developer
                              I would suggest the solution of @sdetweil as well.
                              An other, but much more complicate version would be to use my PythonLedControl and control it with the MMM-MQTTbridge module.
                              • E Offline
                                Egnos @sdetweil
                                Thanks @sdetweil
                                Let’s see if I understand:
                                • By default the LEDs will be off, until the “MMM-GPIO-Notifications” module detects something.
                                • If the PIR detects the movement the “MMM-GPIO-Notifications” module will send the notification USER_PRESENCE = true and the LEDs will turn on
                                • After some time without movement the “MMM-GPIO-Notifications” module will send the notification USER_PRESENCE = false and the LEDs will turn off
                                Correct?
                                I’m not a developer, but I’m still trying to understand your change in the code:
                                else if (notification === ' USER_PRESENCE'){
                                            if(payload == false){
                                                this.leds.allOFF();
                                            } else {
                                                // user present, restore the last active sequence
                                                Promise.resolve(this.runSequence(this.lastSequence.sequence, thi,lastSequence.iterations,this.lastSequence.delay)
                                                .catch((err) => {
                                                    this.log('user present Sequence error: ' + err.message);
                                why can’t I see this notification in the code?
                                            if(payload == true){
                                                this.leds.allON();
                                Thanks again!
                                M S 3 Replies Last reply Reply Quote 0
                                  MMRIZE @Egnos
                                  @Egnos
                                  ' USER_PRESENCE' !== 'USER_PRESENCE'
                                    sdetweil @Egnos
                                    @Egnos fixed the typo, git pull for the update
                                      sdetweil @MMRIZE
                                      @MMRIZE good catch
                                        sdetweil @Egnos
                                        @Egnos u don’t need the GPIO_Notifications module. as the PIR modules send the USER_PRESENCE notification
                                        • E Offline
                                          Egnos @sdetweil
                                          u don’t need the GPIO_Notifications module. as the PIR modules send the USER_PRESENCE notification:
                                          The module I use for sending notifications when the PIR detects motion is MMM-GPIO-Notifications
                                          I believe he is sending the “USER_PRESENCE” notification:
                                          notifications: [
                                                        notification: 'USER_PRESENCE',
                                                        payload: true
                                          Thanks for your patience @sdetweil ! ;-)
                                            sdetweil @Egnos
                                            @Egnos ok got it.
                                            what I was saying is that the
                                            MMM-PIR-???
                                            modules, if you use them, THEY send the USER_PRESENCE notification
                                            the GPIO_Notifcations module is more generic and can send notifications for ANY gpio device
