    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 136.2k Views 38 Watching
      costascontis
      hello,is there a way to resize iframe and still shows all of my camera’s screen area?If i resize iframe window using config it just crop my camera’s view.My cam’s screen is 640x480 and to view it all i have to set the iframe to 640x480 too.Thats to big for my mirror…
      • A
        AgP42 Project Sponsor Module Developer @Egnos
        @Egnos said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
        Hello everybody,
        I am going crazy to find ways to disable audio from this module.
        It’s possible?
        If yes, how?
        Thank you.
        from the module itself : no it is not managed.
        But it depend the kind of source you are playing, if it is YouTube, you just have to click on the “Mute” button on the YouTube interface !
          maxxxxpower @costascontis
          @costascontis @AgP42 Same issue here. Adjusting any of the variables, either by percent or pixel, just seems to resize the window, but not the feed itself. It doesn’t zoom accordingly.
            Doudy @maxxxxpower
            I display with MMM-SmartWebDisplay the maps of
            ‘http://maps.meteoradar.co.uk/’ with two different zooms. No problem with that.
            I also use the MMM-domoticz which shows me the rain forecast.
            My question :
            Is it possible when the% rain is less than 20%, for example, not to display the maps in SmartWebDisplay OR to display something else, for example.
            • A
              AgP42 Project Sponsor Module Developer @Doudy
              @Doudy
              To do so, you can ask your domiticz system to send a new url request according to the humidity value.
              See https://github.com/AgP42/MMM-SmartWebDisplay#change-the-url for the synthaxe of the request to be sent.
              But no, the module itself don’t have an input for any “logical” behavior.
                Doudy @AgP42
                @AgP42 “But no, the module itself don’t have an input for any “logical” behavior.”
                Damage
                :crying_face:
                • BKeyportB
                  BKeyport Module Developer
                  Is there any way to kill the refresh animation (Fade in/out)? I generally hate animation on everything. It’s annoying. Just refresh.
                  EDIT: I’ve given up on the module due to finding a better solution, no need to host a webpage to set up what I needed, and no fading in/out…
                    costascontis @BKeyport
                    @BKeyport said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                    can you share the better solution?
                    • BKeyportB
                      Sure, I’m using MMM-HTMLSnippet now.
                      • F
                        fillilutten
                        If I send a HTTP request via MMM-Remote-Control with an direct url to an .gif. Would work and play?
                        • TazDevT
                          TazDev @peterh
                          @peterh said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                          50%
                          remove the space before the percent sign: 50% vs 50 %
                          • L
                            lmhmm
                            Sorry if this has been covered before but I’ve just tried several css parameters to try to scroll the webpage down by 100-400 px. Lots of things moved the actual iframe around the mirror to certain degrees but the actual web page inside was not affected no matter what I did.
                            If anyone can advise the correct css ?under iframe? To use please?
                            I had high hopes for margin height but either - or + nothing changes …
                            Dooohhh any help appreciated sick of manually scrolling web page to position. When I do it stays there and only see the bit I want refreshing great.
                            Thanks,
                            Lorraine
                              BigSky
                              Can anyone advise how I might be able to grant microphone access for a webpage being displayed via this module? The page is here: https://unitydemos.frostweepgames.com/assetstore/microphone-webgl/ and they’ve provided a button to request permission but it’s not working on the pi. I’m trying to use this page as a test to determine if a simple Unity project compiled for webGL with audio input / output can be displayed as a magic mirror module. Thanks in advance for any suggestions!
                              • A
                                alex2
                                has anyone tried using this module with an axis camera? I have two cameras I want to rotate on my display. all i get is the message saying “update requested at…”
                                • 5 / 5
