    remoteFile in compliments module
    71 Posts 14 Posters 109.1k Views 15 Watching
      schlachtkreuzer6 @strawberry 3.141
      @strawberry-3.141 Hey, hm i think something is wrong^^
      pi@MagicMirror:~ $ npm start dev
      npm ERR! Linux 4.4.37-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
      npm ERR! node v6.9.2
      npm ERR! npm  v3.10.9
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log
      • Y
        yawns Moderator @jcorraliza
        @jcorraliza
        Hi, I just tried on my computer …
        snippit from my config.js
        	module: 'compliments',
        	position: 'lower_third',
        		remoteFile: 'compliments.json'
        my compliments.json
            "morning" : [
                "heyho"
            "afternoon" : [
                "home early?"
            "evening" : [
                "finally home"
        	"fog" : [
        		"fog, oh no :("
        The compliments.json file is located in ~/MagicMirror/modules/default/compliments
        Three things to mention:
        1. Of course you need to use the default “currentweather” module
        2. You need to run the new updated MagicMirror version. Otherwise compliments and currentweather are not interacting
        3. There is a delay loading the compliments file. I added some debug output to track that and as you see MagicMirror starts with default values and takes 30 seconds to load and verify your remote file.0_1483870239034_compliments.PNG
        • Y
          yawns Moderator @schlachtkreuzer6
          @schlachtkreuzer6
          you are in your home directory, not in your MagicMirror folder.
          Run cd MagicMirror first
            schlachtkreuzer6 @yawns
            @yawns oh, okay then i get this:
            pi@MagicMirror:~/MagicMirror $ npm start dev
            > magicmirror@2.1.0 start /home/pi/MagicMirror
            > electron js/electron.js "dev"
            npm ERR! code ELIFECYCLE
            npm ERR! magicmirror@2.1.0 start: `electron js/electron.js "dev"`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
            npm ERR! If you do, this is most likely a problem with the magicmirror package,
            npm ERR! not with npm itself.
            npm ERR!     electron js/electron.js "dev"
            npm ERR!     npm bugs magicmirror
            npm ERR! Or if that isn't available, you can get their info via:
            npm ERR!     npm owner ls magicmirror
            npm ERR!     /home/pi/MagicMirror/npm-debug.log
            npm-debug.log
              GNU nano 2.2.6        File: npm-debug.log
            1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start', 'dev' ]
            2 info using npm@3.10.9
            3 info using node@v6.9.2
            5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0
            6 silly lifecycle magicmirror@2.1.0~prestart: no script for prestart, continuing
            7 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0
            8 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true
            9 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
            10 verbose lifecycle magicmirror@2.1.0~start: CWD: /home/pi/MagicMirror
            11 silly lifecycle magicmirror@2.1.0~start: Args: [ '-c', 'electron js/electron.js "dev"' ]
            12 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1  signal: null
            13 info lifecycle magicmirror@2.1.0~start: Failed to exec start script
            14 verbose stack Error: magicmirror@2.1.0 start: `electron js/electron.js "dev"`
            14 verbose stack Exit status 1
            14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
            14 verbose stack     at emitTwo (events.js:106:13)
            14 verbose stack     at EventEmitter.emit (events.js:191:7)
            14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
            14 verbose stack     at ChildProcess.emit (events.js:191:7)
            14 verbose stack     at maybeClose (internal/child_process.js:877:16)
            14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
            15 verbose pkgid magicmirror@2.1.0
            16 verbose cwd /home/pi/MagicMirror
            17 error Linux 4.4.37-v7+
            18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
            19 error node v6.9.2
            20 error npm  v3.10.9
            21 error code ELIFECYCLE
            22 error magicmirror@2.1.0 start: `electron js/electron.js "dev"`
            22 error Exit status 1
            23 error Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
            23 error Make sure you have the latest version of node.js and npm installed.
            23 error If you do, this is most likely a problem with the magicmirror package,
            23 error not with npm itself.
