    Omxplayer and Bullseye
    21 Posts 4 Posters 4.5k Views 4 Watching
    • E Offline
      Egnos
      Hi guys,
      since installing Bullseye I have discovered some bad news: “As of Raspbian Bullseye release (as well as RPi4B), omxplayer and the hardware decoding that work hand-in-hand are deprecated and/or unsupported.”
      For now I’m using the “cvlc …” command for locally display RTSP streams from security camera systems.
      I launch the command outside of the MM and I see the picture…as I did before with Omxplayer, but from the terminal i get many errors:
      magicmirror@raspberrypi:~ $ cvlc --no-audio --autoscale --video-on-top rtsp://___________________________/stream1
      VLC media player 3.0.17.4 Vetinari (revision 3.0.13-8-g41878ff4f2)
      [00000055c2e2bb70] dummy interface: using the dummy interface module...
      Created new TCP socket 11 for connection
      [0000007f64016a80] avcodec decoder error: unspecified video dimensions
      libEGL warning: DRI2: failed to authenticate
      [0000007f4c0013e0] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
      [0000007f4c0013e0] mmal_xsplitter vout display error: Failed to open Xsplitter:mmal_vout module
      [0000007f4c07a4b0] chain filter error: Too high level of recursion (3)
      [0000007f4c071510] main filter error: Failed to create video converter
      [0000007f4c078390] main filter error: Failed to create video converter
      [0000007f4c0013e0] main vout display error: Failed to create video converter
      [0000007f4c0013e0] main vout display error: Failed to adapt decoder format to display
      [0000007f5c006960] main video output error: video output creation failed
      [0000007f64016a80] main decoder error: failed to create video output
      [0000007f54001410] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
      [0000007f54001410] mmal_xsplitter vout display error: Failed to open Xsplitter:mmal_vout module
      [0000007f64016a80] main decoder error: Timestamp conversion failed (delay 1000000, buffering 0, bound 9000000)
      [0000007f64016a80] main decoder error: Could not convert timestamp 1662708441772695 for FFmpeg
      [0000007f64016a80] main decoder error: buffer deadlock prevented
      after a day sometimes the camera window disappeared and i get this error:
      [0000007f5c001160] live555 demux error: keep-alive failed: liveMedia5
      Do you have any other ideas?
      Which module to use to view video surveillance?
      Thank you all.
      • plainbrokeP Offline
        plainbroke @Egnos
        @Egnos
        Go back to Buster it all works there. Bullseye and rstp do not really play well in my opinion. VLC is a mess for me in Bullseye. Buster Omxplayer works again with rtsp… Wish someone much smarter than me could fix that problem with Bullseye. I went as far back as Stretch to get a wireless dongle to work with one of my RPi’s…
        • E Offline
          Egnos @plainbroke
          Thanks @plainbroke which version of buster do you recommend? The last One?
          Is there a quick way to transfer the modules to the new MicroSD … without having to re-download all the modules again?
          BKeyportB plainbrokeP 3 Replies Last reply Reply Quote 0
          • BKeyportB Offline
            BKeyport Module Developer @Egnos
            @Egnos sadly, I wouldn’t even recommend Buster. OMX crashes everything regularly here. I’ve taken to using the camera’s snapshot feature, and MMM-Proxyimage to display a frame every two seconds to keep things stable.
            From my point of view, it’s been a race to see who can bloat out the most lately, electron, camera providers, etc. Leaving our poor little hobby computers in the dust.
            • E Offline
              Egnos @BKeyport
              @BKeyport so would you go on a Stretch?
                sdetweil @Egnos
                @Egnos latest node/npm don’t work on stretch, and thus electron
                • E Offline
                  Egnos @sdetweil
                  Windows?! 🤣
                    sdetweil @Egnos
                    @Egnos most of the GPIO stuff doesn’t work on windows…
                    • E Offline
                      Egnos @sdetweil
                      @sdetweil in fact mine was a joke!
                      So which OS does the least damage?
                        plainbroke @Egnos
                        @Egnos
                        I am currently using the latest Buster with 5 different rtsp cameras ( i use carousel) and I have no problems viewing them.
                        Description: Raspbian GNU/Linux 10 (buster)
                        Release: 10
                        Codename: buster
                        Just my 2 cents. Unless someone much smarter than me can fix Omxplayer in Bullseye. I have resigned myself to stay on Buster until I can’t anymore…
                        S E 3 Replies Last reply Reply Quote 0
                          plainbroke @Egnos
                          @Egnos
                          Use sdetweil’s backupRestore module it makes it pretty easy to reinstall it all into a working order and it saves your config.js and custom.css very important in my case I do not want to ever go through all the hours spent trial and error testing to get my mirror the way I wanted it…
                            sdetweil @plainbroke
                            @plainbroke buster is the Legacy image
                            • E Offline
                              Egnos @plainbroke
                              @plainbroke said in Omxplayer and Bullseye:
                              Thanks @plainbroke for the advise and thanks @sdetweil for creating the script.
