    Pir sensor
    27 Posts 8 Posters 14.7k Views 10 Watching
    • T
      tanvir586 @pugsly
      @pugsly I’ll give it a try tomorrow. Thanks
      • T
        tanvir586 @sdetweil
        @sdetweil thanks mate. Will check this in detail once I go home
        • T
          tanvir586
          Thanks guys for your help. But I recovered my old sd card which had magicmirror 2.19 installed. Pir sensor work with that version. I’m back on truck.
            If you’re still looking for a working PIR sensor module, I’m using EXT-Pir and it has been great
            https://github.com/bugsounet/EXT-Pir
            T 2 Replies Last reply
              sdetweil @tanvir586
              @tanvir586 might be the os firmware, which has reported problems w gpio interrupts
              • T
                tanvir586 @j.e.f.f
                @j-e-f-f Hi do I need MMM-GoogleAssistant for this? Or works on its own?
                J 1 Reply Last reply
                  j.e.f.f Project Sponsor Module Developer @tanvir586
                  @tanvir586 No need for google assistant. Works fine without it.
                  T 1 Reply Last reply
                  • T
                    tanvir586 @j.e.f.f
                    @j-e-f-f Feb… making another smart mirror soon. I’ll give it a try. Thanks 😊
                    • T
                      tanvir586 @j.e.f.f
                      @j-e-f-f Hi mate. Thinking to install EXT-Pir now. Just one question do I need EXT-Screen to make it work. If yes how can I configure both module? Thanks
                        @tanvir586 no need to install Ext-Screen. You can use Ext-PIR on its own.
                        bugsounetB T 2 Replies Last reply
                        • bugsounetB
                          bugsounet Banned @j.e.f.f
                          @j-e-f-f ah ? So cool so! Give me a sample or tuto?
                            MyMirror @tanvir586
                            @tanvir586 said in Pir sensor:
                            @sdetweil it work like https://github.com/paviro/MMM-PIR-Sensor
                            mmm-pir-sensor is not working anymore that’s why I wanted to use the light one. but this one is not working looks like
                            But of course the module still works.7
                            I have this running on my Pi 3b, Bullseye and MM 2.21.0 …
                            P 1 Reply Last reply
                            • T
                              tanvir586 @j.e.f.f
                              @j-e-f-f Thanks will try soon
                                Peter @MyMirror
                                @MyMirror unfortunately it does not work here.
                                Pi3, Bullseye, MM2.22: PIR-Sensor does not work at all, PIR-Sensor-Light counts down from 15 minutes, but starts again without turning off the screen.
                                No idea what to do.
                                My MM has been working flawlessly for 5 years, but after the new fresh install with 2.22 I am having this problem.
                                Can anybody help?
                                Peter
                                • T
                                  tanvir586 @Peter
                                  @Peter didn’t worked for me either. Recovered my old sd card with mm 1.19 and MMM-PIR-Sensor installed. Not updating my mm now.
                                  • K
                                    kaoshunter
                                    So I have my PIR working through a python script, from an old install but am using xrandr, which if run in terminal works great, I don’t know scripting well and would like to know if someone could make a module, utilising a PIR and xrandr codes below
                                    Monitor off: xrandr --display :0.0 --output HDMI-1 --off
                                    Monitor on: xrandr --display :0.0 --output HDMI-1 --rotate left --auto
                                      sdetweil @kaoshunter
                                      @kaoshunter see MMM-PIR-Sensor-Lite
                                      supports xrandr
