    Pir sensor
    27 Posts 8 Posters 14.1k Views 10 Watching
      If you’re still looking for a working PIR sensor module, I’m using EXT-Pir and it has been great
      https://github.com/bugsounet/EXT-Pir
      T 2 Replies Last reply Reply Quote 0
        sdetweil @tanvir586
        @tanvir586 might be the os firmware, which has reported problems w gpio interrupts
        • T Offline
          tanvir586 @j.e.f.f
          @j-e-f-f Hi do I need MMM-GoogleAssistant for this? Or works on its own?
            j.e.f.f Project Sponsor Module Developer @tanvir586
            @tanvir586 No need for google assistant. Works fine without it.
            • T Offline
              tanvir586 @j.e.f.f
              @j-e-f-f Feb… making another smart mirror soon. I’ll give it a try. Thanks 😊
              • T Offline
                tanvir586 @j.e.f.f
                @j-e-f-f Hi mate. Thinking to install EXT-Pir now. Just one question do I need EXT-Screen to make it work. If yes how can I configure both module? Thanks
                  @tanvir586 no need to install Ext-Screen. You can use Ext-PIR on its own.
                  bugsounetB T 2 Replies Last reply Reply Quote 0
                  • bugsounetB Offline
                    bugsounet Banned @j.e.f.f
                    @j-e-f-f ah ? So cool so! Give me a sample or tuto?
                      MyMirror @tanvir586
                      @tanvir586 said in Pir sensor:
                      @sdetweil it work like https://github.com/paviro/MMM-PIR-Sensor
                      mmm-pir-sensor is not working anymore that’s why I wanted to use the light one. but this one is not working looks like
                      But of course the module still works.7
                      I have this running on my Pi 3b, Bullseye and MM 2.21.0 …
                      • T Offline
                        tanvir586 @j.e.f.f
                        @j-e-f-f Thanks will try soon
                          Peter @MyMirror
                          @MyMirror unfortunately it does not work here.
                          Pi3, Bullseye, MM2.22: PIR-Sensor does not work at all, PIR-Sensor-Light counts down from 15 minutes, but starts again without turning off the screen.
                          No idea what to do.
                          My MM has been working flawlessly for 5 years, but after the new fresh install with 2.22 I am having this problem.
                          Can anybody help?
                          Peter
                          • T Offline
                            tanvir586 @Peter
                            @Peter didn’t worked for me either. Recovered my old sd card with mm 1.19 and MMM-PIR-Sensor installed. Not updating my mm now.
                            • K Offline
                              kaoshunter
                              So I have my PIR working through a python script, from an old install but am using xrandr, which if run in terminal works great, I don’t know scripting well and would like to know if someone could make a module, utilising a PIR and xrandr codes below
                              Monitor off: xrandr --display :0.0 --output HDMI-1 --off
                              Monitor on: xrandr --display :0.0 --output HDMI-1 --rotate left --auto
                                sdetweil @kaoshunter
                                @kaoshunter see MMM-PIR-Sensor-Lite
                                supports xrandr
