    remoteFile in compliments module
    71 Posts 14 Posters 106.9k Views 15 Watching
    • Y Offline
      yawns Moderator
      @DvdEnde Please don’t get me wrong, but this is basic javascript.
      this.config.remoteFile != null checks if the variable “remoteFile” is set in your config file. Afterwards you only have two scenarios:
      1. the variable is not set -> this if clause fails and no remote file is loaded.
      2. the variable is set to any value -> this if clause is true and the function complimentFile() is called, which tries to load the file defined in your config file, in my case “compliments.json”.
      If loading the remote file fails you see an error message in console output of your browser. Otherwise it does not produce any log.
        DvdEnde @yawns
        @yawns
        Don’t worry, i know it is basic javascript.
        @strawberry-3-141
        i thought so too, but it is NOT
        I just now changed the compliment.js (and deleted the remoteFile completly from here) and added this within the config.
        My object is simple
            fadeSpeed: 4000
            updateInterval: 30000
        On line 33 console.log(this.config.remoteFile) = undefined
          jcorraliza @yawns
          @yawns OK I created a compliments_test.json file and pasted your example into it and it worked. It looks like it just doesn’t work with the currentweather objects in my compliments.json file for some reason. Do I need to nest the currentweather objects within the morning, afternoon, and evening arrays perhaps?
            schlachtkreuzer6 @jcorraliza
            @jcorraliza post your config.js and your remotefile pls
              jcorraliza @schlachtkreuzer6
              @schlachtkreuzer6 said in remoteFile in compliments module:
              Hi there, I posted them a few posts up. It works with the time of day objects, but not with the currentweather objects in my .json file. I’m using v2.1.0, dev branch, and I’m using the currentweather default module.
                schlachtkreuzer6 @DvdEnde
                @DvdEnde MM is up to date and every module i git pull the latest version, nope it says it´s a invalid .json in the MM-Admin-Interface. i just can not use this config @yawns post:
                	module: 'compliments',
                	position: 'lower_third',
                		remoteFile: 'compliments.json'
                if i try to start MM, it´s showing up, that the config is broken. even when i adjust it to the MM-Admin code:
                	"module": "compliments",
                	"position": "lower_third",
                	"config": {
                		"remoteFile": "compliments.json"
                I´m not in javascript or anything coding. But nothing worked for me. maybe my system is somehow broken…
                  DvdEnde @schlachtkreuzer6
                  @schlachtkreuzer6
                  The way you do it is the way it should be.
                  BUT i also cannot get it to work like this.
                  please try following:
                  Open config/config.js and remove
                  "config": {
                  Then open your compliments.js and check:
                  defaults: {
                  		updateInterval: 30000,
                  		remoteFile: null,
                  		fadeSpeed: 4000
                  change remoteFile to a useable name:
                  defaults: {
                  		remoteFile: "~/path to your/compliments.json",
                  		fadeSpeed: 4000
                  then restart MM (or restart the PI)
                    @DvdEnde i think my mirror has it´s own brain ^^ so i changed it like your post above. but MM just showing the default compliments. I don´t know whats wrong, but i think i will rebuild MM from the ground.
                      DvdEnde
                      #@schlachtkreuzer6
                      If MM is showing the default compliments, where are they?
                      Please post the complete defaults from your compliments.js AND
                      the complete part of the json for compliments from your config.js.
                      also post your jsonfile where to get your custom compliments.
                      maybe we all misunderstand you?
                        @DvdEnde the default compliments are in the module itself ok, here we go:
                        ~/MagicMirror/config/config.js
                        /* Magic Mirror Config Sample
                        * MIT Licensed.
                        var config = {
                        	"port": 8080,
                        	"language": "de",
                        	"timeFormat": 24,
                        	"units": "metric",
                        	"modules": [
                        			"module": "alert"
                        			"module": "clock",
                        			"position": "top_left"
                        			"module": "calendar",
                        			"header": "Google Kalender",
                        			"position": "top_left",
                        			"config": {
                        				"calendars": [
                        						"symbol": "calendar",
                        						"url": "my link 1"
                        						"url": "my link 2"
                        						"url": "my link 3"
                        						"url": "my link 4"
                        						"url": "my link 4"
                        						"url": "my link 5"
                        				"timeFormat": "absolute",
                        				"maximumEntries": "20",
                        				"fadePoint": "0.55"
                        			"config": {
                        				"compliments": {
                             					 morning: [
                                 					 'Guten Morgen!',
                                 					 'Wie hast du geschlafen?',
                                 					 'Ich wünsche dir einen schönen Tag!'
