    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 137.7k Views 38 Watching
      pdawg17 @sdetweil
      @sdetweil said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
      @pdawg17 ok, I don’t know the module, but I ‘think’ it displays ANOTHER web page ON the MM screen… (according to the readme)
      MMM-SmartWebDisplay is a module for MagicMirror². It allow to display any web content to your MagicMirror and interact with it(the web content) through notifications or with MMM-TelegramBot.
      so, I’m not sure U access it via the MM web page url…
      now, remote control is also not a web page access tool…
      you can SEND it requests and it will do the action…
      Ok I’ve got it working but not with the website I want to use. I can get YouTube videos to work now but not this site:
      https://www.wunderground.com/dashboard/pws/KCASANMA271
        CutiePatootie
        So last night, I had this module running perfectly along with all my other modules. This morning, I’m getting errors on all the site images stating “This browser does not support svg”. No images display and they are a mixture of svgs and pngs.
        I’d made a copy of an existing website using HTTrack and I’m hosting it locally using Apache2. I’m not familiar with how MagicMirror renders pages so I’m not really sure where to look or what to change to resolve this issue.
        Edit: Not sure how, but the referring page was one level deeper and had to be referenced correctly. Fixed!
        • E
          Egnos
          Hello everybody,
          I am going crazy to find ways to disable audio from this module.
          It’s possible?
          If yes, how?
          Thank you.
          A 1 Reply Last reply
            costascontis
            hello,is there a way to resize iframe and still shows all of my camera’s screen area?If i resize iframe window using config it just crop my camera’s view.My cam’s screen is 640x480 and to view it all i have to set the iframe to 640x480 too.Thats to big for my mirror…
            M 1 Reply Last reply
            • A
              AgP42 Project Sponsor Module Developer @Egnos
              @Egnos said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
              Hello everybody,
              It’s possible?
              If yes, how?
              Thank you.
              from the module itself : no it is not managed.
              But it depend the kind of source you are playing, if it is YouTube, you just have to click on the “Mute” button on the YouTube interface !
                maxxxxpower @costascontis
                @costascontis @AgP42 Same issue here. Adjusting any of the variables, either by percent or pixel, just seems to resize the window, but not the feed itself. It doesn’t zoom accordingly.
                D 1 Reply Last reply
                  Doudy @maxxxxpower
                  I display with MMM-SmartWebDisplay the maps of
                  ‘http://maps.meteoradar.co.uk/’ with two different zooms. No problem with that.
                  I also use the MMM-domoticz which shows me the rain forecast.
                  My question :
                  Is it possible when the% rain is less than 20%, for example, not to display the maps in SmartWebDisplay OR to display something else, for example.
                  • A
                    AgP42 Project Sponsor Module Developer @Doudy
                    @Doudy
                    To do so, you can ask your domiticz system to send a new url request according to the humidity value.
                    See https://github.com/AgP42/MMM-SmartWebDisplay#change-the-url for the synthaxe of the request to be sent.
                    But no, the module itself don’t have an input for any “logical” behavior.
                      Doudy @AgP42
                      @AgP42 “But no, the module itself don’t have an input for any “logical” behavior.”
                      Damage
                      :crying_face:
                      • BKeyportB
                        BKeyport Module Developer
                        Is there any way to kill the refresh animation (Fade in/out)? I generally hate animation on everything. It’s annoying. Just refresh.
                        EDIT: I’ve given up on the module due to finding a better solution, no need to host a webpage to set up what I needed, and no fading in/out…
                        C 1 Reply Last reply
                          costascontis @BKeyport
                          @BKeyport said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                          can you share the better solution?
                          • BKeyportB
                            Sure, I’m using MMM-HTMLSnippet now.
                            • F
                              fillilutten
                              If I send a HTTP request via MMM-Remote-Control with an direct url to an .gif. Would work and play?
                              • TazDevT
                                TazDev @peterh
                                @peterh said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                50%
                                remove the space before the percent sign: 50% vs 50 %
                                • L
                                  lmhmm
                                  Sorry if this has been covered before but I’ve just tried several css parameters to try to scroll the webpage down by 100-400 px. Lots of things moved the actual iframe around the mirror to certain degrees but the actual web page inside was not affected no matter what I did.
                                  If anyone can advise the correct css ?under iframe? To use please?
                                  I had high hopes for margin height but either - or + nothing changes …
                                  Dooohhh any help appreciated sick of manually scrolling web page to position. When I do it stays there and only see the bit I want refreshing great.
                                  Thanks,
                                  Lorraine
                                    BigSky
                                    Can anyone advise how I might be able to grant microphone access for a webpage being displayed via this module? The page is here: https://unitydemos.frostweepgames.com/assetstore/microphone-webgl/ and they’ve provided a button to request permission but it’s not working on the pi. I’m trying to use this page as a test to determine if a simple Unity project compiled for webGL with audio input / output can be displayed as a magic mirror module. Thanks in advance for any suggestions!
                                    • A
                                      alex2
                                      has anyone tried using this module with an axis camera? I have two cameras I want to rotate on my display. all i get is the message saying “update requested at…”
                                      • 5 / 5
