    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 692.4k Views 57 Watching
    • T Offline
      trividar @DDE12
      If the Module doesn’t load the informations change ```
      “https://api.openweathermap.org/data/3.0/onecall”
      to
      “https://api.openweathermap.org/data/3.0/onecall?”
      an it should work!
        sdetweil @DDE12
        @DDE12 the API url is in the node_helper.js
        we recently add a Parm to enable picking v3 of the API vs 2.5 (old free).
        the add on modules need to do the same
        • Y Offline
          yk
          Fantastic work! I was using the previous DarkSkyForecast version - easy shift to this one.
          I’m trying to put the hourly data and daily data in the same “row” across using tiled view instead of 2 rows. I’m happy to edit the njk file (have tweaked a bit haven’t gotten it “just right” yet). Any ideas? I gather it’s something with the hourly and daily divs.
          Is data available to get mm of precipitation in the hourly and daily blocks? It shows % chance - keen to add precipitation instead.
          Thanks!!
          • Y Offline
            yk @yk
            @yk said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
            Thanks!!
            Replying to my own post incase someone else wants a single row for 3 hours and 3 days. You’ll need to comment out lines 191, 309, 315, 318 in the njk file. This results in a single row readable left to right hours then days. It’s a useful view if you’re using a full width view.
              justbob
              So what’s the solution for the 401 error?
              The key works in default weather module, but in this one it’s not.
              @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
              @DDE12 NEVER run audit fix…
              Can you elaborate why?
              I for one don’t like seeing vulnerabilities and critical messages anywhere, and letting security flaws linger…
                sdetweil @justbob
                @justbob audit fix forces changes, and many times drags in breaking changes that we can do nothing about.
                we are not running a web site w hundreds of random users, and are not dragging in other page content with their scripts. we are calling apis…
                so the risks for (y)our site is extremely small…
                I don’t know the answer on openweathermap.
                  chris1971
                  I am using MMM-DarkSkyForecast - everything was fine, but today the module is not loading anymore. Are there any changes or known issues? Do I have to swith to another module?
                  Thx, Chris
                  • BKeyportB Offline
                    BKeyport Module Developer @chris1971
                    @chris1971 DarkSky is dead. You’ll have to switch. Apple bought 'em up and is shutting down the APIs.
                      chris1971
                      Thanks for the Info. Hope that the switch to Open Weather will be smooth. Long time ago that I have modified something on the mirror…
                        sdetweil @chris1971
                        @chris1971 @BKeyport
                        there is a replacement API. same parns
                        just different url
                        was posted here in the last few months.
                        no time to search right now
                        • karsten13K Offline
                          karsten13 @sdetweil
                          http://pirateweather.net
                            chris1971 @karsten13
                            @karsten13
                            I tried a new API Token from pirateweather for OpenWeather - but the module is not loading. Do I have to do some other changes next to the API?
                            The token is valid until April 22nd. Do I have to renew the token every month?
                              sdetweil @chris1971
                              @chris1971 pirate weather is the dark sky replacement.
                              openweather has a different API token
                                chris1971 @sdetweil
                                pirateweather is another module next to openweather? Sorry for the dumb question…
                                Then I will try to go with Openweather acc. the description…
                                  sdetweil @chris1971
                                  @chris1971 no. pirateweather.net provides an API that looks like the dark sky API.
                                  so the dark sky module could be made to work again
                                    chris1971 @sdetweil
                                    @sdetweil this would be cool. Will try and give a feedback soon.
                                      chris1971
                                      I tried several API tokens from Pirateweather without success… But the old DarkSky APi is working again - I assume it will work only until March31st… :disappointed_face:
                                        sdetweil @chris1971
                                        @chris1971 you would have to change the dark sky module to use the pirate weather url too
                                          chris1971
                                          Do you have additional information what to change?
                                          Thx
                                            sdetweil @chris1971
                                            @chris1971 no, but the pirateweather.net site would probably tell you
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