            23 error Tell the author that this fails on your system:
            23 error     electron js/electron.js "dev"
            23 error You can get information on how to open an issue for this project with:
            23 error     npm bugs magicmirror
            23 error Or if that isn't available, you can get their info via:
            23 error     npm owner ls magicmirror
            23 error There is likely additional logging output above.
            24 verbose exit [ 1, true ]
              DvdEnde
              Friends,
              using version 2.1.0 you must have the remoteFile within the configuration of the compliments.js.
              the file should start like this:
              defaults: {
              	updateInterval: 30000,
              	remoteFile: 'put your file here',
              	fadeSpeed: 4000
              it is only working with a local file.
              in my config/config.js i did not change anything for compliments module.
              • Y
                yawns Moderator @DvdEnde
                @DvdEnde
                no, this information is wrong. And you should avoid modifying module files.
                Try what I have written above, it is working fine
                  DvdEnde @yawns
                  @yawns Sorry but your option did not work for me.
                  Also please check the original compliment.js file:
                  https://github.com/MichMich/MagicMirror/blob/develop/modules/default/compliments/compliments.js
                  it is standard prepared there.
                  Please also check line 50:
                  if (this.config.remoteFile != null) {
                  At first I also thought this would be the major config file, but it is not. Its the module.
                  If you console.log(this.config) it will give you an object like this. All information from the compliment.js
                      remoteFile: null,
                      fadeSpeed: 4000
                  That is why i think @schlachtkreuzer6 should give this a try.
                  You have also the latest version?
                  I understand that modules should not be changed.
                  Just trying to help.
                  Please do correct me if I am wrong!
                  strawberry 3.141S S 2 Replies Last reply Reply Quote 0
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @DvdEnde
                    @DvdEnde the part from the config in the config.js overwrites the values in default with Object.assign()
                    so when you define remoteFile in the config.js the null value is overwritten
                    • Y
                      yawns Moderator
                      @DvdEnde Please don’t get me wrong, but this is basic javascript.
                      this.config.remoteFile != null checks if the variable “remoteFile” is set in your config file. Afterwards you only have two scenarios:
                      1. the variable is not set -> this if clause fails and no remote file is loaded.
                      2. the variable is set to any value -> this if clause is true and the function complimentFile() is called, which tries to load the file defined in your config file, in my case “compliments.json”.
                      If loading the remote file fails you see an error message in console output of your browser. Otherwise it does not produce any log.
                        DvdEnde @yawns
                        @yawns
                        Don’t worry, i know it is basic javascript.
                        @strawberry-3-141
                        i thought so too, but it is NOT
                        I just now changed the compliment.js (and deleted the remoteFile completly from here) and added this within the config.
                        My object is simple
                            fadeSpeed: 4000
                        On line 33 console.log(this.config.remoteFile) = undefined
                          jcorraliza @yawns
                          @yawns OK I created a compliments_test.json file and pasted your example into it and it worked. It looks like it just doesn’t work with the currentweather objects in my compliments.json file for some reason. Do I need to nest the currentweather objects within the morning, afternoon, and evening arrays perhaps?
                            schlachtkreuzer6 @jcorraliza
                            @jcorraliza post your config.js and your remotefile pls
                              jcorraliza @schlachtkreuzer6
                              @schlachtkreuzer6 said in remoteFile in compliments module:
                              Hi there, I posted them a few posts up. It works with the time of day objects, but not with the currentweather objects in my .json file. I’m using v2.1.0, dev branch, and I’m using the currentweather default module.
                                schlachtkreuzer6 @DvdEnde
                                @DvdEnde MM is up to date and every module i git pull the latest version, nope it says it´s a invalid .json in the MM-Admin-Interface. i just can not use this config @yawns post:
                                if i try to start MM, it´s showing up, that the config is broken. even when i adjust it to the MM-Admin code:
                                	"module": "compliments",
                                	"position": "lower_third",
                                	"config": {
                                		"remoteFile": "compliments.json"
                                I´m not in javascript or anything coding. But nothing worked for me. maybe my system is somehow broken…
                                  DvdEnde @schlachtkreuzer6
                                  @schlachtkreuzer6
                                  The way you do it is the way it should be.
