    Display different Roomtemperature on MagicMirror
    31 Posts 4 Posters 16.7k Views 4 Watching
    • XilefX Offline
      Xilef @wishmaster270
      @wishmaster270 Thanks for your reply.
      @wishmaster270 said in Display different Roomtemperature on MagicMirror:
      Do you plan to power the devices with a power supply or do they need to run on battery?
      Mostly on power supplys
      In general, I would think your solution would work for me, but the big problem is, if i buy like an EPS8266/ESP32 and BME280/HTU21 sensor, i can solder them together, but i have no idea how to set up the software.
      Im glad that i managed it to run Weather, Calendar and an RSS-Feed on my Mirror. But I don’t know much more than that. If there were step-by-step instructions, I would definitely be able to do it, but I don’t think there is one for exactly my needs.
      I would definitely try to do it, but i need help i guess.
        sdetweil @Xilef
        @Xilef esp8266, see the instructables.com site
        also download the Arduino ide to create and load sw on the device.
        I capture the temp and push it to a local server running and http server. you can also use Matt to push
        XilefX 1 Reply Last reply Reply Quote 0
        • XilefX Offline
          Xilef @sdetweil
          @sdetweil no idea what you are talking about after Arduino ide xD but thanks anyway
          I think I will first order an ESP8226 and see if I can set it up/play a sample program on it, with the help of an YT Tutorial. And then Im trying to connect it with the sensor and display the data on the Mirror using an http server
          and it would be cool if someone would upvote my posts so that they arent dumped into the moderation queue
            sdetweil @Xilef
            @Xilef https://docs.arduino.cc/software/ide-v2/tutorials/getting-started/ide-v2-downloading-and-installing
            that’s for programming the ESP8266
            • XilefX Offline
              Xilef @sdetweil
              @sdetweil thx
              • wishmaster270W Offline
                wishmaster270 Module Developer @Xilef
                @Xilef
                ESP8266 is a good choice. I prefer ESP32 cause it has more power but does not need that much more energy. You have a lot more GPIOs with a ESP32 than a with the ESP8266.
                I can provide you a ESP32 sketch which is ready to flash and only needs the Wifi-SSID, Wifi-Password and the MQTT parameters configured.
                I use the Arduino IDE to flash the boards.
                • XilefX Offline
                  @wishmaster270 thanks
                  As I understand it, something like this is my target:
                  And i would need:
                  • ESP32
                  • DHT11-Sensor Problem with this Sensor is the accuracy i think, but if it works I can swap them out I guess
                  • BreadBoard
                  And as Powersupply something with 5V and 1-1,5A right?
                  I would probably do it like this guy on youtube https://www.youtube.com/watch?v=ebJpXs2-WgM&list=PLUwa0e4GQGhS6KCSbLAQGog4_Z7eIWOm3&index=3
                  And from the ESP32-Website the MagicMirror should be able to read the data and display it
                    @Xilef
                    You need a ESP32 ( I use a D1 Mini but nearly everyone should be fine)
                    You need a Temperature and Humidity Sensor (BME280 and HTU21 are a lot more accurate and use I2c to communicate with the controller.
                    A Power supply with 5V 1A should be more than enough.
                    That’s how I display my values…
                    The first three are ESP32 the others my thermostats.
                    JerryPJ XilefX 2 Replies Last reply Reply Quote 0
                    • JerryPJ Offline
                      JerryP @wishmaster270
                      @wishmaster270
                      nice…
                      • XilefX Offline
                        @wishmaster270 Thats exactly what i had in mind
                        The BME280 sensors on amazon are a litte expensive so Im think Im order 3 form this shop They have 5 Pins but I think this will work to, on Aliexpress its even cheaper but i have no experience with the shop, and 1-3€ difference is ok i guess
                        And I wanted to ask what power supply you use e.g. just a cell phone charger?
                        I think im gona go with this one and hope that it doesnt explode
                        So if I have everything right this is my shopping list:
                        ESP32
                        BME280
                        Power Supply
                        BreadBoard
                        And then I just have to figure out the programming
                        XilefX wishmaster270W 2 Replies Last reply Reply Quote 0
                        • XilefX Offline
                          Xilef @Xilef
                          Edit: With Power Supply i mean this one: https://www.amazon.de/gp/product/B08LMFBV55/ref=ox_sc_act_title_2?smid=A1XVC08L2WVJCV&psc=1
                            @Xilef Hi, the list sounds good. I use old mobile chargers to power the boards. I have heard that some had problems with mobile chargers but I had no problems for years now.
                            • XilefX Offline
                              Xilef
                              Hey im back @wishmaster270
                              my parts arrived, and after 5 hours of Troubleshooting i was able to achieve this: (with the help of this tutorial)
                              Now i need just a little bit help to display the Temperature and Humidity on my mirror
                                @Xilef
                                thats great news.
                                The screenshot shows that you setup the ESP32 and the sensor correctly.
                                The main problem is that the ESP now displays a webpage.
                                There are two possible ways now. Either you embed the webpage (as it is) into the mirror with a module like MMM-EmbedURL or to get the ESP to display the data machine readable.
                                Maybe the sketch you flashed to the ESP already contains a way to read the data in a different format? Which one did you use?
                                Edit: I think it is this one, am i right? Then there is no easy way.
                                I think i can provide a sketch that is more “mirror friendly” but you will need to set a static IP for the ESP. Is this ok for you?
