    Pir sensor
    27 Posts 8 Posters 9.9k Views 10 Watching
      sdetweil @tanvir586
      @tanvir586 said in Pir sensor:
      and the .js is
      never edit the module js file
      all config goes in config.js
      I don’t know the module
      does the PIR work outside MM?
      • T Offline
        tanvir586 @sdetweil
        @sdetweil it work like https://github.com/paviro/MMM-PIR-Sensor
        mmm-pir-sensor is not working anymore that’s why I wanted to use the light one. but this one is not working looks like
          sdetweil @tanvir586
          @tanvir586 no, my question was , if u test the PIR connection/setup outside of MM does it work
          using a python script?
          I undertstand how it is SUPPOSED to work , and have tested modules on one of my systems before, but don’t
          use PIR daily
          • T Offline
            tanvir586 @sdetweil
            @sdetweil Hi mate. Sorry I don’t know how to do that. I’m not a programming person. I’m copy past person actually 🤣
              sdetweil @tanvir586
              @tanvir586 https://projects.raspberrypi.org/en/projects/parent-detector/3
              • pugslyP Offline
                pugsly
                This is what I use to put my monitor to sleep using a PIR sensor. I have a 3D printed case for the sensor that hangs under the mirror itself. The sensor does not have anything to do with the magic mirror software at all, in fact it just puts the monitor to sleep when no one is in the area.
                https://github.com/cowboysdude/Pir-Sensor
                S T 2 Replies Last reply Reply Quote 0
                  sdetweil @pugsly
                  @pugsly right, just trying to help w the debug. lots of things can go wrong, so, it’s best to start at the beginning before getting MM involved.
                  • T Offline
                    tanvir586 @pugsly
                    @pugsly I’ll give it a try tomorrow. Thanks
                    • T Offline
                      tanvir586 @sdetweil
                      @sdetweil thanks mate. Will check this in detail once I go home
                      • T Offline
                        tanvir586
                        Thanks guys for your help. But I recovered my old sd card which had magicmirror 2.19 installed. Pir sensor work with that version. I’m back on truck.
