    Omxplayer and Bullseye
    21 Posts 4 Posters 5.3k Views 4 Watching
    • plainbrokeP
      plainbroke @Egnos
      @Egnos
      Use sdetweil’s backupRestore module it makes it pretty easy to reinstall it all into a working order and it saves your config.js and custom.css very important in my case I do not want to ever go through all the hours spent trial and error testing to get my mirror the way I wanted it…
      E 1 Reply Last reply
        sdetweil @plainbroke
        @plainbroke buster is the Legacy image
        • E
          Egnos @plainbroke
          @plainbroke said in Omxplayer and Bullseye:
          Thanks @plainbroke for the advise and thanks @sdetweil for creating the script.
          I will install on a new MicroSD Buster and test the operation.
          • E
            Egnos @plainbroke
            I am currently using the latest Buster with 5 different rtsp cameras ( i use carousel) and I have no problems viewing them.
            Do you use a module in particular to view the stream of the cameras or do you launch omxplayer outside the MM?
            plainbrokeP 1 Reply Last reply
            • E
              Egnos
              sdetweil said in Omxplayer and Bullseye:
              What changes from the “normal” version?
              BKeyportB 1 Reply Last reply
              • BKeyportB
                BKeyport Module Developer @Egnos
                @Egnos nothing. It’s just the previous release.
                • plainbrokeP
                  plainbroke @Egnos
                  @Egnos
                  I use MMM-RTSPStream I have 5 separate instances running, without any issues as long as the cameras are up and running.
                  • E
                    Egnos @plainbroke
                    @plainbroke is there a particular reason why you use different instances of the same module instead of multiple streams in configuration (e.g. stream1, stream2, stream3, etc.)?
                    • plainbrokeP
                      plainbroke @Egnos
                      @Egnos
                      I have one camera show at a time using mmm-carousel, they use the full screen one at a time in various places in my line up of modules. I have 40+ modules running on my Mirror .
                       module: "MMM-Carousel",
                       transitionInterval: 43000,
                       ignoreModules: ["MMM-DynamicWeather", "MMM-ModuleScheduler"],
                              mode: "slides",
                              slides: [
                                      ["MMM-CalendarExt3"],
                                      ["calendar", "clock", "compliments"],
                                      ["facts", "clock", "compliments"],
                                      ["iFrame"],
                                      ["MMM-ATM", "clock", "compliments"],
                                      ["MMM-Bored", "clock", "compliments"],
                                      ["MMM-RTSPStream"],
                                      ["MMM-CalvinAndHobbes", "clock", "compliments"],
                                      ["MMM-CloneWarsQuotes", "clock", "compliments"],
                                      ["MMM-Cocktails", "clock", "compliments"],
                                      ["MMM-covid19", "clock", "compliments"],
                                      ["MMM-DailyQuote", "clock", "compliments"],
                                      ["MMM-DarkSkyForecast", "clock", "compliments"],
                                      ["MMM-Dogs", "clock", "compliments"],
                                      ["MMM-DumbAssCatFacts", "clock", "compliments"],
                                      ["MMM-RTSPStream2"],
                                      ["MMM-EARTH", "clock", "compliments"],
                                      ["MMM-Evil", "clock", "compliments"],
                                      ["MMM-EyeCandy", "clock", "compliments"],
                                      ["MMM-Gas", "clock", "compliments"],
                                      ["MMM-GmailFeed", "clock", "compliments"],
                                      ["MMM-History", "clock", "compliments"],
                                      ["MMM-icanhazdadjoke", "clock", "compliments"],
                                      ["MMM-ImagesPhotos", "clock", "compliments"],
                                      ["MMM-RTSPStream3"],
                                      ["MMM-MotionEye"],
                                      ["MMM-MyWordOfTheDay", "clock", "compliments"],
                                      ["MMM-NetworkScanner"],
                                      ["MMM-NFL", "clock", "compliments"],
                                      ["MMM-Oneliner", "clock", "compliments"],
                                      ["MMM-OpenWeatherForecast", "clock", "compliments"],
                                      ["MMM-quote-of-the-day", "clock", "compliments"],
                                      ["MMM-RTSPStream4"],
                                      ["MMM-RAIN-MAP"],
                                      ["MMM-rfacts", "clock", "compliments"],
                                      ["MMM-SimpleLogo", "clock", "compliments"],
                                      ["MMM-SingleStock", "clock", "compliments"],
                                      ["MMM-Todoist", "clock", "compliments"],
                                      ["on-this-day", "clock", "compliments"],
                                      ["random_quotes", "clock", "compliments"],
                                      ["MMM-RTSPStream5"]
                      • E
                        Egnos @plainbroke
                        @Egnos
                        Description: Raspbian GNU/Linux 10 (buster)
                        Release: 10
                        Codename: buster
                        Just my 2 cents. Unless someone much smarter than me can fix Omxplayer in Bullseye. I have resigned myself to stay on Buster until I can’t anymore…
                        Hi @plainbroke , I installed the Buster as per your advice and for now everything works fine! Thanks!
                        I just have some problems with the bluetooth connection between the RPI and the bluetooth speaker (Nest Audio …), after a certain time of inactivity of a few hours the bluetooth disconnects!
                        Have you also had this problem with you?
                        • plainbrokeP
                          plainbroke @Egnos
                          @Egnos
                          Sorry, I do not use the bluetooth feature at all on my MM, so I am of no help in that area…
