    remoteFile in compliments module
    71 Posts 14 Posters 109.9k Views 15 Watching
      jcorraliza @schlachtkreuzer6
      @schlachtkreuzer6 said in remoteFile in compliments module:
      @jcorraliza post your config.js and your remotefile pls
      Hi there, I posted them a few posts up. It works with the time of day objects, but not with the currentweather objects in my .json file. I’m using v2.1.0, dev branch, and I’m using the currentweather default module.
      • schlachtkreuzer6S
        schlachtkreuzer6 @DvdEnde
        @DvdEnde MM is up to date and every module i git pull the latest version, nope it says it´s a invalid .json in the MM-Admin-Interface. i just can not use this config @yawns post:
        	module: 'compliments',
        	position: 'lower_third',
        		remoteFile: 'compliments.json'
        if i try to start MM, it´s showing up, that the config is broken. even when i adjust it to the MM-Admin code:
        	"module": "compliments",
        	"position": "lower_third",
        	"config": {
        		"remoteFile": "compliments.json"
        I´m not in javascript or anything coding. But nothing worked for me. maybe my system is somehow broken…
        D 1 Reply Last reply
          DvdEnde @schlachtkreuzer6
          @schlachtkreuzer6
          The way you do it is the way it should be.
          BUT i also cannot get it to work like this.
          please try following:
          Open config/config.js and remove
          "config": {
          Then open your compliments.js and check:
          defaults: {
          		updateInterval: 30000,
          		remoteFile: null,
          		fadeSpeed: 4000
          change remoteFile to a useable name:
          defaults: {
          		remoteFile: "~/path to your/compliments.json",
          		fadeSpeed: 4000
          then restart MM (or restart the PI)
          schlachtkreuzer6S 1 Reply Last reply
          • schlachtkreuzer6S
            @DvdEnde i think my mirror has it´s own brain ^^ so i changed it like your post above. but MM just showing the default compliments. I don´t know whats wrong, but i think i will rebuild MM from the ground.
              DvdEnde
              #@schlachtkreuzer6
              If MM is showing the default compliments, where are they?
              Please post the complete defaults from your compliments.js AND
              the complete part of the json for compliments from your config.js.
              also post your jsonfile where to get your custom compliments.
              maybe we all misunderstand you?
              • schlachtkreuzer6S
                @DvdEnde the default compliments are in the module itself ok, here we go:
                ~/MagicMirror/config/config.js
                /* Magic Mirror Config Sample
                * MIT Licensed.
                var config = {
                	"port": 8080,
                	"language": "de",
                	"timeFormat": 24,
                	"units": "metric",
                	"modules": [
                			"module": "alert"
                			"module": "clock",
                			"position": "top_left"
                			"module": "calendar",
                			"header": "Google Kalender",
                			"position": "top_left",
                			"config": {
                				"calendars": [
                						"symbol": "calendar",
                						"url": "my link 1"
                						"url": "my link 2"
                						"url": "my link 3"
                						"url": "my link 4"
                						"url": "my link 4"
                						"url": "my link 5"
                				"timeFormat": "absolute",
                				"maximumEntries": "20",
                				"fadePoint": "0.55"
                			"config": {
                				"compliments": {
                     					 morning: [
                         					 'Guten Morgen!',
                         					 'Wie hast du geschlafen?',
                         					 'Ich wünsche dir einen schönen Tag!'
                    					 afternoon: [
                        		 			 'Guten Tag!',
                         					 'Du schaust gut aus!',
                         					 'Wie war dein Tag!'
                     					 evening: [
                          					 'Guten Abend!',
                          					 'Na wie war dein Tag?',
                          					 'Du warst heute fleßig!'
