    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 416.7k Views 32 Watching
      MMRIZE @luisestrada
      @luisestrada
      Hmmm… With my test, it works as expected.
      This is what I used for config;
      luisestradaL 2 Replies Last reply Reply Quote 0
      • luisestradaL Offline
        luisestrada @MMRIZE
        @MMRIZE said in MMM-CalendarExt3Agenda:
        @luisestrada
        Thanks, I made the changes you did and it did not work, I hope it’s not because I updated Electron to the most recent version :downcast_face_with_sweat:
        • BKeyportB Offline
          BKeyport Module Developer @MMRIZE
          @MMRIZE Question for ya - how do you hide empty days? I would love to do that.
          thanks!
          luisestradaL 1 Reply Last reply Reply Quote 0
            luisestrada @BKeyport
            @BKeyport
            I think it’s this
            Show the days only which has event on the day.
            .CX3A .agenda .cell[data-events-counts="0"] {
              display: none;
            BKeyportB 1 Reply Last reply Reply Quote 1
              luisestrada @MMRIZE
              @MMRIZE I changed the module weatherProvider to “openweathermap”, for the type “forecast” and now it works.
              I kept “envcanada” for the type “current”, though.
              • BKeyportB Offline
                BKeyport Module Developer @luisestrada
                @luisestrada said in MMM-CalendarExt3Agenda:
                .CX3A .agenda .cell[data-events-counts=“0”] {
                display: none;
                Perfect. Thank you.
                  MMRIZE @luisestrada
                  @luisestrada
                  Hmmm. maybe the Locale issue. Could you send me your whole configuration(But to make things simple, drop out all other modules except MMM-CX3 and Weather(envCanada)) (eouia0819@gmail.com)
                  By the way, What’s the Tesla module?
                  BKeyportB luisestradaL 2 Replies Last reply Reply Quote 0
                  • BKeyportB Offline
                    @MMRIZE I’m not quite sure how to do this -
                    I want to filter one calendar source only. This source is the schedule of an entire league, and I only want to include the “Seattle” Team. Can you help me with the filter code so I can do so?
                    Thanks!
                      MMRIZE @BKeyport
                      @BKeyport
                      How can you distinguish? The target team name is included in the title of the event?
                      • BKeyportB Offline
                        @MMRIZE 🏈 in the title for the one I want, and/or calendar name is “XFL”
                          sdetweil @BKeyport
                          @BKeyport
                          eventFilter: (ev) => {
                          	if (ev.title.search('XFL') > -1) {Set color, whatever; }
                          	return true
                          • BKeyportB Offline
                            @sdetweil XFL isn’t in the title - just the calendar name.
                              sdetweil @BKeyport
                              @BKeyport said in MMM-CalendarExt3Agenda:
                              which is it,?
                              • BKeyportB Offline
                                @sdetweil finish reading my statement. What’s unique abou that calendar is two things:
                                1. In the title, the football emoji. (stripped by a transform)
                                2. The calendar name is “XFL”
                                  MMRIZE @BKeyport
                                  @BKeyport
                                  You may use “calendarSet: [ … ]” in configuration to allow specific calendars only.
                                  Or you can use “calendarName” property in the transformer function.
                                    luisestrada @MMRIZE
                                    @MMRIZE Sorry I could not reply sooner.
                                    The Tesla module is the module below
                                    MMM-TeslaLogger https://github.com/spitzlbergerj/MMM-TeslaLogger
                                    I use Teslamate to extract the data from the car.
                                    I will send you my calendar code to your email.
                                    I also realized the last event (Saturday, Feb 18, in my screenshot) shows in my calendar but not in the agenda, If I take less days it does not show the last event. I did not see the issue when the last day was the 23rd, probably because the event started on the 22nd.
                                      MMRIZE
                                      1.2.0 (2023-04-25)
                                      • ADDED: weatherNotification, eventNotification - To get data from 3rd party module which is not compatible with default modules.
                                      • ADDED: weatherPayload, eventPayload - To manipulate or to convert received payload itself on time. (e.g. Convert Celcius unit to Fahrenheit unit)
                                      • ADDED: Hiding day cell which has no event : onlyEventDays: n
                                      • CHANGED : Display whole month events in miniCalendar regardless of agenda showing (despite endDayIndex or onlyEventDays)
                                      • CHANGED: Shared library to fix many issues.
                                      • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
                                      • FIXED : Pooling events with multi-calendar modules’ notification
                                      • FIXED: position issue (I hope so…)
                                      • FIXED: some typo.
                                      • FIXED: flickering for many reasons (logic error to treat notifications)
                                      sc
                                      • BKeyportB Offline
                                        @MMRIZE
                                        Broke: My install… Nothing is coming up. I’ve attempted removing my custom CSS, which doesn’t help, so I’m figuring it’s something in my config. Here’s one of the 3 instances.
                                        Nothing showing up in the logs, which are set for info, log, warn, error, and debug.
                                        			module: "MMM-CalendarExt3Agenda", // https://github.com/MMRIZE/MMM-CalendarExt3Agenda
                                        				instanceId: "1",
                                        				showMiniMonthCalendar: false,
                                        				firstDayOfWeek: 0,
                                        				startDayIndex: 0,
                                        				endDayIndex: 99,
                                        				minimalDaysOfNewYear: 1,
                                        				animationSpeed: 0,
                                        				useSymbol: false,
                                        				useWeather: false,
                                        				calendarSet: ["Main", "Utility"],
                                        				eventTransformer: (ev) => {
                                        					if (ev.title.search("⚾") > -1) {
                                        						ev.title = ev.title.replace("⚾️ ","");
                                        					if (ev.title.search("Bowling") > -1) {
                                        						ev.color = 'yellow';
                                        					if (ev.title.search("🏈") > -1) {
                                        						ev.title = ev.title.replace("🏈 ","");
                                        					return ev
                                          sdetweil @BKeyport
                                          @BKeyport its all in the browser, so open the developers window, console tab
                                          put ext3 in the filter field
                                          • BKeyportB Offline
                                            @sdetweil You really think I forgot to check that?
                                            I did forget to look at the console, though:
                                            • 11
                                            • 12
                                            • 5 / 12
