    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 429.4k Views 32 Watching
      DDE12 @BKeyport
      @BKeyport
      I think I need to use something other than width: ##px so that it adjusts based on how much space the time takes. Is there a way to make startTime " - " endTime into a string or something and then align that to the right?
      .CX3A {
        font-size: 16px;
        min-width: 300px;
        max-width: 400px;
        text-align: left;
        color: lightgray;
        --saturdayColor : white;
        --sundayColor: white;
        --todayColor: gold;
      /* +++  Colored dot before event +++ */
      .CX3A .event .headline .symbol {
        color: var(--calendarColor);
        font-size: 75%;
        vertical-align: text-bottom;
      .CX3A .event .headline .symbol.noSymbol::after {
        content: '|';
        font-weight: bold;
      /*  ++++ Divider Lines +++ */
      .CX3A .agenda .cell {
        padding-top: 2px;
        border-top: 1px solid gray;
        margin-top: 2px;
      .CX3A .cellHeaderMain {
        display: flex;
        gap: 3px;
        text-transform: capitalize;
      /* +++ Show/Hide event description or location +++ */
      /*.CX3A .agenda .event .description, */
      .CX3A .agenda .event .location {
        display: none;
      /* +++ Change order of info displayed +++ */
      /* to test text-wrapping */
      /*.CX3A {
        width: 300px;
      *.CX3A .cellBody .fullday .event {
        width: 100%;
      /* +++  Event title +++ */
      .CX3A .event .title {
        order: 1;
        width: 120px; /* Adjust for your region width. Here I am using fixed value to make things simple */
        flex-grow: 1;
      .CX3A .event .time.startTime {
        order: 2;
        width: 52px;
        text-align: right;
      .CX3A .event .startTime::after {
        content: ' -';
      .CX3A .event .time.endTime {
        order: 2;
        width: 65px;
        text-align: right;
      .CX3A .event .symbol {
        order: 3;
      .CX3A .event .headline {
        justify-content: space-between;
      • BKeyportB
        BKeyport Module Developer @DDE12
        @DDE12
        Well… I believe you can tell it to take up a percentage of space rather than an absolute of space, but don’t quote me on that. I’m not a wizard on how the CSS works, the original stuff I used was MMRize’s, and just tweaked from there.
        Also, that’s not the entire CSS for CX3A - what I was curious about was your long text work - it’s what is still causing me issues today.
          DDE12 @BKeyport
          @BKeyport
          Maybe someone with CSS Wizard skills can help us out. I am far from a wizard with any of this stuff, I just come up with impossible ideas.
          Do you know what css your are looking for specifically? I might have changed something in the module’s css and forgot to move it over to mine. “Is it the Test 8 with a lot of words to test wrapping and such” that you are interested in?
          • BKeyportB
            @DDE12 yeah, I was referring to Test 8…
            as for changing the module’s CSS. Please go through and move everything to custom.css and restore the default file. When @MMRize updates, it’ll break things to leave your changes in the module’s CSS file. git restore is the command you need to back out your changes…
            Honestly, if you’ve made changes to his file, what I’d do is:
            cp MMM-CalendarExt3Agenda.css mine.css
            git restore MMM-CalendarExt3Agenda.css
            then compare MMM-CalendarExt3Agenda.css with mine.css to remember what you’ve changed.
            Easiest way.
              DDE12 @BKeyport
              @BKeyport
              I have been working on a new install of MM to clean everything up. I worked on CalExt3Ag today and I hope this helps you. Here is my entire custom Css. I am using Firefox in Windows 10.
              .CX3A_MAGIC {
                display:none;
              .CX3A {
                font-size: 16px;
                min-width: 300px;
                max-width: 400px;
                text-align: left;
                color: lightgray;
                --todayColor: gold;
              /* +++  Colored symbol before event +++ */
                font-size: 75%;
                /*content: '⬤';/**/
                content: '|';
                font-family: Impact;
                font-weight: bold;
                /*display: inline-block;
                /*padding-right: 2px;/**/
                padding-top: 2px;
                margin-top: 2px;
                display: flex;
                gap: 3px;
                display: none;
              /*.CX3A {
                width: 300px;
                width: 100%;
                order: 1;
                width: 135px; /* Adjust for your region width. Here I am using fixed value to make things simple */
                text-overflow: ellipsis;
                overflow: hidden;
                white-space: nowrap;/**/
                padding-left: 2px;
                flex-grow: 1;
                order: 2;
                width: 79px;
                text-align: right;
                content: ' -';
                order: 3;
                width: 45px;
                text-align: left;
                order: 4;
              .CX3A .event .description {
                overflow: hidden;
                max-width: 100%;
                font-size: 90%;
                color: orange;
                padding-left: 20px;
              Looks like:
              Changing only .CX3A .event .title.
                order: 1;
                /*text-overflow: ellipsis;
                overflow: hidden;
                padding-left: 1px;
                flex-grow: 1;
              Gives:
              I think you are wanting the wrapping and I do not LOL.
                shizzlesticks
                I’m confused how to implement the eventFilter. In the documentation it’s listed in the config properties but references a section that is with the CSS and DOM model. Should I just include it in my config.js?