                				"updateInterval": 15000
                			"module": "currentweather",
                			"position": "top_right",
                			"config": {
                				"location": "my location",
                				"locationID": "",
                				"appid": "my api"
                			"module": "weatherforecast",
                			"header": "Wetter in den kommenden Tagen",
                			"config": {
                				"locationID": "",
                				"appid": "my api"
                			"module": "newsfeed",
                			"position": "bottom_bar",
                			"config": {
                				"feeds": [
                						"title": "Die Presse",
                						"url": "http://diepresse.com/rss/home"
                				"showSourceTitle": true,
                				"showPublishDate": true
                			"module": "MMM-Remote-Control"
                			"module": "mmm-wu-moonphase",
                			"header": "Aktuelle Mondphase",
                			"config": {
                				"apikey": "my api",
                				"country": "Austria",
                				"city": "Vienna",
                				"apiLang": "DL"
                			"module": "MMM-WienerLinien",
                			"config": {
                				"api_key": "my api",
                				"stations": [
                					"abcd",
                					"abcd"
                			"module": "MMM-SpotifyConnectUI",
                			"position": "fullscreen_below",
                			"config": {}
                			"module": "MMM-Globe",
                			"config": {
                				"style": "europeDiscNat",
                				"imageSize": 250,
                				"ownImagePath": "",
                				"updateInterval": 600000
                			"module": "internet-monitor",
                			"position": "top_bar",
                			"config": {
                				"type": "minimal",
                				"maxTime": 20000,
                				"updateInterval": 0,
                				"verbose": false,
                				"displayStrength": true,
                				"displaySpeed": false,
                				"strengthIconSize": 40,
                				"maxGaugeScale": 100
                			"module": "MMM-Traffic",
                			"config": {
                				"mode": "driving",
                				"origin": "my home",
                				"destination": "my work",
                				"arrival_time": "",
                				"route_name": "Home-work",
                				"changeColor": true,
                				"showGreen": false,
                				"limitYellow": 5,
                				"limitRed": 20,
                				"traffic_model": "pessimistic",
                				"interval": 120000,
                				"language": "de",
                				"prependText": "Derzeit"
                			"classes": "dimmed medium"
                			"module": "MMM-RandomPhoto",
                			"config": {
                				"opacity": 0.3,
                				"animationSpeed": 1500,
                				"updateInterval": 15,
                				"url": "https://unsplash.it/1080/1920/?random"
                			"module": "MMM-SystemStats",
                			"position": "bottom_right",
                			"config": {
                				"updateInterval": 10000,
                				"animationSpeed": 0
                			"classes": "small dimmed"
                			"module": "MMM-Admin-Interface"
                	"ipWhitelist": [
                		"::fff:0.0.0.0/1",
                		"::fff:128.0.0.0/2",
                		"::fff:192.0.0.0/3",
                		"::fff:224.0.0.0/4",
                		"127.0.0.1",
                		"::ffff:127.0.0.1",
                		"::1"
                this config is working perfect.
                ~/MagicMirror/modules/default/compliments/compliments.json (remoteFile) tried it also here ~/MagicMirror/config/compliments.json with and without absolut path.
                      "morning": [
                          "Test1!",
                          "Test2?",
                          "Test3!"
                     "afternoon": [
                          "Test4!",
                          "Test5!",
                          "Test6!"
                     "evening": [
                           "Test7!",
                           "Test8?",
                           "Test9!"
                and ~/MagicMirror/modules/default/compliments/compliments.js
                * global Log, Module, moment */
                /* Magic Mirror
                 * Module: Compliments
                 * MIT Licensed.
                Module.register("compliments",{
                	// Module config defaults.
                	defaults: {
                		compliments: {
                			morning: [
                				"Good morning, handsome!",
                				"Enjoy your day!",
                				"How was your sleep?"
                			afternoon: [
                				"Hello, beauty!",
                				"You look sexy!",
                				"Looking good today!"
                			evening: [
                				"Wow, you look hot!",
                				"You look nice!",
                				"Hi, sexy!"
                		remoteFile: null,
                		fadeSpeed: 4000
                	// Set currentweather from module
                	currentWeatherType: "",
                	// Define required scripts.
                	getScripts: function() {
                		return ["moment.js"];
                	// Define start sequence.
                	start: function() {
                		this.lastComplimentIndex = -1;
                		if (this.config.remoteFile != null) {
                			this.complimentFile((response) => {
                				this.config.compliments = JSON.parse(response);
                		// Schedule update timer.
                		var self = this;
                		setInterval(function() {
                			self.updateDom(self.config.fadeSpeed);
                		}, this.config.updateInterval);
                	/* randomIndex(compliments)
                	 * Generate a random index for a list of compliments.
                	 * argument compliments Array<String> - Array with compliments.
                	 * return Number - Random index.
                	randomIndex: function(compliments) {
                		if (compliments.length === 1) {
                			return 0;
                		var generate = function() {
                			return Math.floor(Math.random() * compliments.length);
                		var complimentIndex = generate();
                		while (complimentIndex === this.lastComplimentIndex) {
                		this.lastComplimentIndex = complimentIndex;
                		return complimentIndex;
                	/* complimentArray()
                	 * Retrieve an array of compliments for the time of the day.
                	 * return compliments Array<String> - Array with compliments for the time of the day.
                	complimentArray: function() {
                		var hour = moment().hour();
                		var compliments  = null;
                		if (hour >= 3 && hour < 12) {
                			compliments = this.config.compliments.morning;
                		} else if (hour >= 12 && hour < 17) {
                			compliments = this.config.compliments.afternoon;
                		} else {
                			compliments = this.config.compliments.evening;
                		if ( this.currentWeatherType in this.config.compliments) {
                			compliments.push.apply(compliments, this.config.compliments[this.currentWeatherType]);
                		return compliments;
                	/* complimentFile(callback)
                	 * Retrieve a file from the local filesystem
                	complimentFile: function(callback) {
                		var xobj = new XMLHttpRequest();
                		xobj.overrideMimeType("application/json");
                		xobj.open("GET", this.file(this.config.remoteFile), true);
                		xobj.onreadystatechange = function () {
                			if (xobj.readyState == 4 && xobj.status == "200") {
                				callback(xobj.responseText);
                		xobj.send(null);
                	 * Retrieve a random compliment.
