    Led strip problem
    20 Posts 4 Posters 6.7k Views 4 Watching
      Anthony Project Sponsor
      Hello everyone. I just finished my MM and I have a problem with my WS2812B led strip. It is powered from an external power supply and I use arduino uno for the effects which also is powered by another power supply. When I hooked everything in the MM frame I tested the led strip and was working fine. But when I turn on the TV, the led strip is starting doing crazy things like flickering, turn off, etc. Keep in mind that my tv is an old one. I am mentioning that because the led strip is doing the crazy things not when I push the on button on the TV but when the screen turns on (it needs about 10sec for the screen to show picture). It is like something happens when the screen turns on. I don’t think it has to do with power bacause beside that everything is pluged into a hub, every board has it’s own power supply. Maybe some “noise-waves” from TV panel confuses arduino? Have enyone face something like that? Any opinions will be appreciated. Thank you in advance.
        sdetweil @Anthony
        @Anthony do all the power sources share a common ground? or are they all separate?
          Anthony Project Sponsor @sdetweil
          @sdetweil Thank you for your reply. I have a power hub (I am sorry for my English but I am Greek so some words are difficult ro translate so I have the link to see the picture of it) where everything is plugged in. I don’t know if that is what you mean.
            sdetweil @Anthony
            @Anthony on the output of the power supplies is a +5 or +12 and a ground…
            are all the grounds connected together at some point or are they all separate… usually to stop interference like this you need to bind the grounds…
            the input side has them grounded together… but not the output side
              @sdetweil oh sorry. on the power supply which powers the arduino I have also connect 2 small 12v fans. So the grounds of the fans and the ground of arduino yes they are common. Do you think this is the problem? So if disconnect the fans the leds should work? but why this is not happening from the beggining and it happens only when the screen turns on?
              • BKeyportB Offline
                BKeyport Module Developer @Anthony
                @Anthony I suspect the driver for the TV is emitting radio noise, which the leads for the WS2812 is picking up as data.
                Did you power both ends of the LED strip? It’s good practice unless the strip is very short. This will do two things, first, ensure level LED color throughout the strip, and second, help the data line recognize it’s data over the noise.
                There may be other things you can do to improve the data control. If you know anyone in the amateur (ham) radio community, you may be able to ask them about Radio Frequency Interference. They have the knowledge to help you isolate the issue and solve it.
                  Anthony Project Sponsor @BKeyport
                  @BKeyport No. The led strip has 30 leds per meter and I use 59 leds so it is 2 meter long and I have powered it only from one side with a 5v power supply. I read somewhere that a common problem is if HDMI cable is too close to power plug this happens and that they should be at least 30cm away from each other. My TV’s hdmi is just below from the power hub. I think I will disconnect everything and reconnect-test one by one and I hope I will locate the problem.
                  BKeyportB B 2 Replies Last reply Reply Quote 0
                  • BKeyportB Offline
                    @Anthony You might consider somehow powering both ends. You’ll find better performance of the string because it’s that long.
                      bhepler Module Developer @Anthony
                      @Anthony - In my CNC work I have run into a lot of electromagnetic interference. One thing that has helped a bit is to add ferrite cores to most of my input wires at both ends. Especially any USB wires.
                      Your friendly electronics shop should have something like these.
                      BKeyportB A 2 Replies Last reply Reply Quote 0
                      • BKeyportB Offline
                        BKeyport Module Developer @bhepler
                        @bhepler a lot of times in longer runs, the data line on the strip itself is the antenna.
                          Anthony Project Sponsor @bhepler
                          @bhepler That is a very good idea I will definetly try it. I hope I will find those ferrite cores in one of my local electronic stores. Thank you for your reply.
                            @BKeyport thank you for your reply. I don’t know how to power both ends of led strip. Can it be done from the same power supply? For example I should have 2 wires for 5v, 2 wires for ground and 2 wires for data and one of each must be connected to each end? If not please advice how can it be done.
                            • BKeyportB Offline
                              @Anthony It can be done with the same power supply. just the power and ground to be hooked up. 2 power - one to each end, 2 ground - one to each end.
                                sdetweil @BKeyport
                                @BKeyport unrelated to his problem, I have led strip under my kitchen cabinets. the long one has a problem of burning out the connector , but it’s only powered from one side.
                                so you are saying I could connect power to the other end as well? never seen this shown before.
                                LEDwholesalers 16.4 Feet (5 Meter) Flexible LED Light Strip with 300xSMD3528 and Adhesive Back, 12 Volt, Warm White 2700K, 2026WW-27K https://a.co/d/g8l12v2
                                these are my light strips
                                • BKeyportB Offline
                                  @sdetweil Short answer: Likely.
                                  Long answer:
                                  Here’s a simplified drawing of how most LED strips are “wired” up. Data line is included for Anthony’s issue.
                                  Power is distributed equally across each LED, each LED drains their current accordingly, and it returns via ground.
                                  As the strip you showed is cuttable, it would appear that it’s wired in the same way, although it’s unclear from the pictures on the website. A few LED strips are wired in series, and then it wouldn’t work backwards.
                                  By powering both ends you get two results - less current (heat!) on the connectors as they’re sharing the load, and more consistent lighting along the strip (in extremely long runs, you’d lose some brightness in the middle still, but)
                                  If you want to test, it’s easy to do. Hook up the power supply to the output end, just making sure the power is on power and the ground is on ground. (if there’s a data line, leave it on the input end, as the data line can’t travel backwards. (Technical reasons I won’t get into here)
                                    sdetweil @BKeyport
                                    @BKeyport thx. no data line, just power & ground. right now I just soldered the leads on to one end. got to find another clip on to try the other. there is power over there, for the third strip, so can add leads to the back of the long strip. less heat would be a good outcome
                                    • BKeyportB Offline
                                      @sdetweil for the test, don’t have the input end connected, FWIW. Forgot that part. If it lights with just the output end connected, you’ve got the standard setup.
                                        @BKeyport , @sdetweil I found the answer to my problem. By moving places to the components I found out the arduino board was too close to a coil from TV’s power circuit board and that was the one which caused the problem. I screwed arduino at the opposite side which a decent distance from the coil and everything worked fine. But I will also try what @BKeyport suggested by ppowering the strip from both ends. So @BKeyport only power and ground on both ends and data only on one end right?
                                        • BKeyportB Offline
                                          @Anthony correct. leave the data disconnected on the far end.
                                            @BKeyport Thank you very much.
