    PIR sensor to turn on LED strip
    35 Posts 6 Posters 16.3k Views 6 Watching
      sdetweil @Egnos
      @Egnos it has a way for all off. but not all on.
        sdetweil @Egnos
        @Egnos use my updated fork…
        https://github.com/sdetweil/MMM-PiLights
        it responds to the PIR modules USER_PRESENCE notification (true = turn on, false = turn off)
        if lights are off and on is sent, it will restore the previous sequence set with the normal
        SEQUENCE notification
        E 1 Reply Last reply
        • wishmaster270W
          wishmaster270 Module Developer
          I would suggest the solution of @sdetweil as well.
          An other, but much more complicate version would be to use my PythonLedControl and control it with the MMM-MQTTbridge module.
          • E
            Egnos @sdetweil
            @sdetweil said in PIR sensor to turn on LED strip:
            Thanks @sdetweil
            Let’s see if I understand:
            • By default the LEDs will be off, until the “MMM-GPIO-Notifications” module detects something.
            • If the PIR detects the movement the “MMM-GPIO-Notifications” module will send the notification USER_PRESENCE = true and the LEDs will turn on
            • After some time without movement the “MMM-GPIO-Notifications” module will send the notification USER_PRESENCE = false and the LEDs will turn off
            Correct?
            I’m not a developer, but I’m still trying to understand your change in the code:
            else if (notification === ' USER_PRESENCE'){
                        if(payload == false){
                            this.leds.allOFF();
                        } else {
                            // user present, restore the last active sequence
                            Promise.resolve(this.runSequence(this.lastSequence.sequence, thi,lastSequence.iterations,this.lastSequence.delay)
                            .catch((err) => {
                                this.log('user present Sequence error: ' + err.message);
            why can’t I see this notification in the code?
                        if(payload == true){
                            this.leds.allON();
            Thanks again!
            M S 3 Replies Last reply
              MMRIZE @Egnos
              @Egnos
              ' USER_PRESENCE' !== 'USER_PRESENCE'
                sdetweil @Egnos
                @Egnos fixed the typo, git pull for the update
                  sdetweil @MMRIZE
                  @MMRIZE good catch
                    sdetweil @Egnos
                    @Egnos u don’t need the GPIO_Notifications module. as the PIR modules send the USER_PRESENCE notification
                    • E
                      Egnos @sdetweil
                      u don’t need the GPIO_Notifications module. as the PIR modules send the USER_PRESENCE notification:
                      The module I use for sending notifications when the PIR detects motion is MMM-GPIO-Notifications
                      I believe he is sending the “USER_PRESENCE” notification:
                      notifications: [
                                    notification: 'USER_PRESENCE',
                                    payload: true
                      Thanks for your patience @sdetweil ! ;-)
                        sdetweil @Egnos
                        @Egnos ok got it.
                        what I was saying is that the
                        MMM-PIR-???
                        modules, if you use them, THEY send the USER_PRESENCE notification
                        the GPIO_Notifcations module is more generic and can send notifications for ANY gpio device
                        • E
                          Egnos @sdetweil
                          @Egnos ok got it.
                          MMM-PIR-???
                          Ok ok, I just wanted to be sure that, in my case, the MMM-GPIO-Notifications module sends the “USER_PRESENCE” notification.
                          I knew that the module I am using is a collector of GPIO devices…
                          Thanks @sdetweil
                          O 1 Reply Last reply
                          • O
                            OberfragGER @Egnos
                            @Egnos Just in case…
                            Im using ioBroker @home (thats a free Smart Home Software). WIth that i also have installed MQTT. Any other Smart Home software like Home Assist can do the same.
                            I also installed Hyperion on the same Raspyberry i have installed MagicMirror. Inside ioBroker iam using the Hyperion adapter.
                            So with any “user_presence” i get the MQTT informartion… and that triggers a scipt inside ioBroker to activate Hyperion.
                            If your using any smart home software as well… this should be an easy thing. Feel free to ask…
                            • E
                              Egnos @OberfragGER
                              @OberfragGER thanks for the valuable advice and for your availability, now I’ll read something.
                              In the meantime, can you tell me an LED strip (not necessarily RGB …) that is compatible with this project?
                              Thank you all.
                              • O
                                OberfragGER @Egnos
                                @Egnos I have to add… i use also the Module https://github.com/olexs/MMM-UserPresenceToMQTT
                                For the LED-Strip… i use a WS2812. Its adessable an u can use it with 5V and it preconfigured in Hyperion.
                                • E
                                  Egnos
                                  @OberfragGER said in PIR sensor to turn on LED strip:
                                  Where did you buy the LED strip? They seem very expensive …
                                  I have seen the connection between RPI and LED strip but I do not understand why the external 5V power supply must also be connected to the RPI, is it not enough to connect it to the LED strip?
                                  If I really have to connect the power supply to the RPI as well, how do you do if you have both PINs of the 5V GPIO occupied?
                                  • E
                                    Egnos @Egnos
                                    I found these https://a.aliexpress.com/_EwF3KTV.
                                    The WS2813 strip is 5V.
                                    Can be fine?
                                    B 1 Reply Last reply
                                      bhepler Module Developer @Egnos
                                      @Egnos - Those look like they’ll do the job.
                                      The reason is that the output of the RPi can drive a handful of LEDs, but the Pi only has so much power flowing through it (specs say 50mA). Powering the LEDs separately will let the Pi handle the logic and the power supply handle the… well, power.
                                      • E
                                        Egnos @bhepler
                                        @bhepler said in PIR sensor to turn on LED strip:
                                        Thanks @bhepler I understood that the LEDs must be powered by an external 5V because the RPI generates a few mA and is not able to turn on an LED strip, but from the photo you can see that the external 5V (+ and -) also goes in parallel on the 5V in exit from the RPI.
                                        For what reason?
                                        Is this connection necessary (I no longer have 5V available on GPIO …)?
                                        Thank you very much
                                        wishmaster270W S 2 Replies Last reply
                                        • wishmaster270W
                                          wishmaster270 Module Developer @Egnos
                                          @Egnos Hi, as the picture says they use the 5V power source of the led strip to power the Pi, too.
                                          Instead of powering the pi via USB they use the 5V GPIO pin.
                                          If you want to power the Pi via USB instead be sure to connect the Ground of the strip with ground of the pi.
                                            sdetweil @Egnos
                                            @Egnos no. they are powering the pi from the 5v gpio pins as well as the LEDs.
                                            the pin is tall.
