    Omxplayer and Bullseye
    21 Posts 4 Posters 5.3k Views 4 Watching
    • E
      Egnos @sdetweil
      @sdetweil in fact mine was a joke!
      So which OS does the least damage?
      • plainbrokeP
        plainbroke @Egnos
        @Egnos
        I am currently using the latest Buster with 5 different rtsp cameras ( i use carousel) and I have no problems viewing them.
        Description: Raspbian GNU/Linux 10 (buster)
        Release: 10
        Codename: buster
        Just my 2 cents. Unless someone much smarter than me can fix Omxplayer in Bullseye. I have resigned myself to stay on Buster until I can’t anymore…
        S E 3 Replies Last reply
        • plainbrokeP
          plainbroke @Egnos
          @Egnos
          Use sdetweil’s backupRestore module it makes it pretty easy to reinstall it all into a working order and it saves your config.js and custom.css very important in my case I do not want to ever go through all the hours spent trial and error testing to get my mirror the way I wanted it…
          E 1 Reply Last reply
            sdetweil @plainbroke
            @plainbroke buster is the Legacy image
            • E
              Egnos @plainbroke
              @plainbroke said in Omxplayer and Bullseye:
              Thanks @plainbroke for the advise and thanks @sdetweil for creating the script.
              I will install on a new MicroSD Buster and test the operation.
              • E
                Egnos @plainbroke
                Do you use a module in particular to view the stream of the cameras or do you launch omxplayer outside the MM?
                plainbrokeP 1 Reply Last reply
                • E
                  Egnos
                  sdetweil said in Omxplayer and Bullseye:
                  What changes from the “normal” version?
                  BKeyportB 1 Reply Last reply
                  • BKeyportB
                    BKeyport Module Developer @Egnos
                    @Egnos nothing. It’s just the previous release.
                    • plainbrokeP
                      plainbroke @Egnos
                      @Egnos
                      I use MMM-RTSPStream I have 5 separate instances running, without any issues as long as the cameras are up and running.
                      • E
                        Egnos @plainbroke
                        @plainbroke is there a particular reason why you use different instances of the same module instead of multiple streams in configuration (e.g. stream1, stream2, stream3, etc.)?
                        • plainbrokeP
                          plainbroke @Egnos
                          @Egnos
                          I have one camera show at a time using mmm-carousel, they use the full screen one at a time in various places in my line up of modules. I have 40+ modules running on my Mirror .
                           module: "MMM-Carousel",
                           transitionInterval: 43000,
                           ignoreModules: ["MMM-DynamicWeather", "MMM-ModuleScheduler"],
                                  mode: "slides",
                                  slides: [
                                          ["MMM-CalendarExt3"],
                                          ["calendar", "clock", "compliments"],
                                          ["facts", "clock", "compliments"],
                                          ["iFrame"],
                                          ["MMM-ATM", "clock", "compliments"],
                                          ["MMM-Bored", "clock", "compliments"],
                                          ["MMM-RTSPStream"],
                                          ["MMM-CalvinAndHobbes", "clock", "compliments"],
                                          ["MMM-CloneWarsQuotes", "clock", "compliments"],
                                          ["MMM-Cocktails", "clock", "compliments"],
                                          ["MMM-covid19", "clock", "compliments"],
                                          ["MMM-DailyQuote", "clock", "compliments"],
                                          ["MMM-DarkSkyForecast", "clock", "compliments"],
                                          ["MMM-Dogs", "clock", "compliments"],
                                          ["MMM-DumbAssCatFacts", "clock", "compliments"],
                                          ["MMM-RTSPStream2"],
                                          ["MMM-EARTH", "clock", "compliments"],
                                          ["MMM-Evil", "clock", "compliments"],
                                          ["MMM-EyeCandy", "clock", "compliments"],
                                          ["MMM-Gas", "clock", "compliments"],
                                          ["MMM-GmailFeed", "clock", "compliments"],
                                          ["MMM-History", "clock", "compliments"],
                                          ["MMM-icanhazdadjoke", "clock", "compliments"],
                                          ["MMM-ImagesPhotos", "clock", "compliments"],
                                          ["MMM-RTSPStream3"],
                                          ["MMM-MotionEye"],
                                          ["MMM-MyWordOfTheDay", "clock", "compliments"],
                                          ["MMM-NetworkScanner"],
                                          ["MMM-NFL", "clock", "compliments"],
                                          ["MMM-Oneliner", "clock", "compliments"],
                                          ["MMM-OpenWeatherForecast", "clock", "compliments"],
                                          ["MMM-quote-of-the-day", "clock", "compliments"],
                                          ["MMM-RTSPStream4"],
                                          ["MMM-RAIN-MAP"],
                                          ["MMM-rfacts", "clock", "compliments"],
                                          ["MMM-SimpleLogo", "clock", "compliments"],
                                          ["MMM-SingleStock", "clock", "compliments"],
                                          ["MMM-Todoist", "clock", "compliments"],
                                          ["on-this-day", "clock", "compliments"],
                                          ["random_quotes", "clock", "compliments"],
                                          ["MMM-RTSPStream5"]
                          • E
                            Egnos @plainbroke
                            @Egnos
                            Release: 10
                            Codename: buster
                            Hi @plainbroke , I installed the Buster as per your advice and for now everything works fine! Thanks!
                            I just have some problems with the bluetooth connection between the RPI and the bluetooth speaker (Nest Audio …), after a certain time of inactivity of a few hours the bluetooth disconnects!
                            Have you also had this problem with you?
                            • plainbrokeP
                              plainbroke @Egnos
                              @Egnos
                              Sorry, I do not use the bluetooth feature at all on my MM, so I am of no help in that area…
