    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 415.2k Views 32 Watching
    • BKeyportB Offline
      BKeyport Module Developer @MMRIZE
      @MMRIZE 🏈 in the title for the one I want, and/or calendar name is “XFL”
        sdetweil @BKeyport
        @BKeyport
        eventFilter: (ev) => {
        	if (ev.title.search('XFL') > -1) {Set color, whatever; }
        	return true
        • BKeyportB Offline
          @sdetweil XFL isn’t in the title - just the calendar name.
            sdetweil @BKeyport
            @BKeyport said in MMM-CalendarExt3Agenda:
            which is it,?
            • BKeyportB Offline
              @sdetweil finish reading my statement. What’s unique abou that calendar is two things:
              1. In the title, the football emoji. (stripped by a transform)
              2. The calendar name is “XFL”
                MMRIZE @BKeyport
                @BKeyport
                You may use “calendarSet: [ … ]” in configuration to allow specific calendars only.
                Or you can use “calendarName” property in the transformer function.
                • luisestradaL Offline
                  luisestrada @MMRIZE
                  @MMRIZE Sorry I could not reply sooner.
                  The Tesla module is the module below
                  MMM-TeslaLogger https://github.com/spitzlbergerj/MMM-TeslaLogger
                  I use Teslamate to extract the data from the car.
                  I will send you my calendar code to your email.
                  I also realized the last event (Saturday, Feb 18, in my screenshot) shows in my calendar but not in the agenda, If I take less days it does not show the last event. I did not see the issue when the last day was the 23rd, probably because the event started on the 22nd.
                    MMRIZE
                    1.2.0 (2023-04-25)
                    • ADDED: weatherNotification, eventNotification - To get data from 3rd party module which is not compatible with default modules.
                    • ADDED: weatherPayload, eventPayload - To manipulate or to convert received payload itself on time. (e.g. Convert Celcius unit to Fahrenheit unit)
                    • ADDED: Hiding day cell which has no event : onlyEventDays: n
                    • CHANGED : Display whole month events in miniCalendar regardless of agenda showing (despite endDayIndex or onlyEventDays)
                    • CHANGED: Shared library to fix many issues.
                    • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
                    • FIXED : Pooling events with multi-calendar modules’ notification
                    • FIXED: position issue (I hope so…)
                    • FIXED: some typo.
                    • FIXED: flickering for many reasons (logic error to treat notifications)
                    sc
                    • BKeyportB Offline
                      @MMRIZE
                      Broke: My install… Nothing is coming up. I’ve attempted removing my custom CSS, which doesn’t help, so I’m figuring it’s something in my config. Here’s one of the 3 instances.
                      Nothing showing up in the logs, which are set for info, log, warn, error, and debug.
                      			module: "MMM-CalendarExt3Agenda", // https://github.com/MMRIZE/MMM-CalendarExt3Agenda
                      				instanceId: "1",
                      				showMiniMonthCalendar: false,
                      				firstDayOfWeek: 0,
                      				startDayIndex: 0,
                      				endDayIndex: 99,
                      				minimalDaysOfNewYear: 1,
                      				animationSpeed: 0,
                      				useSymbol: false,
                      				useWeather: false,
                      				calendarSet: ["Main", "Utility"],
                      				eventTransformer: (ev) => {
                      					if (ev.title.search("⚾") > -1) {
                      						ev.title = ev.title.replace("⚾️ ","");
                      					if (ev.title.search("Bowling") > -1) {
                      						ev.color = 'yellow';
                      					if (ev.title.search("🏈") > -1) {
                      						ev.title = ev.title.replace("🏈 ","");
                      					return ev
                        sdetweil @BKeyport
                        @BKeyport its all in the browser, so open the developers window, console tab
                        put ext3 in the filter field
                        • BKeyportB Offline
                          @sdetweil You really think I forgot to check that?
                          I did forget to look at the console, though:
                            no idea that the ‘not prepared yet’ means
                            • BKeyportB Offline
                              @sdetweil Same. I figure there’s an option somewhere that’s preventing me from loading it fully. I’m sure @MMRIZE will have it fixed right away.
                                MMRIZE @BKeyport
                                @BKeyport
                                I refactored all the duplicated logics in these modules and separate it with sub module named ‘CX3_Shared’.
                                That message happens when that submodule is not loaded(with certain reason). Most suspicious thing would be that submodule is not installed properly. Could you check it again?
                                https://github.com/MMRIZE/MMM-CalendarExt3Agenda#update-to-120
                                • N Named54 referenced this topic on
                                • BKeyportB Offline
                                  @MMRIZE Oh, doh! you gave in and had to install a dependancy/submodule! 🤣🤣🤣
                                  Missed that.