                                  BUT i also cannot get it to work like this.
                                  please try following:
                                  Open config/config.js and remove
                                  "config": {
                                  Then open your compliments.js and check:
                                  defaults: {
                                  		remoteFile: null,
                                  		fadeSpeed: 4000
                                  change remoteFile to a useable name:
                                  defaults: {
                                  		remoteFile: "~/path to your/compliments.json",
                                  		fadeSpeed: 4000
                                  then restart MM (or restart the PI)
                                    @DvdEnde i think my mirror has it´s own brain ^^ so i changed it like your post above. but MM just showing the default compliments. I don´t know whats wrong, but i think i will rebuild MM from the ground.
                                      DvdEnde
                                      #@schlachtkreuzer6
                                      If MM is showing the default compliments, where are they?
                                      Please post the complete defaults from your compliments.js AND
                                      the complete part of the json for compliments from your config.js.
                                      also post your jsonfile where to get your custom compliments.
                                      maybe we all misunderstand you?
                                        @DvdEnde the default compliments are in the module itself ok, here we go:
                                        ~/MagicMirror/config/config.js
                                        /* Magic Mirror Config Sample
                                        * MIT Licensed.
                                        var config = {
                                        	"port": 8080,
                                        	"language": "de",
                                        	"timeFormat": 24,
                                        	"units": "metric",
                                        	"modules": [
                                        			"module": "alert"
                                        			"module": "clock",
                                        			"position": "top_left"
                                        			"module": "calendar",
                                        			"header": "Google Kalender",
                                        			"position": "top_left",
                                        			"config": {
                                        				"calendars": [
                                        						"symbol": "calendar",
                                        						"url": "my link 1"
                                        						"url": "my link 2"
                                        						"url": "my link 3"
                                        						"url": "my link 4"
                                        						"url": "my link 4"
                                        						"url": "my link 5"
                                        				"timeFormat": "absolute",
                                        				"maximumEntries": "20",
                                        				"fadePoint": "0.55"
                                        			"config": {
                                        				"compliments": {
                                             					 morning: [
                                                 					 'Guten Morgen!',
                                                 					 'Wie hast du geschlafen?',
                                                 					 'Ich wünsche dir einen schönen Tag!'
                                            					 afternoon: [
                                                		 			 'Guten Tag!',
                                                 					 'Du schaust gut aus!',
                                                 					 'Wie war dein Tag!'
                                             					 evening: [
                                                  					 'Guten Abend!',
                                                  					 'Na wie war dein Tag?',
                                                  					 'Du warst heute fleßig!'
                                        				"updateInterval": 15000
                                        			"module": "currentweather",
                                        			"position": "top_right",
                                        			"config": {
                                        				"location": "my location",
                                        				"locationID": "",
                                        				"appid": "my api"
                                        			"module": "weatherforecast",
                                        			"header": "Wetter in den kommenden Tagen",
                                        			"config": {
                                        				"locationID": "",
                                        				"appid": "my api"
                                        			"module": "newsfeed",
                                        			"position": "bottom_bar",
                                        			"config": {
                                        				"feeds": [
                                        						"title": "Die Presse",
                                        						"url": "http://diepresse.com/rss/home"
                                        				"showSourceTitle": true,
                                        				"showPublishDate": true
                                        			"module": "MMM-Remote-Control"
                                        			"module": "mmm-wu-moonphase",
                                        			"header": "Aktuelle Mondphase",
                                        			"config": {
                                        				"apikey": "my api",
                                        				"country": "Austria",
                                        				"city": "Vienna",
                                        				"apiLang": "DL"
                                        			"module": "MMM-WienerLinien",
                                        			"config": {
                                        				"api_key": "my api",
                                        				"stations": [
                                        					"abcd",
                                        					"abcd"
                                        			"module": "MMM-SpotifyConnectUI",
                                        			"position": "fullscreen_below",
                                        			"config": {}
                                        			"module": "MMM-Globe",
                                        			"config": {
                                        				"style": "europeDiscNat",
                                        				"imageSize": 250,
