    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 713.6k Views 57 Watching
      chris1971 @sdetweil
      @sdetweil this would be cool. Will try and give a feedback soon.
        chris1971
        I tried several API tokens from Pirateweather without success… But the old DarkSky APi is working again - I assume it will work only until March31st… :disappointed_face:
          sdetweil @chris1971
          @chris1971 you would have to change the dark sky module to use the pirate weather url too
            chris1971
            Do you have additional information what to change?
            Thx
              sdetweil @chris1971
              @chris1971 no, but the pirateweather.net site would probably tell you
                chris1971
                Tried to install MMM-OpenWeatherForecast acc. the description and got a lot of errors during installation:
                npm ERR! Linux 4.9.41-v7+
                npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “install”
                npm ERR! node v6.12.0
                npm ERR! npm v3.10.10
                npm ERR! path /home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/.staging/@iarna/cli-64fafd25
                npm ERR! code ENOENT
                npm ERR! errno -2
                npm ERR! syscall rename
                npm ERR! enoent ENOENT: no such file or directory, rename ‘/home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/.staging/@iarna/cli-64fafd25’ -> ‘/home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/npm/node_modules/@iarna/cli’
                npm ERR! enoent This is most likely not a problem with npm itself
                npm ERR! enoent and is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR! /home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/npm-debug.log<
                After modification of the config and npm start I got a black screen and had to reset the system by disconnection from power supply. Any recommendations?
                  sdetweil @chris1971
                  @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                  WAY downlevel…
                  should be node 16 and npm 8
                  use my install script, it sets up everything…
                  see https://github.com/sdetweil/MagicMirror_scripts
                    chris1971
                    I only have to type <“$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”> in the command line and the Update will be done automatically? No changes to the existing System?
                      sdetweil @chris1971
                      @chris1971 no type, just copy paste ( use ssh VM from desktop/laptop)
                      but still it’s a two part process, check by default, advise, make no changes
                      then rerun with Parm at the end to DO the upgrade
                      if you are ALREADY at the latest release, it will abort, unless that Parm is force
                      • BerkSmash1984B
                        BerkSmash1984
                        Awesome module! Question for you: I am using MMM-Wallpaper and some of the text can be hard to read during certain wallpapers. I looked in the MMM-OpenWeatherForecast.css file but did not see an obvious place to change the color for the text highlighted in the red boxes below. I would like to set them to white (#FFFFFF). Can you tell me where in that css to set that? Thanks for your help!
                          sdetweil @BerkSmash1984
                          @BerkSmash1984 I do not know … but you can find out thru using the developers console
                          see
                          https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1679584458559
                          BerkSmash1984B 1 Reply Last reply Reply Quote 0
                          • BerkSmash1984B
                            BerkSmash1984 @sdetweil
                            Thank you! I will dig into it via the dev console
                            • BKeyportB
                              BKeyport Module Developer @BerkSmash1984
                              @BerkSmash1984
                              It uses the defaults from MagicMirror for grey text. I use:
                              root {
                              	--color-text: #DDD;
                              	--color-text-dimmed: #666;
                              	--color-text-bright: #fff;
                                    --color-background: #000;
                              /* Originals:
                                --color-text: #999;
                              BKeyportB BerkSmash1984B 3 Replies Last reply Reply Quote 0
                              • BKeyportB
                                Anyone know how to get the entire table to center within the region? I don’t want to center the contents, only the position of the table being built by the app.
                                thanks!
                                  sdetweil @BKeyport
                                  @BKeyport
                                  position: relative
                                  either use margin or x and width, margin is easier
                                  • BKeyportB
                                    @sdetweil the problem is that I can’t find the right CSS class to apply it to.
                                      sdetweil @BKeyport
                                      @BKeyport did u use the dev console to examine the content? click on the element u mean to adjust?
                                      may not be a class, so you would have to select more … just have to be careful if the table is in a div, in a div… then its ‘size’ and position are relative to the parent (div) …
                                      .modulename table {
                                      position: relative
                                      this is my goto for figuring out the selector ( the thing before the { )
                                      https://www.w3schools.com/cssref/css_selectors.php
                                      look at the css for the form in MMM-Config
                                      https://github.com/sdetweil/MMM-Config/blob/main/webform.css
                                      selector doesn’t have to start with a class…
                                      note in the cheat sheet its ALWAYS selects ALL elements that match
                                      • BKeyportB
                                        @BerkSmash1984 FYI, there’s more ways to make things easier to read - fade the background - or add a background to the modules themselves.
                                        Here’s how to add a background to the modules:
                                        the .5 is the opacity in this case, I’ve got it set to 50% visible.
                                        .module {
                                          background-color: rgba(0,0,0,.5);
                                        • BKeyportB
                                          @sdetweil found it. Missing a * on the opening CSS when I did it…
                                          .MMM-OpenWeatherForecast * {
                                          	box-sizing: border-box;
                                          	margin-left: auto;
                                          	margin-right: auto;
                                          does it, for anyone else that runs across this.
                                          • BKeyportB
                                            @BerkSmash1984 I’ve also found, in the documentation for MMM-Wallpaper, a “filter” option - If you don’t want to put a background on the modules, you can use this to improve readability.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