                	 * return compliment string - A compliment.
                	randomCompliment: function() {
                		var compliments = this.complimentArray();
                		var index = this.randomIndex(compliments);
                		return compliments[index];
                	// Override dom generator.
                	getDom: function() {
                		var complimentText = this.randomCompliment();
                		var compliment = document.createTextNode(complimentText);
                		wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright";
                		wrapper.appendChild(compliment);
                		return wrapper;
                	// From data currentweather set weather type
                	setCurrentWeatherType: function(data) {
                		var weatherIconTable = {
                			"01d": "day_sunny",
                			"02d": "day_cloudy",
                			"03d": "cloudy",
                			"04d": "cloudy_windy",
                			"09d": "showers",
                			"10d": "rain",
                			"11d": "thunderstorm",
                			"13d": "snow",
                			"50d": "fog",
                			"01n": "night_clear",
                			"02n": "night_cloudy",
                			"03n": "night_cloudy",
                			"04n": "night_cloudy",
                			"09n": "night_showers",
                			"10n": "night_rain",
                			"11n": "night_thunderstorm",
                			"13n": "night_snow",
                			"50n": "night_alt_cloudy_windy"
                		this.currentWeatherType = weatherIconTable[data.weather[0].icon];
                	// Override notification handler.
                		if (notification == "CURRENTWEATHER_DATA") {
                			this.setCurrentWeatherType(payload.data);
                even when i change it like you said above:
                defaults: {
                		remoteFile: "~/MagicMirror/modules/default/compliments/compliments.json",
                		fadeSpeed: 4000
                It´s showing then the default compliments. (hi sexy etc.)
                it´s working with my custom compliments in the config.js perfectly. but when i try this code:
                	"config": {
                MM showing the error srceen that i had to set up a config file.
                J D 2 Replies Last reply
                  @schlachtkreuzer6
                  	"config": {
                  You have to get rid of those quotes around module, position, config, and remoteFile. It should look like this:
                  schlachtkreuzer6S 2 Replies Last reply
                  • schlachtkreuzer6S
                    schlachtkreuzer6 @jcorraliza
                    @jcorraliza it´s from the MMM-Admin-Interface… after initializing this module, there quotes are everywhere… but sure i will try this too
                      @schlachtkreuzer6
                      You have tried many things, we can see it.
                      Maybe you cleanup the mess a little.
                      IN de config/confg.js remove the complete “config” from “module”: “compliments”.
                      "config": {
                      				"compliments": {
                      take away the quotes also like @jcorraliza adviced.
                      So the config.js looks like this (for your compliment module)
                      	module: "compliments",
                      	position: "lower_third"
                      then in the compliments.js you default sould look like this:
                      defaults: {
                      		fadeSpeed: 4000
                      It should run.
                      • schlachtkreuzer6S
                        @jcorraliza haha I can not believe it!!! now it´s working. okay so here is what i did:
                        so after ending with an error and resetting all the configs and .js files to default and my latest working config.js (post it above)
                        i shut it down
                        some hours later i boot it up again, and via putty ssh I copy and paste this code in the config.js:
                        the comliments.js file is still located here: ~/MagicMirror/modules/default/compliments
                        then i restart the MM via pm2 restart mm
                        now it´s working with the compliments from the readme:
                            "morning" : [
                                "heyho"
                            "afternoon" : [
                                "home early?"
                            "evening" : [
                                "finally home"
                                "fog" : [
                                        "fog, oh no :("
                        but anyway, the MMM-Admin-Interface changed the config.json to this again ^^:
                          "config": {
                        many thanks for your help, and time!
                          A Former User
                          hey, sorry for being a bit silent. was travelling with no access to my raspberry. will give your solution a shot, too. why does it have to be a local file, though? my plan was to (in a 2nd step) place the compliments.json in my dropbox folder, so i can easily change the compliments remotely.
                          bheplerB D 2 Replies Last reply
                          • bheplerB
                            bhepler Module Developer @Guest
                            @skr Because I’m a crap coder in Javascript.
                            Sorry for not helping earlier, folks. I was at a wedding and delivering my mirror as a gift. I’ll investigate and see if I can’t improve the mirror code.
                            You should not ever have to modify the compliments.js file. You should be able to pull it off with just modifications to the config.js file.
