    Display different Roomtemperature on MagicMirror
    31 Posts 4 Posters 16.7k Views 4 Watching
      sdetweil @Xilef
      @Xilef https://docs.arduino.cc/software/ide-v2/tutorials/getting-started/ide-v2-downloading-and-installing
      that’s for programming the ESP8266
      XilefX 1 Reply Last reply Reply Quote 0
      • XilefX Offline
        Xilef @sdetweil
        @sdetweil thx
        • wishmaster270W Offline
          wishmaster270 Module Developer @Xilef
          @Xilef
          ESP8266 is a good choice. I prefer ESP32 cause it has more power but does not need that much more energy. You have a lot more GPIOs with a ESP32 than a with the ESP8266.
          I can provide you a ESP32 sketch which is ready to flash and only needs the Wifi-SSID, Wifi-Password and the MQTT parameters configured.
          I use the Arduino IDE to flash the boards.
          • XilefX Offline
            Xilef @wishmaster270
            @wishmaster270 thanks
            As I understand it, something like this is my target:
            And i would need:
            • ESP32
            • DHT11-Sensor Problem with this Sensor is the accuracy i think, but if it works I can swap them out I guess
            • BreadBoard
            And as Powersupply something with 5V and 1-1,5A right?
            I would probably do it like this guy on youtube https://www.youtube.com/watch?v=ebJpXs2-WgM&list=PLUwa0e4GQGhS6KCSbLAQGog4_Z7eIWOm3&index=3
            And from the ESP32-Website the MagicMirror should be able to read the data and display it
              @Xilef
              You need a ESP32 ( I use a D1 Mini but nearly everyone should be fine)
              You need a Temperature and Humidity Sensor (BME280 and HTU21 are a lot more accurate and use I2c to communicate with the controller.
              A Power supply with 5V 1A should be more than enough.
              That’s how I display my values…
              The first three are ESP32 the others my thermostats.
              JerryPJ XilefX 2 Replies Last reply Reply Quote 0
              • JerryPJ Offline
                JerryP @wishmaster270
                @wishmaster270
                nice…
                • XilefX Offline
                  @wishmaster270 Thats exactly what i had in mind
                  The BME280 sensors on amazon are a litte expensive so Im think Im order 3 form this shop They have 5 Pins but I think this will work to, on Aliexpress its even cheaper but i have no experience with the shop, and 1-3€ difference is ok i guess
                  And I wanted to ask what power supply you use e.g. just a cell phone charger?
                  I think im gona go with this one and hope that it doesnt explode
                  So if I have everything right this is my shopping list:
                  ESP32
                  BME280
                  Power Supply
                  BreadBoard
                  And then I just have to figure out the programming
                  XilefX wishmaster270W 2 Replies Last reply Reply Quote 0
                  • XilefX Offline
                    Xilef @Xilef
                    Edit: With Power Supply i mean this one: https://www.amazon.de/gp/product/B08LMFBV55/ref=ox_sc_act_title_2?smid=A1XVC08L2WVJCV&psc=1
                      @Xilef Hi, the list sounds good. I use old mobile chargers to power the boards. I have heard that some had problems with mobile chargers but I had no problems for years now.
                      • XilefX Offline
                        Xilef
                        Hey im back @wishmaster270
                        my parts arrived, and after 5 hours of Troubleshooting i was able to achieve this: (with the help of this tutorial)
                        Now i need just a little bit help to display the Temperature and Humidity on my mirror
                          @Xilef
                          thats great news.
                          The screenshot shows that you setup the ESP32 and the sensor correctly.
                          The main problem is that the ESP now displays a webpage.
                          There are two possible ways now. Either you embed the webpage (as it is) into the mirror with a module like MMM-EmbedURL or to get the ESP to display the data machine readable.
                          Maybe the sketch you flashed to the ESP already contains a way to read the data in a different format? Which one did you use?
                          Edit: I think it is this one, am i right? Then there is no easy way.
                          I think i can provide a sketch that is more “mirror friendly” but you will need to set a static IP for the ESP. Is this ok for you?
