    remoteFile in compliments module
    71 Posts 14 Posters 106.9k Views 15 Watching
    • Y Offline
      yawns Moderator @DvdEnde
      @DvdEnde
      no, this information is wrong. And you should avoid modifying module files.
      Try what I have written above, it is working fine
        DvdEnde @yawns
        @yawns Sorry but your option did not work for me.
        Also please check the original compliment.js file:
        https://github.com/MichMich/MagicMirror/blob/develop/modules/default/compliments/compliments.js
        it is standard prepared there.
        Please also check line 50:
        if (this.config.remoteFile != null) {
        At first I also thought this would be the major config file, but it is not. Its the module.
        If you console.log(this.config) it will give you an object like this. All information from the compliment.js
            updateInterval: 30000,
            remoteFile: null,
            fadeSpeed: 4000
        That is why i think @schlachtkreuzer6 should give this a try.
        You have also the latest version?
        I understand that modules should not be changed.
        Just trying to help.
        Please do correct me if I am wrong!
        strawberry 3.141S S 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @DvdEnde
          @DvdEnde the part from the config in the config.js overwrites the values in default with Object.assign()
          so when you define remoteFile in the config.js the null value is overwritten
          • Y Offline
            yawns Moderator
            @DvdEnde Please don’t get me wrong, but this is basic javascript.
            this.config.remoteFile != null checks if the variable “remoteFile” is set in your config file. Afterwards you only have two scenarios:
            1. the variable is not set -> this if clause fails and no remote file is loaded.
            2. the variable is set to any value -> this if clause is true and the function complimentFile() is called, which tries to load the file defined in your config file, in my case “compliments.json”.
            If loading the remote file fails you see an error message in console output of your browser. Otherwise it does not produce any log.
              DvdEnde @yawns
              @yawns
              Don’t worry, i know it is basic javascript.
              @strawberry-3-141
              i thought so too, but it is NOT
              I just now changed the compliment.js (and deleted the remoteFile completly from here) and added this within the config.
              My object is simple
                  fadeSpeed: 4000
              On line 33 console.log(this.config.remoteFile) = undefined
                jcorraliza @yawns
                @yawns OK I created a compliments_test.json file and pasted your example into it and it worked. It looks like it just doesn’t work with the currentweather objects in my compliments.json file for some reason. Do I need to nest the currentweather objects within the morning, afternoon, and evening arrays perhaps?
                  schlachtkreuzer6 @jcorraliza
                  @jcorraliza post your config.js and your remotefile pls
                    jcorraliza @schlachtkreuzer6
                    @schlachtkreuzer6 said in remoteFile in compliments module:
                    Hi there, I posted them a few posts up. It works with the time of day objects, but not with the currentweather objects in my .json file. I’m using v2.1.0, dev branch, and I’m using the currentweather default module.
                      schlachtkreuzer6 @DvdEnde
                      @DvdEnde MM is up to date and every module i git pull the latest version, nope it says it´s a invalid .json in the MM-Admin-Interface. i just can not use this config @yawns post:
                      	module: 'compliments',
                      	position: 'lower_third',
                      		remoteFile: 'compliments.json'
                      if i try to start MM, it´s showing up, that the config is broken. even when i adjust it to the MM-Admin code:
                      	"module": "compliments",
                      	"position": "lower_third",
                      	"config": {
                      		"remoteFile": "compliments.json"
                      I´m not in javascript or anything coding. But nothing worked for me. maybe my system is somehow broken…
                        DvdEnde @schlachtkreuzer6
                        @schlachtkreuzer6
                        The way you do it is the way it should be.
                        BUT i also cannot get it to work like this.
                        please try following:
                        Open config/config.js and remove
                        "config": {
                        Then open your compliments.js and check:
                        defaults: {
                        		remoteFile: null,
                        		fadeSpeed: 4000
                        change remoteFile to a useable name:
                        defaults: {
                        		remoteFile: "~/path to your/compliments.json",
                        		fadeSpeed: 4000
                        then restart MM (or restart the PI)
                          @DvdEnde i think my mirror has it´s own brain ^^ so i changed it like your post above. but MM just showing the default compliments. I don´t know whats wrong, but i think i will rebuild MM from the ground.
                            DvdEnde
                            #@schlachtkreuzer6
                            If MM is showing the default compliments, where are they?