                Here’s what I’m trying and it’s not removing the events like I want:
                	module: "MMM-CalendarExt3Agenda",
                		instanceId: "familyCalendar",
                		calendarSet: ['Cal1', 'Cal2', 'Cal3', 'Cal4'],
                		useWeather: false,
                		showMiniMonthCalendar: false,
                		useSymbol: true,
                		waitFetch: 20000,
                		eventFilter: {
                			eventFilter: (ev) => {
                				if (ev.title.search('Your statement is ready') > -1) return false
                				return true
                  MMRIZE @shizzlesticks
                  @shizzlesticks
                  waitFetch: 20000,
                  	return true
                    shizzlesticks @MMRIZE
                    @MMRIZE That worked. Thanks for the help and finding my stupid mistake.
                    You’ve made a nice module here. Enjoy a few coffees on me, thanks.
                    • luisestradaL
                      luisestrada
                      I noticed when I select envcanada as my forecast provider I just get today’s value, not for the rest of the week. The issue happens in both, MMM-CalendarExt3 & MMM-CalendarExt3Agenda. :crying_face:
                      			module: "weather",
                      			header: "Forecast",
                      				weatherProvider: "envcanada",
                      				type: "forecast",
                      				maxNumberOfDays: "7",
                      				siteCode: "s0000635",
                      				provCode: "QC"
                        MMRIZE @luisestrada
                        @luisestrada
                        Maybe its forecasted data format is different from the default OpenWeatherMap service.
                        I’ll check envcanada service.
                          MMRIZE @luisestrada
                          @luisestrada
                          Hmmm… With my test, it works as expected.
                          This is what I used for config;
                          luisestradaL 2 Replies Last reply Reply Quote 0
                          • luisestradaL
                            luisestrada @MMRIZE
                            @MMRIZE said in MMM-CalendarExt3Agenda:
                            @luisestrada
                            Thanks, I made the changes you did and it did not work, I hope it’s not because I updated Electron to the most recent version :downcast_face_with_sweat:
                            • BKeyportB
                              BKeyport Module Developer @MMRIZE
                              @MMRIZE Question for ya - how do you hide empty days? I would love to do that.
                              thanks!
                              luisestradaL 1 Reply Last reply Reply Quote 0
                              • luisestradaL
                                luisestrada @BKeyport
                                @BKeyport
                                I think it’s this
                                Show the days only which has event on the day.
                                .CX3A .agenda .cell[data-events-counts="0"] {
                                  display: none;
                                BKeyportB 1 Reply Last reply Reply Quote 1
                                • luisestradaL
                                  luisestrada @MMRIZE
                                  @MMRIZE I changed the module weatherProvider to “openweathermap”, for the type “forecast” and now it works.
                                  I kept “envcanada” for the type “current”, though.
                                  • BKeyportB
                                    BKeyport Module Developer @luisestrada
                                    @luisestrada said in MMM-CalendarExt3Agenda:
                                    .CX3A .agenda .cell[data-events-counts=“0”] {
                                    display: none;
                                    Perfect. Thank you.
                                      MMRIZE @luisestrada
                                      @luisestrada
                                      Hmmm. maybe the Locale issue. Could you send me your whole configuration(But to make things simple, drop out all other modules except MMM-CX3 and Weather(envCanada)) (eouia0819@gmail.com)
                                      By the way, What’s the Tesla module?
                                      BKeyportB luisestradaL 2 Replies Last reply Reply Quote 0
                                      • BKeyportB
                                        @MMRIZE I’m not quite sure how to do this -
                                        I want to filter one calendar source only. This source is the schedule of an entire league, and I only want to include the “Seattle” Team. Can you help me with the filter code so I can do so?
                                        Thanks!
                                          MMRIZE @BKeyport
                                          @BKeyport
                                          How can you distinguish? The target team name is included in the title of the event?
                                          • BKeyportB
                                            @MMRIZE 🏈 in the title for the one I want, and/or calendar name is “XFL”
                                            • 11
                                            • 12
                                            • 4 / 12
