    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 361.1k Views 32 Watching
    • BKeyportB Offline
      BKeyport Module Developer @MMRIZE
      @MMRIZE 🏈 in the title for the one I want, and/or calendar name is “XFL”
        sdetweil @BKeyport
        @BKeyport
        eventFilter: (ev) => {
        	if (ev.title.search('XFL') > -1) {Set color, whatever; }
        	return true
        • BKeyportB Offline
          @sdetweil XFL isn’t in the title - just the calendar name.
            sdetweil @BKeyport
            @BKeyport said in MMM-CalendarExt3Agenda:
            which is it,?
            • BKeyportB Offline
              @sdetweil finish reading my statement. What’s unique abou that calendar is two things:
              1. In the title, the football emoji. (stripped by a transform)
              2. The calendar name is “XFL”
                MMRIZE @BKeyport
                @BKeyport
                You may use “calendarSet: [ … ]” in configuration to allow specific calendars only.
                Or you can use “calendarName” property in the transformer function.
                • luisestradaL Offline
                  luisestrada @MMRIZE
                  @MMRIZE Sorry I could not reply sooner.
                  The Tesla module is the module below
                  MMM-TeslaLogger https://github.com/spitzlbergerj/MMM-TeslaLogger
                  I use Teslamate to extract the data from the car.
                  I will send you my calendar code to your email.
                  I also realized the last event (Saturday, Feb 18, in my screenshot) shows in my calendar but not in the agenda, If I take less days it does not show the last event. I did not see the issue when the last day was the 23rd, probably because the event started on the 22nd.
                    MMRIZE
                    1.2.0 (2023-04-25)
                    • ADDED: weatherNotification, eventNotification - To get data from 3rd party module which is not compatible with default modules.
                    • ADDED: weatherPayload, eventPayload - To manipulate or to convert received payload itself on time. (e.g. Convert Celcius unit to Fahrenheit unit)
                    • ADDED: Hiding day cell which has no event : onlyEventDays: n
                    • CHANGED : Display whole month events in miniCalendar regardless of agenda showing (despite endDayIndex or onlyEventDays)
                    • CHANGED: Shared library to fix many issues.
                    • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
                    • FIXED : Pooling events with multi-calendar modules’ notification
                    • FIXED: position issue (I hope so…)
                    • FIXED: some typo.
                    • FIXED: flickering for many reasons (logic error to treat notifications)
                    sc
                    • BKeyportB Offline
                      @MMRIZE
                      Broke: My install… Nothing is coming up. I’ve attempted removing my custom CSS, which doesn’t help, so I’m figuring it’s something in my config. Here’s one of the 3 instances.
                      Nothing showing up in the logs, which are set for info, log, warn, error, and debug.
                      			module: "MMM-CalendarExt3Agenda", // https://github.com/MMRIZE/MMM-CalendarExt3Agenda
                      				instanceId: "1",
                      				showMiniMonthCalendar: false,
                      				firstDayOfWeek: 0,
                      				startDayIndex: 0,
                      				endDayIndex: 99,
                      				minimalDaysOfNewYear: 1,
                      				animationSpeed: 0,
                      				useSymbol: false,
                      				useWeather: false,
                      				calendarSet: ["Main", "Utility"],
                      				eventTransformer: (ev) => {
                      					if (ev.title.search("⚾") > -1) {
                      						ev.title = ev.title.replace("⚾️ ","");
                      					if (ev.title.search("Bowling") > -1) {
                      						ev.color = 'yellow';
                      					if (ev.title.search("🏈") > -1) {
                      						ev.title = ev.title.replace("🏈 ","");
                      					return ev
                        sdetweil @BKeyport
                        @BKeyport its all in the browser, so open the developers window, console tab
                        put ext3 in the filter field
                        • 10
                        • 11
                        • 22
                        • 23
                        • 9 / 23