                            					 afternoon: [
                                		 			 'Guten Tag!',
                                 					 'Du schaust gut aus!',
                                 					 'Wie war dein Tag!'
                             					 evening: [
                                  					 'Guten Abend!',
                                  					 'Na wie war dein Tag?',
                                  					 'Du warst heute fleßig!'
                        				"updateInterval": 15000
                        			"module": "currentweather",
                        			"position": "top_right",
                        			"config": {
                        				"location": "my location",
                        				"locationID": "",
                        				"appid": "my api"
                        			"module": "weatherforecast",
                        			"header": "Wetter in den kommenden Tagen",
                        			"config": {
                        				"locationID": "",
                        				"appid": "my api"
                        			"module": "newsfeed",
                        			"position": "bottom_bar",
                        			"config": {
                        				"feeds": [
                        						"title": "Die Presse",
                        						"url": "http://diepresse.com/rss/home"
                        				"showSourceTitle": true,
                        				"showPublishDate": true
                        			"module": "MMM-Remote-Control"
                        			"module": "mmm-wu-moonphase",
                        			"header": "Aktuelle Mondphase",
                        			"config": {
                        				"apikey": "my api",
                        				"country": "Austria",
                        				"city": "Vienna",
                        				"apiLang": "DL"
                        			"module": "MMM-WienerLinien",
                        			"config": {
                        				"api_key": "my api",
                        				"stations": [
                        					"abcd",
                        					"abcd"
                        			"module": "MMM-SpotifyConnectUI",
                        			"position": "fullscreen_below",
                        			"config": {}
                        			"module": "MMM-Globe",
                        			"config": {
                        				"style": "europeDiscNat",
                        				"imageSize": 250,
                        				"ownImagePath": "",
                        				"updateInterval": 600000
                        			"module": "internet-monitor",
                        			"position": "top_bar",
                        			"config": {
                        				"type": "minimal",
                        				"maxTime": 20000,
                        				"updateInterval": 0,
                        				"verbose": false,
                        				"displayStrength": true,
                        				"displaySpeed": false,
                        				"strengthIconSize": 40,
                        				"maxGaugeScale": 100
                        			"module": "MMM-Traffic",
                        			"config": {
                        				"mode": "driving",
                        				"origin": "my home",
                        				"destination": "my work",
                        				"arrival_time": "",
                        				"route_name": "Home-work",
                        				"changeColor": true,
                        				"showGreen": false,
                        				"limitYellow": 5,
                        				"limitRed": 20,
                        				"traffic_model": "pessimistic",
                        				"interval": 120000,
                        				"language": "de",
                        				"prependText": "Derzeit"
                        			"classes": "dimmed medium"
                        			"module": "MMM-RandomPhoto",
                        			"config": {
                        				"opacity": 0.3,
                        				"animationSpeed": 1500,
                        				"updateInterval": 15,
                        				"url": "https://unsplash.it/1080/1920/?random"
                        			"module": "MMM-SystemStats",
                        			"position": "bottom_right",
                        			"config": {
                        				"updateInterval": 10000,
                        				"animationSpeed": 0
                        			"classes": "small dimmed"
                        			"module": "MMM-Admin-Interface"
                        	"ipWhitelist": [
                        		"::fff:0.0.0.0/1",
                        		"::fff:128.0.0.0/2",
                        		"::fff:192.0.0.0/3",
                        		"::fff:224.0.0.0/4",
                        		"127.0.0.1",
                        		"::ffff:127.0.0.1",
                        		"::1"
                        this config is working perfect.
                        ~/MagicMirror/modules/default/compliments/compliments.json (remoteFile) tried it also here ~/MagicMirror/config/compliments.json with and without absolut path.
                              "morning": [
                                  "Test1!",
                                  "Test2?",
                                  "Test3!"
                             "afternoon": [
                                  "Test4!",
                                  "Test5!",
                                  "Test6!"
                             "evening": [
                                   "Test7!",
                                   "Test8?",
                                   "Test9!"
                        and ~/MagicMirror/modules/default/compliments/compliments.js
                        * global Log, Module, moment */
                        /* Magic Mirror
                         * Module: Compliments
                         * MIT Licensed.
                        Module.register("compliments",{
                        	// Module config defaults.