                                        				"ownImagePath": "",
                                        				"updateInterval": 600000
                                        			"module": "internet-monitor",
                                        			"position": "top_bar",
                                        			"config": {
                                        				"type": "minimal",
                                        				"maxTime": 20000,
                                        				"updateInterval": 0,
                                        				"verbose": false,
                                        				"displayStrength": true,
                                        				"displaySpeed": false,
                                        				"strengthIconSize": 40,
                                        				"maxGaugeScale": 100
                                        			"module": "MMM-Traffic",
                                        			"config": {
                                        				"mode": "driving",
                                        				"origin": "my home",
                                        				"destination": "my work",
                                        				"arrival_time": "",
                                        				"route_name": "Home-work",
                                        				"changeColor": true,
                                        				"showGreen": false,
                                        				"limitYellow": 5,
                                        				"limitRed": 20,
                                        				"traffic_model": "pessimistic",
                                        				"interval": 120000,
                                        				"language": "de",
                                        				"prependText": "Derzeit"
                                        			"classes": "dimmed medium"
                                        			"module": "MMM-RandomPhoto",
                                        			"config": {
                                        				"opacity": 0.3,
                                        				"animationSpeed": 1500,
                                        				"updateInterval": 15,
                                        				"url": "https://unsplash.it/1080/1920/?random"
                                        			"module": "MMM-SystemStats",
                                        			"position": "bottom_right",
                                        			"config": {
                                        				"updateInterval": 10000,
                                        				"animationSpeed": 0
                                        			"classes": "small dimmed"
                                        			"module": "MMM-Admin-Interface"
                                        	"ipWhitelist": [
                                        		"::fff:0.0.0.0/1",
                                        		"::fff:128.0.0.0/2",
                                        		"::fff:192.0.0.0/3",
                                        		"::fff:224.0.0.0/4",
                                        		"127.0.0.1",
                                        		"::ffff:127.0.0.1",
                                        		"::1"
                                        this config is working perfect.
                                        ~/MagicMirror/modules/default/compliments/compliments.json (remoteFile) tried it also here ~/MagicMirror/config/compliments.json with and without absolut path.
                                              "morning": [
                                                  "Test1!",
                                                  "Test2?",
                                                  "Test3!"
                                             "afternoon": [
                                                  "Test4!",
                                                  "Test5!",
                                                  "Test6!"
                                             "evening": [
                                                   "Test7!",
                                                   "Test8?",
                                                   "Test9!"
                                        and ~/MagicMirror/modules/default/compliments/compliments.js
                                        * global Log, Module, moment */
                                        /* Magic Mirror
                                         * Module: Compliments
                                         * MIT Licensed.
                                        Module.register("compliments",{
                                        	// Module config defaults.
                                        	defaults: {
                                        		compliments: {
                                        			morning: [
                                        				"Good morning, handsome!",
                                        				"Enjoy your day!",
                                        				"How was your sleep?"
                                        			afternoon: [
                                        				"Hello, beauty!",
                                        				"You look sexy!",
                                        				"Looking good today!"
                                        			evening: [
                                        				"Wow, you look hot!",
                                        				"You look nice!",
                                        				"Hi, sexy!"
                                        		remoteFile: null,
                                        		fadeSpeed: 4000
                                        	// Set currentweather from module
                                        	currentWeatherType: "",
                                        	// Define required scripts.
                                        	getScripts: function() {
                                        		return ["moment.js"];
                                        	// Define start sequence.
                                        	start: function() {
                                        		this.lastComplimentIndex = -1;
                                        			this.complimentFile((response) => {
                                        				this.config.compliments = JSON.parse(response);
                                        		// Schedule update timer.
                                        		var self = this;
                                        		setInterval(function() {
                                        			self.updateDom(self.config.fadeSpeed);
                                        		}, this.config.updateInterval);
                                        	/* randomIndex(compliments)
                                        	 * Generate a random index for a list of compliments.
                                        	 * argument compliments Array<String> - Array with compliments.
                                        	 * return Number - Random index.