                              I will install on a new MicroSD Buster and test the operation.
                              • E Offline
                                Egnos @plainbroke
                                Do you use a module in particular to view the stream of the cameras or do you launch omxplayer outside the MM?
                                • E Offline
                                  Egnos
                                  sdetweil said in Omxplayer and Bullseye:
                                  What changes from the “normal” version?
                                  • BKeyportB Offline
                                    @Egnos nothing. It’s just the previous release.
                                      plainbroke @Egnos
                                      @Egnos
                                      I use MMM-RTSPStream I have 5 separate instances running, without any issues as long as the cameras are up and running.
                                      • E Offline
                                        Egnos @plainbroke
                                        @plainbroke is there a particular reason why you use different instances of the same module instead of multiple streams in configuration (e.g. stream1, stream2, stream3, etc.)?
                                          plainbroke @Egnos
                                          @Egnos
                                          I have one camera show at a time using mmm-carousel, they use the full screen one at a time in various places in my line up of modules. I have 40+ modules running on my Mirror .
                                           module: "MMM-Carousel",
                                           transitionInterval: 43000,
                                           ignoreModules: ["MMM-DynamicWeather", "MMM-ModuleScheduler"],
                                                  mode: "slides",
                                                  slides: [
                                                          ["MMM-CalendarExt3"],
                                                          ["calendar", "clock", "compliments"],
                                                          ["facts", "clock", "compliments"],
                                                          ["iFrame"],
                                                          ["MMM-ATM", "clock", "compliments"],
                                                          ["MMM-Bored", "clock", "compliments"],
                                                          ["MMM-RTSPStream"],
                                                          ["MMM-CalvinAndHobbes", "clock", "compliments"],
                                                          ["MMM-CloneWarsQuotes", "clock", "compliments"],
                                                          ["MMM-Cocktails", "clock", "compliments"],
                                                          ["MMM-covid19", "clock", "compliments"],
                                                          ["MMM-DailyQuote", "clock", "compliments"],
                                                          ["MMM-DarkSkyForecast", "clock", "compliments"],
                                                          ["MMM-Dogs", "clock", "compliments"],
                                                          ["MMM-DumbAssCatFacts", "clock", "compliments"],
                                                          ["MMM-RTSPStream2"],
                                                          ["MMM-EARTH", "clock", "compliments"],
                                                          ["MMM-Evil", "clock", "compliments"],
                                                          ["MMM-EyeCandy", "clock", "compliments"],
                                                          ["MMM-Gas", "clock", "compliments"],
                                                          ["MMM-GmailFeed", "clock", "compliments"],
                                                          ["MMM-History", "clock", "compliments"],
                                                          ["MMM-icanhazdadjoke", "clock", "compliments"],
                                                          ["MMM-ImagesPhotos", "clock", "compliments"],
                                                          ["MMM-RTSPStream3"],
                                                          ["MMM-MotionEye"],
                                                          ["MMM-MyWordOfTheDay", "clock", "compliments"],
                                                          ["MMM-NetworkScanner"],
                                                          ["MMM-NFL", "clock", "compliments"],
                                                          ["MMM-Oneliner", "clock", "compliments"],
                                                          ["MMM-OpenWeatherForecast", "clock", "compliments"],
                                                          ["MMM-quote-of-the-day", "clock", "compliments"],
                                                          ["MMM-RTSPStream4"],
                                                          ["MMM-RAIN-MAP"],
                                                          ["MMM-rfacts", "clock", "compliments"],
                                                          ["MMM-SimpleLogo", "clock", "compliments"],
                                                          ["MMM-SingleStock", "clock", "compliments"],
                                                          ["MMM-Todoist", "clock", "compliments"],
                                                          ["on-this-day", "clock", "compliments"],
                                                          ["random_quotes", "clock", "compliments"],
                                                          ["MMM-RTSPStream5"]
                                          • E Offline
                                            Egnos @plainbroke
                                            @Egnos
                                            Release: 10
                                            Codename: buster
                                            Hi @plainbroke , I installed the Buster as per your advice and for now everything works fine! Thanks!
                                            I just have some problems with the bluetooth connection between the RPI and the bluetooth speaker (Nest Audio …), after a certain time of inactivity of a few hours the bluetooth disconnects!
                                            Have you also had this problem with you?
