    PIR sensor to turn on LED strip
    35 Posts 6 Posters 16.3k Views 6 Watching
    • E
      Egnos @sdetweil
      @sdetweil said in PIR sensor to turn on LED strip:
      what actions would u like the LEDs to do on notification? and what would u think the notification ID string should be?
      Initially it would be enough to turn on the LEDs at the same time as the monitor is turned on and turn them off when the monitor is turned off.
      For the notification I believe that the module that manages the LEDs should respond to a notification such as “LightOn-White” and “LightOff-White” generated by the module that manages the PIR sensor variations.
      I hope I haven’t said too many wrong things … 🤞
        sdetweil @Egnos
        @Egnos that led module can only on/off/ or blink
        E 1 Reply Last reply
        • E
          Egnos @sdetweil
          At the moment I could be satisfied … but it does not seem that the module proposed by you can receive notifications.
            sdetweil @Egnos
            @Egnos notifications are easy… but this module rpi-leds, only toggles the leds ON the pi board… not led strip…
            if u can find one that works the ed strip with a python command, then we can make that work
            • E
              Egnos
              Maybe this module could fit https://github.com/jc21/MMM-PiLights, using SPI and a LPD8806 or WS2801 LED strip.
              It appears to respond to notifications:
              this.sendNotification('PILIGHTS_SEQUENCE', 'blue_pulse');
              S 2 Replies Last reply
                sdetweil @Egnos
                @Egnos it has a way for all off. but not all on.
                  sdetweil @Egnos
                  @Egnos use my updated fork…
                  https://github.com/sdetweil/MMM-PiLights
                  it responds to the PIR modules USER_PRESENCE notification (true = turn on, false = turn off)
                  if lights are off and on is sent, it will restore the previous sequence set with the normal
                  SEQUENCE notification
                  • wishmaster270W
                    wishmaster270 Module Developer
                    I would suggest the solution of @sdetweil as well.
                    An other, but much more complicate version would be to use my PythonLedControl and control it with the MMM-MQTTbridge module.
                    • E
                      Egnos @sdetweil
                      Thanks @sdetweil
                      Let’s see if I understand:
                      • By default the LEDs will be off, until the “MMM-GPIO-Notifications” module detects something.
                      • If the PIR detects the movement the “MMM-GPIO-Notifications” module will send the notification USER_PRESENCE = true and the LEDs will turn on
                      • After some time without movement the “MMM-GPIO-Notifications” module will send the notification USER_PRESENCE = false and the LEDs will turn off
                      Correct?
                      I’m not a developer, but I’m still trying to understand your change in the code:
                      else if (notification === ' USER_PRESENCE'){
                                  if(payload == false){
                                      this.leds.allOFF();
                                  } else {
                                      // user present, restore the last active sequence
                                      Promise.resolve(this.runSequence(this.lastSequence.sequence, thi,lastSequence.iterations,this.lastSequence.delay)
                                      .catch((err) => {
                                          this.log('user present Sequence error: ' + err.message);
                      why can’t I see this notification in the code?
                                  if(payload == true){
                                      this.leds.allON();
                      Thanks again!
                      M S 3 Replies Last reply
                        MMRIZE @Egnos
                        @Egnos
                        ' USER_PRESENCE' !== 'USER_PRESENCE'
                          sdetweil @Egnos
                          @Egnos fixed the typo, git pull for the update
                            sdetweil @MMRIZE
                            @MMRIZE good catch
                              sdetweil @Egnos
                              @Egnos u don’t need the GPIO_Notifications module. as the PIR modules send the USER_PRESENCE notification
                              • E
                                Egnos @sdetweil
                                u don’t need the GPIO_Notifications module. as the PIR modules send the USER_PRESENCE notification:
                                The module I use for sending notifications when the PIR detects motion is MMM-GPIO-Notifications
                                I believe he is sending the “USER_PRESENCE” notification:
                                notifications: [
                                              notification: 'USER_PRESENCE',
                                              payload: true
                                Thanks for your patience @sdetweil ! ;-)
                                  sdetweil @Egnos
                                  @Egnos ok got it.
                                  what I was saying is that the
                                  MMM-PIR-???
                                  modules, if you use them, THEY send the USER_PRESENCE notification
                                  the GPIO_Notifcations module is more generic and can send notifications for ANY gpio device
                                  • E
                                    Egnos @sdetweil
                                    @Egnos ok got it.
                                    MMM-PIR-???
                                    Ok ok, I just wanted to be sure that, in my case, the MMM-GPIO-Notifications module sends the “USER_PRESENCE” notification.
                                    I knew that the module I am using is a collector of GPIO devices…
                                    Thanks @sdetweil
                                    O 1 Reply Last reply
                                    • O
                                      OberfragGER @Egnos
                                      @Egnos Just in case…
                                      Im using ioBroker @home (thats a free Smart Home Software). WIth that i also have installed MQTT. Any other Smart Home software like Home Assist can do the same.
                                      I also installed Hyperion on the same Raspyberry i have installed MagicMirror. Inside ioBroker iam using the Hyperion adapter.
                                      So with any “user_presence” i get the MQTT informartion… and that triggers a scipt inside ioBroker to activate Hyperion.
                                      If your using any smart home software as well… this should be an easy thing. Feel free to ask…
                                      • E
                                        Egnos @OberfragGER
                                        @OberfragGER thanks for the valuable advice and for your availability, now I’ll read something.
                                        In the meantime, can you tell me an LED strip (not necessarily RGB …) that is compatible with this project?
                                        Thank you all.
                                        • O
                                          OberfragGER @Egnos
                                          @Egnos I have to add… i use also the Module https://github.com/olexs/MMM-UserPresenceToMQTT
                                          For the LED-Strip… i use a WS2812. Its adessable an u can use it with 5V and it preconfigured in Hyperion.
                                          • E
                                            Egnos
                                            @OberfragGER said in PIR sensor to turn on LED strip:
                                            Where did you buy the LED strip? They seem very expensive …
                                            I have seen the connection between RPI and LED strip but I do not understand why the external 5V power supply must also be connected to the RPI, is it not enough to connect it to the LED strip?
                                            If I really have to connect the power supply to the RPI as well, how do you do if you have both PINs of the 5V GPIO occupied?