                            Please post the complete defaults from your compliments.js AND
                            the complete part of the json for compliments from your config.js.
                            also post your jsonfile where to get your custom compliments.
                            maybe we all misunderstand you?
                              @DvdEnde the default compliments are in the module itself ok, here we go:
                              ~/MagicMirror/config/config.js
                              /* Magic Mirror Config Sample
                              * MIT Licensed.
                              var config = {
                              	"port": 8080,
                              	"language": "de",
                              	"timeFormat": 24,
                              	"units": "metric",
                              	"modules": [
                              			"module": "alert"
                              			"module": "clock",
                              			"position": "top_left"
                              			"module": "calendar",
                              			"header": "Google Kalender",
                              			"position": "top_left",
                              			"config": {
                              				"calendars": [
                              						"symbol": "calendar",
                              						"url": "my link 1"
                              						"url": "my link 2"
                              						"url": "my link 3"
                              						"url": "my link 4"
                              						"url": "my link 4"
                              						"url": "my link 5"
                              				"timeFormat": "absolute",
                              				"maximumEntries": "20",
                              				"fadePoint": "0.55"
                              			"config": {
                              				"compliments": {
                                   					 morning: [
                                       					 'Guten Morgen!',
                                       					 'Wie hast du geschlafen?',
                                       					 'Ich wünsche dir einen schönen Tag!'
                                  					 afternoon: [
                                      		 			 'Guten Tag!',
                                       					 'Du schaust gut aus!',
                                       					 'Wie war dein Tag!'
                                   					 evening: [
                                        					 'Guten Abend!',
                                        					 'Na wie war dein Tag?',
                                        					 'Du warst heute fleßig!'
                              				"updateInterval": 15000
                              			"module": "currentweather",
                              			"position": "top_right",
                              			"config": {
                              				"location": "my location",
                              				"locationID": "",
                              				"appid": "my api"
                              			"module": "weatherforecast",
                              			"header": "Wetter in den kommenden Tagen",
                              			"config": {
                              				"locationID": "",
                              				"appid": "my api"
                              			"module": "newsfeed",
                              			"position": "bottom_bar",
                              			"config": {
                              				"feeds": [
                              						"title": "Die Presse",
                              						"url": "http://diepresse.com/rss/home"
                              				"showSourceTitle": true,
                              				"showPublishDate": true
                              			"module": "MMM-Remote-Control"
                              			"module": "mmm-wu-moonphase",
                              			"header": "Aktuelle Mondphase",
                              			"config": {
                              				"apikey": "my api",
                              				"country": "Austria",
                              				"city": "Vienna",
                              				"apiLang": "DL"
                              			"module": "MMM-WienerLinien",
                              			"config": {
                              				"api_key": "my api",
                              				"stations": [
                              					"abcd",
                              					"abcd"
                              			"module": "MMM-SpotifyConnectUI",
                              			"position": "fullscreen_below",
                              			"config": {}
                              			"module": "MMM-Globe",
                              			"config": {
                              				"style": "europeDiscNat",
                              				"imageSize": 250,
                              				"ownImagePath": "",
                              				"updateInterval": 600000
                              			"module": "internet-monitor",
                              			"position": "top_bar",
                              			"config": {
                              				"type": "minimal",
                              				"maxTime": 20000,
                              				"updateInterval": 0,
                              				"verbose": false,
                              				"displayStrength": true,
                              				"displaySpeed": false,
                              				"strengthIconSize": 40,
                              				"maxGaugeScale": 100
                              			"module": "MMM-Traffic",
                              			"config": {
                              				"mode": "driving",
                              				"origin": "my home",
                              				"destination": "my work",
                              				"arrival_time": "",
                              				"route_name": "Home-work",
                              				"changeColor": true,
                              				"showGreen": false,
                              				"limitYellow": 5,
                              				"limitRed": 20,
                              				"traffic_model": "pessimistic",
                              				"interval": 120000,
                              				"language": "de",
                              				"prependText": "Derzeit"
                              			"classes": "dimmed medium"
                              			"module": "MMM-RandomPhoto",
                              			"config": {
                              				"opacity": 0.3,
                              				"animationSpeed": 1500,
                              				"updateInterval": 15,
                              				"url": "https://unsplash.it/1080/1920/?random"
                              			"module": "MMM-SystemStats",
                              			"position": "bottom_right",
                              			"config": {
                              				"updateInterval": 10000,
                              				"animationSpeed": 0
                              			"classes": "small dimmed"
                              			"module": "MMM-Admin-Interface"
                              	"ipWhitelist": [
                              		"::fff:0.0.0.0/1",
                              		"::fff:128.0.0.0/2",
                              		"::fff:192.0.0.0/3",
                              		"::fff:224.0.0.0/4",
                              		"127.0.0.1",
                              		"::ffff:127.0.0.1",
                              		"::1"
                              this config is working perfect.