                                  • BKeyportB Offline
                                    Doing some clean up work and some things aren’t working.
                                    The module isn’t updating in my config.
                                    Here is the configs and details.
                                    				instanceId: "1",
                                    				firstDayOfWeek: 0,
                                    				startDayIndex: 0,
                                    				endDayIndex: 99,
                                    				animationSpeed: 0,
                                    				useSymbol: false,
                                    				useWeather: false,
                                    					return ev
                                    //top_center
                                    			position: "top_center",
                                    				instanceId: "2",
                                    				firstDayOfWeek: 0,
                                    				startDayIndex: 0,
                                    				endDayIndex: 99,
                                    				animationSpeed: 0,
                                    				useSymbol: false,
                                    				useWeather: false,
                                    				calendarSet: ["Seahawks", "Sounders", "Bluejays", "Mariners", "Kraken", "Huskies", "XFL", "ARES", "Holdays"],
                                    						ev.title = ev.title.replace("⚾","");
                                    					return ev
                                    				instanceId: "3",
                                    				firstDayOfWeek: 0,
                                    				startDayIndex: 0,
                                    				endDayIndex: 99,
                                    				animationSpeed: 0,
                                    				useSymbol: false,
                                    				useWeather: false,
                                    				calendarSet: ["IRS"],
                                    Here’s all the public calendars for testing. My “Main” calendar is a private google calendar.
                                    // First Calendar
                                    // Stand in public calendar to protect private data:
                                    						url: "https://calendar.google.com/calendar/ical/brendan.keyport%40gmail.com/public/basic.ics",
                                    						url: "https://recollect.a.ssl.fastly.net/api/places/BC71002A-F27F-11E8-B5B7-6853A40EAB6C/services/579/events.en-US.ics?client_id=91264B66-7113-11ED-8C28-2101D6C077E5",
                                    // Second Calendar
                                    						url: "http://cal.events/VReW45.ics",
                                    						color: "#69BE28",
                                    						url: "https://calendar.google.com/calendar/ical/3vejg64nfe9hk5odcphufgis14%40group.calendar.google.com/private-ae3d986ef6488a425755baf7198a1c99/basic.ics",
                                    						color: "#69BE28",
                                    						url: "https://calendar.google.com/calendar/ical/mp4efjqgjiq6hphri5ppkkm66k%40group.calendar.google.com/private-81bfdc024de66a7639ac010dfe56263a/basic.ics",
                                    						color: "#E8291C",
                                    						url: "https://calendar.google.com/calendar/ical/fgl0a1o8duc3quq3mpjlcopk50%40group.calendar.google.com/private-c55f9de420fe504de01c18f263d70fa7/basic.ics",
                                    						color: "#69BE28",
                                    						url: "https://calendar.google.com/calendar/ical/a6fras24hof5ibrk9q1aeg0igg%40group.calendar.google.com/private-147cebc733aab31784e2ab7f18c13cbc/basic.ics",
                                    						color: "#69BE28",
                                    						url: "https://gohuskies.com/calendar.ashx/calendar.ics?sport_id=3",
                                    						color: "#69BE28",
                                    						url: "webcal://calendar.google.com/calendar/ical/d2dba52c05b47583471f0eccbdb79938b9b0d5ef7711298f4c3455fe64ae6ffa%40group.calendar.google.com/public/basic.ics",
                                    						color: "#e93b16",
                                    						url: "https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics",
                                    						url: "https://calendar.google.com/calendar/ical/futpub9jb1fisumog0u68s9pdc%40group.calendar.google.com/public/basic.ics",
                                    						color: "#FF1493",
                                    // Third Calendar
                                    						url: "https://calendar.google.com/calendar/ical/ufeoastn72l4rcaact44k3iff3pfcun5%40import.calendar.google.com/public/basic.ics",
                                      MMRIZE @BKeyport
                                      @BKeyport
                                      This is what I’ve got with your config.
                                      Is it different with what you want? Tell/Show me what you expected. (AS-IS and TO-BE)
                                      • BKeyportB Offline
                                        @MMRIZE It seems to be loading everything now, but it’s not refreshing with the calendar app. If I add an event, it misses it until it refreshes at the top of the hour. This includes events going “live” - (bold).
                                          sdetweil @BKeyport
                                          @BKeyport what is the calendar refresh rate set to ?
                                          • BKeyportB Offline
                                            			module: "calendar", // Built in
                                            				animationSpeed: 0,
                                            				broadcastEvents: true,
                                            				broadcastPastEvents: true,
                                            				fetchInterval: 30000,
                                            				maximumEntries: 99,
                                            • 11
                                            • 12
                                            • 5 / 12