                        	defaults: {
                        		compliments: {
                        			morning: [
                        				"Good morning, handsome!",
                        				"Enjoy your day!",
                        				"How was your sleep?"
                        			afternoon: [
                        				"Hello, beauty!",
                        				"You look sexy!",
                        				"Looking good today!"
                        			evening: [
                        				"Wow, you look hot!",
                        				"You look nice!",
                        				"Hi, sexy!"
                        		remoteFile: null,
                        		fadeSpeed: 4000
                        	// Set currentweather from module
                        	currentWeatherType: "",
                        	// Define required scripts.
                        	getScripts: function() {
                        		return ["moment.js"];
                        	// Define start sequence.
                        	start: function() {
                        		this.lastComplimentIndex = -1;
                        		if (this.config.remoteFile != null) {
                        			this.complimentFile((response) => {
                        				this.config.compliments = JSON.parse(response);
                        		// Schedule update timer.
                        		var self = this;
                        		setInterval(function() {
                        			self.updateDom(self.config.fadeSpeed);
                        		}, this.config.updateInterval);
                        	/* randomIndex(compliments)
                        	 * Generate a random index for a list of compliments.
                        	 * argument compliments Array<String> - Array with compliments.
                        	 * return Number - Random index.
                        	randomIndex: function(compliments) {
                        		if (compliments.length === 1) {
                        			return 0;
                        		var generate = function() {
                        			return Math.floor(Math.random() * compliments.length);
                        		var complimentIndex = generate();
                        		while (complimentIndex === this.lastComplimentIndex) {
                        		this.lastComplimentIndex = complimentIndex;
                        		return complimentIndex;
                        	/* complimentArray()
                        	 * Retrieve an array of compliments for the time of the day.
                        	 * return compliments Array<String> - Array with compliments for the time of the day.
                        	complimentArray: function() {
                        		var hour = moment().hour();
                        		var compliments  = null;
                        		if (hour >= 3 && hour < 12) {
                        			compliments = this.config.compliments.morning;
                        		} else if (hour >= 12 && hour < 17) {
                        			compliments = this.config.compliments.afternoon;
                        		} else {
                        			compliments = this.config.compliments.evening;
                        		if ( this.currentWeatherType in this.config.compliments) {
                        			compliments.push.apply(compliments, this.config.compliments[this.currentWeatherType]);
                        		return compliments;
                        	/* complimentFile(callback)
                        	 * Retrieve a file from the local filesystem
                        	complimentFile: function(callback) {
                        		var xobj = new XMLHttpRequest();
                        		xobj.overrideMimeType("application/json");
                        		xobj.open("GET", this.file(this.config.remoteFile), true);
                        		xobj.onreadystatechange = function () {
                        			if (xobj.readyState == 4 && xobj.status == "200") {
                        				callback(xobj.responseText);
                        		xobj.send(null);
                        	 * Retrieve a random compliment.
                        	 * return compliment string - A compliment.
                        	randomCompliment: function() {
                        		var compliments = this.complimentArray();
                        		var index = this.randomIndex(compliments);
                        		return compliments[index];
                        	// Override dom generator.
                        	getDom: function() {
                        		var complimentText = this.randomCompliment();
                        		var compliment = document.createTextNode(complimentText);
                        		wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright";
                        		wrapper.appendChild(compliment);
                        		return wrapper;
                        	// From data currentweather set weather type
                        	setCurrentWeatherType: function(data) {
                        		var weatherIconTable = {
                        			"01d": "day_sunny",
                        			"02d": "day_cloudy",
                        			"03d": "cloudy",
                        			"04d": "cloudy_windy",
                        			"09d": "showers",
                        			"10d": "rain",
                        			"11d": "thunderstorm",
                        			"13d": "snow",
                        			"50d": "fog",
                        			"01n": "night_clear",
                        			"02n": "night_cloudy",
                        			"03n": "night_cloudy",
                        			"04n": "night_cloudy",
                        			"09n": "night_showers",
                        			"10n": "night_rain",
                        			"11n": "night_thunderstorm",
                        			"13n": "night_snow",
                        			"50n": "night_alt_cloudy_windy"
                        		this.currentWeatherType = weatherIconTable[data.weather[0].icon];
                        	// Override notification handler.
                        		if (notification == "CURRENTWEATHER_DATA") {
                        			this.setCurrentWeatherType(payload.data);
                        even when i change it like you said above:
                        defaults: {
                        		remoteFile: "~/MagicMirror/modules/default/compliments/compliments.json",
                        		fadeSpeed: 4000
                        It´s showing then the default compliments. (hi sexy etc.)