                              ~/MagicMirror/modules/default/compliments/compliments.json (remoteFile) tried it also here ~/MagicMirror/config/compliments.json with and without absolut path.
                                    "morning": [
                                        "Test1!",
                                        "Test2?",
                                        "Test3!"
                                   "afternoon": [
                                        "Test4!",
                                        "Test5!",
                                        "Test6!"
                                   "evening": [
                                         "Test7!",
                                         "Test8?",
                                         "Test9!"
                              and ~/MagicMirror/modules/default/compliments/compliments.js
                              * global Log, Module, moment */
                              /* Magic Mirror
                               * Module: Compliments
                               * MIT Licensed.
                              Module.register("compliments",{
                              	// Module config defaults.
                              	defaults: {
                              		compliments: {
                              			morning: [
                              				"Good morning, handsome!",
                              				"Enjoy your day!",
                              				"How was your sleep?"
                              			afternoon: [
                              				"Hello, beauty!",
                              				"You look sexy!",
                              				"Looking good today!"
                              			evening: [
                              				"Wow, you look hot!",
                              				"You look nice!",
                              				"Hi, sexy!"
                              		remoteFile: null,
                              		fadeSpeed: 4000
                              	// Set currentweather from module
                              	currentWeatherType: "",
                              	// Define required scripts.
                              	getScripts: function() {
                              		return ["moment.js"];
                              	// Define start sequence.
                              	start: function() {
                              		this.lastComplimentIndex = -1;
                              			this.complimentFile((response) => {
                              				this.config.compliments = JSON.parse(response);
                              		// Schedule update timer.
                              		var self = this;
                              		setInterval(function() {
                              			self.updateDom(self.config.fadeSpeed);
                              		}, this.config.updateInterval);
                              	/* randomIndex(compliments)
                              	 * Generate a random index for a list of compliments.
                              	 * argument compliments Array<String> - Array with compliments.
                              	 * return Number - Random index.
                              	randomIndex: function(compliments) {
                              		if (compliments.length === 1) {
                              			return 0;
                              		var generate = function() {
                              			return Math.floor(Math.random() * compliments.length);
                              		var complimentIndex = generate();
                              		while (complimentIndex === this.lastComplimentIndex) {
                              		this.lastComplimentIndex = complimentIndex;
                              		return complimentIndex;
                              	/* complimentArray()
                              	 * Retrieve an array of compliments for the time of the day.
                              	 * return compliments Array<String> - Array with compliments for the time of the day.
                              	complimentArray: function() {
                              		var hour = moment().hour();
                              		var compliments  = null;
                              		if (hour >= 3 && hour < 12) {
                              			compliments = this.config.compliments.morning;
                              		} else if (hour >= 12 && hour < 17) {
                              			compliments = this.config.compliments.afternoon;
                              		} else {
                              			compliments = this.config.compliments.evening;
                              		if ( this.currentWeatherType in this.config.compliments) {
                              			compliments.push.apply(compliments, this.config.compliments[this.currentWeatherType]);
                              		return compliments;
                              	/* complimentFile(callback)
                              	 * Retrieve a file from the local filesystem
                              	complimentFile: function(callback) {
                              		var xobj = new XMLHttpRequest();
                              		xobj.overrideMimeType("application/json");
                              		xobj.open("GET", this.file(this.config.remoteFile), true);
                              		xobj.onreadystatechange = function () {
                              			if (xobj.readyState == 4 && xobj.status == "200") {
                              				callback(xobj.responseText);
                              		xobj.send(null);
                              	 * Retrieve a random compliment.
                              	 * return compliment string - A compliment.
                              	randomCompliment: function() {
                              		var compliments = this.complimentArray();
                              		var index = this.randomIndex(compliments);
                              		return compliments[index];
                              	// Override dom generator.