                                        	randomIndex: function(compliments) {
                                        		if (compliments.length === 1) {
                                        			return 0;
                                        		var generate = function() {
                                        			return Math.floor(Math.random() * compliments.length);
                                        		var complimentIndex = generate();
                                        		while (complimentIndex === this.lastComplimentIndex) {
                                        		this.lastComplimentIndex = complimentIndex;
                                        		return complimentIndex;
                                        	/* complimentArray()
                                        	 * Retrieve an array of compliments for the time of the day.
                                        	 * return compliments Array<String> - Array with compliments for the time of the day.
                                        	complimentArray: function() {
                                        		var hour = moment().hour();
                                        		var compliments  = null;
                                        		if (hour >= 3 && hour < 12) {
                                        			compliments = this.config.compliments.morning;
                                        		} else if (hour >= 12 && hour < 17) {
                                        			compliments = this.config.compliments.afternoon;
                                        		} else {
                                        			compliments = this.config.compliments.evening;
                                        		if ( this.currentWeatherType in this.config.compliments) {
                                        			compliments.push.apply(compliments, this.config.compliments[this.currentWeatherType]);
                                        		return compliments;
                                        	/* complimentFile(callback)
                                        	 * Retrieve a file from the local filesystem
                                        	complimentFile: function(callback) {
                                        		var xobj = new XMLHttpRequest();
                                        		xobj.overrideMimeType("application/json");
                                        		xobj.open("GET", this.file(this.config.remoteFile), true);
                                        		xobj.onreadystatechange = function () {
                                        			if (xobj.readyState == 4 && xobj.status == "200") {
                                        				callback(xobj.responseText);
                                        		xobj.send(null);
                                        	 * Retrieve a random compliment.
                                        	 * return compliment string - A compliment.
                                        	randomCompliment: function() {
                                        		var compliments = this.complimentArray();
                                        		var index = this.randomIndex(compliments);
                                        		return compliments[index];
                                        	// Override dom generator.
                                        	getDom: function() {
                                        		var complimentText = this.randomCompliment();
                                        		var compliment = document.createTextNode(complimentText);
                                        		wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright";
                                        		wrapper.appendChild(compliment);
                                        		return wrapper;
                                        	// From data currentweather set weather type
                                        	setCurrentWeatherType: function(data) {
                                        		var weatherIconTable = {
                                        			"01d": "day_sunny",
                                        			"02d": "day_cloudy",
                                        			"03d": "cloudy",
                                        			"04d": "cloudy_windy",
                                        			"09d": "showers",
                                        			"10d": "rain",
                                        			"11d": "thunderstorm",
                                        			"13d": "snow",
                                        			"50d": "fog",
                                        			"01n": "night_clear",
                                        			"02n": "night_cloudy",
                                        			"03n": "night_cloudy",
                                        			"04n": "night_cloudy",
                                        			"09n": "night_showers",
                                        			"10n": "night_rain",
                                        			"11n": "night_thunderstorm",
                                        			"13n": "night_snow",
                                        			"50n": "night_alt_cloudy_windy"
                                        		this.currentWeatherType = weatherIconTable[data.weather[0].icon];
                                        	// Override notification handler.
                                        		if (notification == "CURRENTWEATHER_DATA") {
                                        			this.setCurrentWeatherType(payload.data);
                                        even when i change it like you said above:
                                        defaults: {
                                        		remoteFile: "~/MagicMirror/modules/default/compliments/compliments.json",
                                        		fadeSpeed: 4000
                                        It´s showing then the default compliments. (hi sexy etc.)
                                        it´s working with my custom compliments in the config.js perfectly. but when i try this code:
                                        	"config": {
                                        MM showing the error srceen that i had to set up a config file.
                                        J D 2 Replies Last reply Reply Quote 0
                                          @schlachtkreuzer6
                                          	"config": {
                                          You have to get rid of those quotes around module, position, config, and remoteFile. It should look like this:
                                            @jcorraliza it´s from the MMM-Admin-Interface… after initializing this module, there quotes are everywhere… but sure i will try this too
                                            • 2 / 4