                            Reply Quote 3
                              DvdEnde
                              @schlachtkreuzer6
                              Because it worked with you as it should be, so I changed my whole MM installation.
                              I did manage to keep the compliments unchanged too.
                              :D I am happy …
                              @strawberry-3-141 @yawns thanks guys. Your info helped me too a lot!
                                DvdEnde @Guest
                                @skr I am working on that now.
                                @strawberry-3-141 has some good information in this project:
                                https://forum.magicmirror.builders/topic/240/soccer-standings
                                I am struggling with the CORS at the moment but it is solvable…
                                • schlachtkreuzer6S
                                  @DvdEnde Great :) did you manage to run the weather-dependent compliments? My goal is to add all weather conditions based compliments. The normal compliments work, just need some time to load after starting MM from 30 seconds to 3mins. But if a add all of them:
                                  day_sunny
                                  day_cloudy
                                  cloudy
                                  cloudy_windy
                                  showers
                                  rain
                                  thunderstorm
                                  snow
                                  fog
                                  night_clear
                                  night_cloudy
                                  night_showers
                                  night_rain
                                  night_thunderstorm
                                  night_snow
                                  in this format:
                                          "fog" : [
                                                  "fog, oh no :("
                                  MM starts to show the default comliments. Any Idea?
                                  J 1 Reply Last reply
                                    day_sunny
                                    day_cloudy
                                    cloudy
                                    cloudy_windy
                                    showers
                                    rain
                                    thunderstorm
                                    snow
                                    fog
                                    night_clear
                                    night_cloudy
                                    night_showers
                                    night_rain
                                    night_thunderstorm
                                    night_snow
                                    in this format:
                                            "fog" : [
                                                    "fog, oh no :("
                                    This is the exact problem I’m running into as well. I can get the remoteFile to work if I just use the default times of day, but if I try using the currentweather objects, it just goes back to the default compliments.
                                    • schlachtkreuzer6S
                                      @jcorraliza yeah… the only reason why i would use the remote file is the weather stuff, and obviously this feature has a bug, or we are to weak in coding ^^
                                      • bheplerB
                                        Okay, I have the weather integration working. I’ll spare you the process I went through to figure it out, but the short version is that I am a worse developer than I originally suspected. The remoteFile capability works by replacing the three compliment arrays (morning, afternoon & evening). The weather integration works (sensibly, IMHO) by adding weather-specific compliments to the existing arrays.
                                        So in order to get them both working, you need to specify both the original arrays and the weather-specific arrays. You can delete any weather-specific arrays you wish, but you must have the morning, afternoon & evening arrays. Copy & paste this compliments.json file to your mirror and then modify accordingly.
                                          "morning": ["Morning compliment"],
                                          "afternoon": ["Afternoon compliment"],
                                          "evening": ["Evening compliment"],
                                          "day_sunny" : [
                                            "Day Sunny Compliment 1",
                                            "Day Sunny Compliment 2"
                                          "day_cloudy" : [
                                            "Day Cloudy Compliment 1",
                                            "Day Cloudy Compliment 2"
                                          "cloudy" : ["Cloud 1"],
                                          "cloudy_windy" : ["Cloud windy"],
                                          "showers" : ["Showers"],
                                          "rain" : ["Rain"],
                                          "thunderstorm" : ["Thunderstorm"],
                                          "snow" : ["Snow"],
                                          "fog" : ["Fog"],
                                          "night_clear" : ["Night clear"],
                                          "night_cloudy" : ["Night Cloudy"],
                                          "night_showers" : ["Night showers"],
                                          "night_rain" : ["Night Rain"],
                                          "night_thunderstorm" : ["Night thunderstorm"],
                                          "night_snow" : ["Night Snow"],
                                          "night_alt_cloudy_wind": ["Night Cloudy Winds"]
                                        I’m going to work on this a bit and hopefully the next release of the MirrorMirror software will be a bit more friendly. As an aside, I’ve noticed that the weather integration technique continually adds to the arrays. So the memory usage will grow and grow at whatever frequency you set the compliment refresh. This isn’t terrible, as straight text doesn’t take a whole lot of memory. But it may have unintended effects if you leave your mirror running for months at a time or if you are expecting a true randomization of the compliments you enter.
                                        schlachtkreuzer6S R 2 Replies Last reply
                                        Reply Quote 2
                                        • schlachtkreuzer6S
                                          schlachtkreuzer6 @bhepler
                                          @bhepler okay a bit weird^^ anyway thank you! It worked perfecly!
                                          @Steff the config above :)
                                            roramirez Core Contributors @bhepler
                                            @bhepler said in remoteFile in compliments module:
                                            Hi, when I worked in this feature I remember was a flashing about this.
                                            If you can help how improved this is welcome :)
                                            • 2 / 4