                        it´s working with my custom compliments in the config.js perfectly. but when i try this code:
                        	"config": {
                        MM showing the error srceen that i had to set up a config file.
                        J D 2 Replies Last reply Reply Quote 0
                          @schlachtkreuzer6
                          	"config": {
                          You have to get rid of those quotes around module, position, config, and remoteFile. It should look like this:
                            @jcorraliza it´s from the MMM-Admin-Interface… after initializing this module, there quotes are everywhere… but sure i will try this too
                              @schlachtkreuzer6
                              You have tried many things, we can see it.
                              Maybe you cleanup the mess a little.
                              IN de config/confg.js remove the complete “config” from “module”: “compliments”.
                              "config": {
                              				"compliments": {
                              take away the quotes also like @jcorraliza adviced.
                              So the config.js looks like this (for your compliment module)
                              	module: "compliments",
                              	position: "lower_third"
                              then in the compliments.js you default sould look like this:
                              defaults: {
                              		fadeSpeed: 4000
                              It should run.
                                @jcorraliza haha I can not believe it!!! now it´s working. okay so here is what i did:
                                so after ending with an error and resetting all the configs and .js files to default and my latest working config.js (post it above)
                                i shut it down
                                some hours later i boot it up again, and via putty ssh I copy and paste this code in the config.js:
                                the comliments.js file is still located here: ~/MagicMirror/modules/default/compliments
                                then i restart the MM via pm2 restart mm
                                now it´s working with the compliments from the readme:
                                    "morning" : [
                                        "heyho"
                                    "afternoon" : [
                                        "home early?"
                                    "evening" : [
                                        "finally home"
                                        "fog" : [
                                                "fog, oh no :("
                                but anyway, the MMM-Admin-Interface changed the config.json to this again ^^:
                                  "config": {
                                many thanks for your help, and time!
                                  [[global:former-user]]
                                  hey, sorry for being a bit silent. was travelling with no access to my raspberry. will give your solution a shot, too. why does it have to be a local file, though? my plan was to (in a 2nd step) place the compliments.json in my dropbox folder, so i can easily change the compliments remotely.
                                  B D 2 Replies Last reply Reply Quote 0
                                    bhepler Module Developer @Guest
                                    @skr Because I’m a crap coder in Javascript.
                                    Sorry for not helping earlier, folks. I was at a wedding and delivering my mirror as a gift. I’ll investigate and see if I can’t improve the mirror code.
                                    You should not ever have to modify the compliments.js file. You should be able to pull it off with just modifications to the config.js file.
                                      DvdEnde
                                      @schlachtkreuzer6
                                      Because it worked with you as it should be, so I changed my whole MM installation.
                                      I did manage to keep the compliments unchanged too.
                                      :D I am happy …
                                      @strawberry-3-141 @yawns thanks guys. Your info helped me too a lot!
                                        DvdEnde @Guest
                                        @skr I am working on that now.
                                        @strawberry-3-141 has some good information in this project:
                                        https://forum.magicmirror.builders/topic/240/soccer-standings
                                        I am struggling with the CORS at the moment but it is solvable…
                                          @DvdEnde Great :) did you manage to run the weather-dependent compliments? My goal is to add all weather conditions based compliments. The normal compliments work, just need some time to load after starting MM from 30 seconds to 3mins. But if a add all of them:
                                          day_sunny
                                          day_cloudy
                                          cloudy
                                          cloudy_windy
                                          showers
                                          rain
                                          thunderstorm
                                          snow
                                          fog
                                          night_clear
                                          night_cloudy
                                          night_showers
                                          night_rain
                                          night_thunderstorm
                                          night_snow
                                          in this format:
                                                  "fog" : [
                                                          "fog, oh no :("
                                          MM starts to show the default comliments. Any Idea?
                                            day_sunny
                                            day_cloudy
                                            cloudy
                                            cloudy_windy
                                            showers
                                            rain
                                            thunderstorm
                                            snow
                                            fog
                                            night_clear
                                            night_cloudy
                                            night_showers
                                            night_rain
                                            night_thunderstorm
                                            night_snow
                                            in this format:
                                                    "fog" : [
                                                            "fog, oh no :("
                                            This is the exact problem I’m running into as well. I can get the remoteFile to work if I just use the default times of day, but if I try using the currentweather objects, it just goes back to the default compliments.
                                            • 2 / 4
