    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 136.2k Views 38 Watching
      Doudy @maxxxxpower
      I display with MMM-SmartWebDisplay the maps of
      ‘http://maps.meteoradar.co.uk/’ with two different zooms. No problem with that.
      I also use the MMM-domoticz which shows me the rain forecast.
      My question :
      Is it possible when the% rain is less than 20%, for example, not to display the maps in SmartWebDisplay OR to display something else, for example.
      • A
        AgP42 Project Sponsor Module Developer @Doudy
        @Doudy
        To do so, you can ask your domiticz system to send a new url request according to the humidity value.
        See https://github.com/AgP42/MMM-SmartWebDisplay#change-the-url for the synthaxe of the request to be sent.
        But no, the module itself don’t have an input for any “logical” behavior.
          Doudy @AgP42
          @AgP42 “But no, the module itself don’t have an input for any “logical” behavior.”
          Damage
          :crying_face:
          • BKeyportB
            BKeyport Module Developer
            Is there any way to kill the refresh animation (Fade in/out)? I generally hate animation on everything. It’s annoying. Just refresh.
            EDIT: I’ve given up on the module due to finding a better solution, no need to host a webpage to set up what I needed, and no fading in/out…
              costascontis @BKeyport
              @BKeyport said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
              can you share the better solution?
              • BKeyportB
                Sure, I’m using MMM-HTMLSnippet now.
                • F
                  fillilutten
                  If I send a HTTP request via MMM-Remote-Control with an direct url to an .gif. Would work and play?
                  • TazDevT
                    TazDev @peterh
                    @peterh said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                    50%
                    remove the space before the percent sign: 50% vs 50 %
                    • L
                      lmhmm
                      Sorry if this has been covered before but I’ve just tried several css parameters to try to scroll the webpage down by 100-400 px. Lots of things moved the actual iframe around the mirror to certain degrees but the actual web page inside was not affected no matter what I did.
                      If anyone can advise the correct css ?under iframe? To use please?
                      I had high hopes for margin height but either - or + nothing changes …
                      Dooohhh any help appreciated sick of manually scrolling web page to position. When I do it stays there and only see the bit I want refreshing great.
                      Thanks,
                      Lorraine
                        BigSky
                        Can anyone advise how I might be able to grant microphone access for a webpage being displayed via this module? The page is here: https://unitydemos.frostweepgames.com/assetstore/microphone-webgl/ and they’ve provided a button to request permission but it’s not working on the pi. I’m trying to use this page as a test to determine if a simple Unity project compiled for webGL with audio input / output can be displayed as a magic mirror module. Thanks in advance for any suggestions!
                        • A
                          alex2
                          has anyone tried using this module with an axis camera? I have two cameras I want to rotate on my display. all i get is the message saying “update requested at…”
                          • 5 / 5