                          You will need to change to your needs:
                          • ##ADD_WIFI_SSID_HERE
                          • ##ADD_WIFI_PASSWORD_HERE
                          • IPAddress local_IP(192, 168, 0, 2);
                          • IPAddress gateway(192, 168, 0, 1);
                          • IPAddress subnet(255, 255, 255, 0);
                          • IPAddress primaryDNS(192, 168, 0, 1);
                          #include <WiFi.h>
                          #include <Wire.h>
                          #include <Adafruit_Sensor.h>
                          #include <Adafruit_BME280.h>
                          const char* ssid     = "##ADD_WIFI_SSID_HERE";
                          const char* password = "##ADD_WIFI_PASSWORD_HERE";
                          //ENTER STATIC IP OF THE ESP32 BOARD HERE
                          IPAddress secondaryDNS(8, 8, 8, 8);
                          Adafruit_BME280 bme;
                          WiFiServer server(80);
                          void setup()
                            Wire.begin();
                            Serial.begin(115200);
                            if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
                              Serial.println("STA Failed to configure");
                            Serial.print("Connecting to ");
                            Serial.println(ssid);
                            WiFi.begin(ssid, password);
                            while (WiFi.status() != WL_CONNECTED) {
                              delay(500);
                              Serial.print(".");
                            Serial.println("");
                            Serial.println("WiFi connected!");
                            Serial.print("IP address: ");
                            Serial.println(WiFi.localIP());
                            Serial.print("ESP Mac Address: ");
                            Serial.println(WiFi.macAddress());
                            Serial.print("Subnet Mask: ");
                            Serial.println(WiFi.subnetMask());
                            Serial.print("Gateway IP: ");
                            Serial.println(WiFi.gatewayIP());
                            Serial.print("DNS: ");
                            Serial.println(WiFi.dnsIP());
                            if (!bme.begin(0x76);) {
                              Serial.println("Couldn't find sensor!");
                              while (1);
                            server.begin();
                          void loop()
                            float temp = bme.readTemperature();
                            float tempf = temp * 1.8 + 32;
                            float rel_hum = bme.readHumidity();
                            WiFiClient client = server.available();
                            if (client) {
                              Serial.println("New Client.");
                              client.println("{");
                              client.print("  \"temperature_c\": ");
                              client.print(temp);
                              client.println(",");
                              client.print("  \"temperature_f\": ");
                              client.print(tempf);
                              client.print("  \"humidity\": ");
                              client.print(rel_hum);
                              client.println("  \"error\": false");
                              client.println("}");
                              client.stop();
                              Serial.println("Client disconnected.");
                              Serial.println("");
                            delay(100);
                          You can use netcat to fetch the data:
                          /bin/nc -w3 THE_IP_OF_THE_ESP 80
                          And the result will be something like:
                             "humidity": 32.61236572265625,
                             "temperature_c": 25.50150878906249,
                             "temperature_f": 77.9027158203125,
                             "error": false
                          This kind of JSON object then can be read by my MMM-Temperature module.
                          S XilefX 2 Replies Last reply Reply Quote 1
                            sdetweil @wishmaster270
                            @wishmaster270 I created a sketch for my 8266, which is a json get. returns current temp and humidity.
                            then I just fetch it when I want, similar to what u did
                              wishmaster270 Module Developer @sdetweil
                              @sdetweil Hi Sam, i was to slow with editing my post. The Sketch i provided does exactly that.
                              • XilefX Offline
                                @wishmaster270 i think thats a good way to to it
                                @wishmaster270 said in Display different Roomtemperature on MagicMirror:
                                So i need to set it manually in the router settings?
                                #include <WiFi.h>…
                                Thats what i need to flash on the esp , right?
                                idk what that’s supposed to be for
                                and you have to explain to me in more detail what I should add to the IPs
                                  @Xilef
                                  You can but do not have to set the ip in the router. You either need a free address in the range that is NOT used by your routers DHCP server or maybe there is a setting to provide the device always with the same IP in your router. You then can set this IP for the ESP (as it is not used for any other DHCP device in the future then.
                                  • the local_ip in the sketch is the IP you choose for the ESP (attention the numbers are separated with , and NOT ..
                                  • the gateway is the IP of your router
                                  • the subnet depends on your network but 255,255,255,0 will be fine in the most cases
                                  • the primaryDNS is usually the IP of you router
                                  yes the “include …” part is the one to be flashed to the ESP.
                                  After you flashed the new Sketch to the ESP and booted it you can use the nc command to fetch the data from the shell of the mirror. The temperature module uses this command to get the data so you can make sure to see if it works without the need to install the module first.
                                  • XilefX Offline
                                    @wishmaster270 i guess thats what i need
                                    “Always assign the same IPv4 address to this network device.”
                                    And for the WIFI SSID and Passwort, behind the 2 ## right?
                                    and where do i need to use the nc command? on the esp32 or on the raspberry pi?
                                      @Xilef
                                      Perfect. This is the right setting.
                                      You need to replace the ##, too.
                                      It will look something like:
                                      const char* ssid     = "MY_WIFI_NETWORK";
                                      const char* password = "123ABC456";
                                      IPAddress local_IP(192, 168, 178, 106);
                                      IPAddress gateway(192, 168, 178, 1);
                                      IPAddress primaryDNS(192, 168, 178, 1);
                                      To check if everything is set up correctly you can run:
                                      /bin/nc -w3 192.168.178.106 80
                                      • XilefX Offline
                                        @wishmaster270 the “/bin/nc -w3 192.168.178.106 80” command on the serial monitor message line?
                                        I would suggest to remove the clamp behind the ; ??
                                          @Xilef
                                          Sorry, my fault. You need to change line 52 to:
                                          if (!bme.begin(0x76)) {
                                          Copy&Paste mistake of me
                                          • XilefX Offline
                                            @wishmaster270 i installed the module, but i cant display the data
                                            what am i doing wrong, ah the esp32 says he couldnt find a sensor, thats weird
                                            (edit: i tried another one and it worked this time)