                              	getDom: function() {
                              		var complimentText = this.randomCompliment();
                              		var compliment = document.createTextNode(complimentText);
                              		wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright";
                              		wrapper.appendChild(compliment);
                              		return wrapper;
                              	// From data currentweather set weather type
                              	setCurrentWeatherType: function(data) {
                              		var weatherIconTable = {
                              			"01d": "day_sunny",
                              			"02d": "day_cloudy",
                              			"03d": "cloudy",
                              			"04d": "cloudy_windy",
                              			"09d": "showers",
                              			"10d": "rain",
                              			"11d": "thunderstorm",
                              			"13d": "snow",
                              			"50d": "fog",
                              			"01n": "night_clear",
                              			"02n": "night_cloudy",
                              			"03n": "night_cloudy",
                              			"04n": "night_cloudy",
                              			"09n": "night_showers",
                              			"10n": "night_rain",
                              			"11n": "night_thunderstorm",
                              			"13n": "night_snow",
                              			"50n": "night_alt_cloudy_windy"
                              		this.currentWeatherType = weatherIconTable[data.weather[0].icon];
                              	// Override notification handler.
                              		if (notification == "CURRENTWEATHER_DATA") {
                              			this.setCurrentWeatherType(payload.data);
                              even when i change it like you said above:
                              defaults: {
                              		remoteFile: "~/MagicMirror/modules/default/compliments/compliments.json",
                              		fadeSpeed: 4000
                              It´s showing then the default compliments. (hi sexy etc.)
                              it´s working with my custom compliments in the config.js perfectly. but when i try this code:
                              	"config": {
                              MM showing the error srceen that i had to set up a config file.
                              J D 2 Replies Last reply Reply Quote 0
                                @schlachtkreuzer6
                                	"config": {
                                You have to get rid of those quotes around module, position, config, and remoteFile. It should look like this:
                                  @jcorraliza it´s from the MMM-Admin-Interface… after initializing this module, there quotes are everywhere… but sure i will try this too
                                    @schlachtkreuzer6
                                    You have tried many things, we can see it.
                                    Maybe you cleanup the mess a little.
                                    IN de config/confg.js remove the complete “config” from “module”: “compliments”.
                                    "config": {
                                    				"compliments": {
                                    take away the quotes also like @jcorraliza adviced.
                                    So the config.js looks like this (for your compliment module)
                                    	module: "compliments",
                                    	position: "lower_third"
                                    then in the compliments.js you default sould look like this:
                                    defaults: {
                                    		fadeSpeed: 4000
                                    It should run.
                                      @jcorraliza haha I can not believe it!!! now it´s working. okay so here is what i did:
                                      so after ending with an error and resetting all the configs and .js files to default and my latest working config.js (post it above)
                                      i shut it down
                                      some hours later i boot it up again, and via putty ssh I copy and paste this code in the config.js:
                                      the comliments.js file is still located here: ~/MagicMirror/modules/default/compliments
                                      then i restart the MM via pm2 restart mm
                                      now it´s working with the compliments from the readme:
                                          "morning" : [
                                              "heyho"
                                          "afternoon" : [
                                              "home early?"
                                          "evening" : [
                                              "finally home"
                                              "fog" : [
                                                      "fog, oh no :("
                                      but anyway, the MMM-Admin-Interface changed the config.json to this again ^^:
                                        "config": {
                                      many thanks for your help, and time!
                                        [[global:former-user]]
                                        hey, sorry for being a bit silent. was travelling with no access to my raspberry. will give your solution a shot, too. why does it have to be a local file, though? my plan was to (in a 2nd step) place the compliments.json in my dropbox folder, so i can easily change the compliments remotely.
                                        B D 2 Replies Last reply Reply Quote 0
                                          bhepler Module Developer @Guest
                                          @skr Because I’m a crap coder in Javascript.
                                          Sorry for not helping earlier, folks. I was at a wedding and delivering my mirror as a gift. I’ll investigate and see if I can’t improve the mirror code.
                                          You should not ever have to modify the compliments.js file. You should be able to pull it off with just modifications to the config.js file.
                                            DvdEnde
                                            @schlachtkreuzer6
                                            Because it worked with you as it should be, so I changed my whole MM installation.
                                            I did manage to keep the compliments unchanged too.
                                            :D I am happy …
                                            @strawberry-3-141 @yawns thanks guys. Your info helped me too a lot!
                                            • 2 / 4