                                You will need to change to your needs:
                                • ##ADD_WIFI_SSID_HERE
                                • ##ADD_WIFI_PASSWORD_HERE
                                • IPAddress local_IP(192, 168, 0, 2);
                                • IPAddress gateway(192, 168, 0, 1);
                                • IPAddress subnet(255, 255, 255, 0);
                                • IPAddress primaryDNS(192, 168, 0, 1);
                                #include <WiFi.h>
                                #include <Wire.h>
                                #include <Adafruit_Sensor.h>
                                #include <Adafruit_BME280.h>
                                const char* ssid     = "##ADD_WIFI_SSID_HERE";
                                const char* password = "##ADD_WIFI_PASSWORD_HERE";
                                //ENTER STATIC IP OF THE ESP32 BOARD HERE
                                IPAddress secondaryDNS(8, 8, 8, 8);
                                Adafruit_BME280 bme;
                                WiFiServer server(80);
                                void setup()
                                  Wire.begin();
                                  Serial.begin(115200);
                                  if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
                                    Serial.println("STA Failed to configure");
                                  Serial.print("Connecting to ");
                                  Serial.println(ssid);
                                  WiFi.begin(ssid, password);
                                  while (WiFi.status() != WL_CONNECTED) {
                                    delay(500);
                                    Serial.print(".");
                                  Serial.println("");
                                  Serial.println("WiFi connected!");
                                  Serial.print("IP address: ");
                                  Serial.println(WiFi.localIP());
                                  Serial.print("ESP Mac Address: ");
                                  Serial.println(WiFi.macAddress());
                                  Serial.print("Subnet Mask: ");
                                  Serial.println(WiFi.subnetMask());
                                  Serial.print("Gateway IP: ");
                                  Serial.println(WiFi.gatewayIP());
                                  Serial.print("DNS: ");
                                  Serial.println(WiFi.dnsIP());
                                  if (!bme.begin(0x76);) {
                                    Serial.println("Couldn't find sensor!");
                                    while (1);
                                  server.begin();
                                void loop()
                                  float temp = bme.readTemperature();
                                  float tempf = temp * 1.8 + 32;
                                  float rel_hum = bme.readHumidity();
                                  WiFiClient client = server.available();
                                  if (client) {
                                    Serial.println("New Client.");
                                    client.println("{");
                                    client.print("  \"temperature_c\": ");
                                    client.print(temp);
                                    client.println(",");
                                    client.print("  \"temperature_f\": ");
                                    client.print(tempf);
                                    client.print("  \"humidity\": ");
                                    client.print(rel_hum);
                                    client.println("  \"error\": false");
                                    client.println("}");
                                    client.stop();
                                    Serial.println("Client disconnected.");
                                    Serial.println("");
                                  delay(100);
                                You can use netcat to fetch the data:
                                /bin/nc -w3 THE_IP_OF_THE_ESP 80
                                And the result will be something like:
                                   "humidity": 32.61236572265625,
                                   "temperature_c": 25.50150878906249,
                                   "temperature_f": 77.9027158203125,
                                   "error": false
                                This kind of JSON object then can be read by my MMM-Temperature module.
                                S XilefX 2 Replies Last reply Reply Quote 1
                                  sdetweil @wishmaster270
                                  @wishmaster270 I created a sketch for my 8266, which is a json get. returns current temp and humidity.
                                  then I just fetch it when I want, similar to what u did
                                    wishmaster270 Module Developer @sdetweil
                                    @sdetweil Hi Sam, i was to slow with editing my post. The Sketch i provided does exactly that.
                                    • XilefX Offline
                                      @wishmaster270 i think thats a good way to to it
                                      So i need to set it manually in the router settings?
                                      #include <WiFi.h>…
                                      Thats what i need to flash on the esp , right?
                                      idk what that’s supposed to be for
                                      and you have to explain to me in more detail what I should add to the IPs
                                        @Xilef
                                        You can but do not have to set the ip in the router. You either need a free address in the range that is NOT used by your routers DHCP server or maybe there is a setting to provide the device always with the same IP in your router. You then can set this IP for the ESP (as it is not used for any other DHCP device in the future then.
                                        • the local_ip in the sketch is the IP you choose for the ESP (attention the numbers are separated with , and NOT ..
                                        • the gateway is the IP of your router
                                        • the subnet depends on your network but 255,255,255,0 will be fine in the most cases
                                        • the primaryDNS is usually the IP of you router
                                        yes the “include …” part is the one to be flashed to the ESP.
                                        After you flashed the new Sketch to the ESP and booted it you can use the nc command to fetch the data from the shell of the mirror. The temperature module uses this command to get the data so you can make sure to see if it works without the need to install the module first.
                                        • XilefX Offline
                                          @wishmaster270 i guess thats what i need
                                          “Always assign the same IPv4 address to this network device.”
                                          And for the WIFI SSID and Passwort, behind the 2 ## right?
                                          and where do i need to use the nc command? on the esp32 or on the raspberry pi?
                                            @Xilef
                                            Perfect. This is the right setting.
                                            You need to replace the ##, too.
                                            It will look something like:
                                            const char* ssid     = "MY_WIFI_NETWORK";
                                            const char* password = "123ABC456";
                                            IPAddress local_IP(192, 168, 178, 106);
                                            IPAddress gateway(192, 168, 178, 1);
                                            IPAddress primaryDNS(192, 168, 178, 1);
                                            To check if everything is set up correctly you can run:
                                            /bin/nc -w3 192.168.178.106 80
