    Pir sensor
    27 Posts 8 Posters 14.3k Views 10 Watching
      sdetweil @tanvir586
      @tanvir586 what is not working?
      lite is the one that was updated most recently
      • T Offline
        tanvir586 @sdetweil
        @sdetweil I put the countdown for 1 min. but when the countdown start it goes to 54 then it go back to 1 min again.
        my config is
        module: “MMM-PIR-Sensor-Lite”,
        position: “top_right”,
        sensorPin: 2, // GPIO pin
        and the .js is
        defaults: {
        sensorPin: 0, // GPIO pin
        commandType: ‘xrandr’, // Type of command used
        title: “Automatic Standby”,
        rotation: ‘normal’,
        deactivateDelay: 1 * 60 * 1000, // 15 minutes
        updateInterval: 1000, // 1 second
        animationSpeed: 1000, // 1 second
        showCountDown: true,
        showDetection: true,
        hoursLabel: ‘h’,
        minutesLabel: ‘m’,
        secondsLabel: ‘s’,
          sdetweil @tanvir586
          @tanvir586 said in Pir sensor:
          and the .js is
          never edit the module js file
          all config goes in config.js
          I don’t know the module
          does the PIR work outside MM?
          • T Offline
            tanvir586 @sdetweil
            @sdetweil it work like https://github.com/paviro/MMM-PIR-Sensor
            mmm-pir-sensor is not working anymore that’s why I wanted to use the light one. but this one is not working looks like
              sdetweil @tanvir586
              @tanvir586 no, my question was , if u test the PIR connection/setup outside of MM does it work
              using a python script?
              I undertstand how it is SUPPOSED to work , and have tested modules on one of my systems before, but don’t
              use PIR daily
              • T Offline
                tanvir586 @sdetweil
                @sdetweil Hi mate. Sorry I don’t know how to do that. I’m not a programming person. I’m copy past person actually 🤣
                  sdetweil @tanvir586
                  @tanvir586 https://projects.raspberrypi.org/en/projects/parent-detector/3
                    pugsly
                    This is what I use to put my monitor to sleep using a PIR sensor. I have a 3D printed case for the sensor that hangs under the mirror itself. The sensor does not have anything to do with the magic mirror software at all, in fact it just puts the monitor to sleep when no one is in the area.
                    https://github.com/cowboysdude/Pir-Sensor
                    S T 2 Replies Last reply Reply Quote 0
                      sdetweil @pugsly
                      @pugsly right, just trying to help w the debug. lots of things can go wrong, so, it’s best to start at the beginning before getting MM involved.
                      • T Offline
                        tanvir586 @pugsly
                        @pugsly I’ll give it a try tomorrow. Thanks
                        • T Offline
                          tanvir586 @sdetweil
                          @sdetweil thanks mate. Will check this in detail once I go home
                          • T Offline
                            tanvir586
                            Thanks guys for your help. But I recovered my old sd card which had magicmirror 2.19 installed. Pir sensor work with that version. I’m back on truck.
                              If you’re still looking for a working PIR sensor module, I’m using EXT-Pir and it has been great
                              https://github.com/bugsounet/EXT-Pir
                                sdetweil @tanvir586
                                @tanvir586 might be the os firmware, which has reported problems w gpio interrupts
                                • T Offline
                                  tanvir586 @j.e.f.f
                                  @j-e-f-f Hi do I need MMM-GoogleAssistant for this? Or works on its own?
                                    j.e.f.f Project Sponsor Module Developer @tanvir586
                                    @tanvir586 No need for google assistant. Works fine without it.
                                    • T Offline
                                      tanvir586 @j.e.f.f
                                      @j-e-f-f Feb… making another smart mirror soon. I’ll give it a try. Thanks 😊
                                      • T Offline
                                        tanvir586 @j.e.f.f
                                        @j-e-f-f Hi mate. Thinking to install EXT-Pir now. Just one question do I need EXT-Screen to make it work. If yes how can I configure both module? Thanks
                                          @tanvir586 no need to install Ext-Screen. You can use Ext-PIR on its own.
                                          bugsounetB T 2 Replies Last reply Reply Quote 0
                                          • bugsounetB Offline
                                            bugsounet Banned @j.e.f.f
                                            @j-e-f-f ah ? So cool so! Give me a sample or tuto?
